1. Not finding help here? Sign up for a free 30min tutor trial with Chegg Tutors
Deflection of a beam question
  1. Mar 24, 2015 #1
    For the simply supported steel beam [E = 200 GPa; I = 129 × 10^6 mm4], use the double-integration method to determine the deflection vB at B. Assume L = 4 m, P = 60 kN, and w= 40 kN/m.
    Can someone please help, when I insert x=2m into the equation i derived for M, and then insert M into equation 1, I do not get the correct answer (-8.27 mm).
    2. Relevant equations
    E.I.y''=M (eq. 1)
    M=F.d (eq. 2)
    3. The attempt at a solution
  3. Mar 24, 2015 #2
    SteamKing
    Staff Emeritus
    Check your equation for the bending moment in the beam. I would split the problem up into calculating the BM due to the central point load plus the BM due to the distributed load.
    In order to avoid confusion, draw the shear and bending moment diagrams for this beam. Because the beam is symmetrically loaded, these can almost be done by inspection.
Have something to add?
Draft saved Draft deleted
Similar Discussions: Deflection of a beam question
  1. Deflection of a beam (Replies: 4)
  2. Beam Deflection (Replies: 0)
Loading...
