Dehumidification to solve the third world drought problem
  • Thread starter Thread starter vernonn4styv
Massive dehumidifiers could potentially address drought issues by creating water for crops and drinking, powered by solar energy. However, their effectiveness is limited in arid regions where humidity is low, such as many parts of Africa. The dew point, which varies by climate, plays a crucial role in moisture extraction; in dry areas, it may be too low to yield significant water. Alternative methods, like using plastic filament fences to trap moisture, have shown some promise in capturing water from the air. Overall, while innovative ideas exist, the feasibility of large-scale dehumidification in arid climates remains questionable.
vernonn4styv
Hi, I am new to this site, i am not a brain box nor am i studying for any qualifications.
I wonder why the worlds drought problem could not be solved by massive dehumidifiers to create water for crops and filtered for drinking.
So far i see no problem why this cannot be done using solar energy to charge batteries by day and produce water in the nights?
Someone told me that it is possible in places where the air is damp but will not work in arrid locations, Would africa be considered as arrid?
Does evenings hold more moisture and could this system work in places like Africa?
It is my intention to eventually be able to set this project up in a location where water is greatly needed, this will take place on behalf of a charity and all the help i can get to solve these problems would be greatly recieved. Regards Vernon.
If it is too dry to rain then it is likley to be to dry to extract significant water.
There are schemes to trap water from the air in the early morning using fences made of plastic filaments - high tech versions of the shrubs that used to trap water naturally
Pulling moisture from the air is simply a matter of dropping that air below the dew point. What that dew point is is completely climate dependent. Where I live, in the northeastern US, the dew point runs around 60-75F for 8-10 months of the year and drops down to 10-20F in the winter (with a month on either end of high variability). So in summer, it is easy to extract moisture, in winter, it is essentially impossible (water vapor doesn't liquify, it freezes directly on a coil when it is that cold).
Africa is a big place. The areas which suffer drought tend not to have much moisture in the air anyway.
Thread 'How can I find the cleanout for my building drain?'
I am a long distance truck driver, but I recently completed a plumbing program with Stratford Career Institute. In the chapter of my textbook Repairing DWV Systems, the author says that if there is a clog in the building drain, one can clear out the clog by using a snake augur or maybe some other type of tool into the cleanout for the building drain. The author said that the cleanout for the building drain is usually near the stack. I live in a duplex townhouse. Just out of curiosity, I...
Thread 'Where is my curb stop?'
My water meter is submerged under water for about 95% of the year. Today I took a photograph of the inside of my water meter box because today is one of the rare days that my water meter is not submerged in water. Here is the photograph that I took of my water meter with the cover on: Here is a photograph I took of my water meter with the cover off: I edited the photograph to draw a red circle around a knob on my water meter. Is that knob that I drew a red circle around my meter...
