Homework Help: Definitions of Polygons
  1. Aug 13, 2011 #1
    Dembadon
    I'm working through the following book: Principles of Mathematics, by Allendoerfer & Oakley.
    Since I haven't taken a proof-based course yet, and won't be able to until spring 2012 :grumpy:, I want to make sure that I'm not forming habits that will hurt me when I do. There are some answers that aren't provided in the back of the book, so I want to check them with you all.
    On Page 5, Problem 2:
    Assume that polygon, side of a polygon, angle, length of side, equal, and parallel, have been previously defined. Then define:
    a) Parallelogram.
    b) Rhombus.
    c) Pentagon.
    d) Regular Pentagon.
    e) Trapezoid.
    f) Hexagon.
    2. Relevant equations
    I believe the exercise wants to ensure that I'm using the "if and only if" bi-conditional logical connective correctly. My understanding is that the "if" includes all of the cases that follow the next clause, and "only if" excludes all others. So, I need to make sure that my definitions do not include other polygons.
    3. The attempt at a solution
    Parallelogram: A four-sided polygon is a parallelogram if and only if it has two sets of parallel sides.
    Rhombus: A four-sided polygon is a rhombus if and only if its sides are equal and has two pairs of congruent angles.
    Pentagon: A polygon is a pentagon if and only if it has 5 sides.
    Regular Pentagon: A polygon is a regular pentagon if and only if it has 5 equal sides.
    Trapezoid: A four-sided polygon is a Trapezoid if and only if it has two parallel sides and two pairs of congruent angles.
    Hexagon: A polygon is a hexagon if and only if it has 6 sides.
    Thank you for your help.
    Edit: I have avoided simply looking up the definitions on the internet so that I'm given the chance to reason my way to an answer, if possible.
  3. Aug 13, 2011 #2
    I like Serena
    Hi Dembadon! :smile:
    Just a few comments on your statements (mostly nitpicking, but that is what math is about :wink:).
    In a rhombus the sides are not equal (that would be pretty weird!), but the lengths of the sides are equal.
    The two pairs of congruent angles are redundant in a rhombus (but not wrong).
    A pentagon with 5 sides of equal length does not have to be regular.
    Perhaps you could try to find an example?
    A trapezoid does not have to have two pairs of congruent angles.
    Perhaps you could look up the definition of a trapezoid?
    The rest looks good! :smile:
  4. Aug 13, 2011 #3
    Dembadon
    Hello!
    Thank you, ILS. Nitpicking is exactly what I was hoping for! I need, and want, to learn to be as precise as possible.
  5. Aug 13, 2011 #4
    I like Serena
    Good!
    I've been tuning my nitpicking back in real life, since it usually mostly irritates people, but I believe it is invaluable in math and programming. :wink:
Loading...
Similar Threads for Definitions Polygons
Interior and Exterior Angle of a Polygon: Formula not working
