Homework Help: Delta force
  1. Apr 28, 2010 #1
    In delta potential barrier problem Schrodinger equation we get
    [tex]\psi(x)=Ae^{kx}, x<0[/tex]
    [tex]\psi(x)=Ae^{-kx}, x>0[/tex]
    We must get solution of
    [tex]lim_{\epsilon \rightarrow 0} \int^{\epsilon}_{-\epsilon}\frac{d^2\psi}{dx^2}dx[/tex]
    2. Relevant equations
    3. The attempt at a solution
    [tex]lim_{\epsilon \rightarrow 0} \int^{\epsilon}_{-\epsilon}\frac{d^2\psi}{dx^2}dx=lim_{\epsilon \rightarrow 0} \frac{d\psi}{dx}|^{\epsilon}_{-\epsilon}[/tex] and get the solution
    I can say that the whole function is
    [tex]\psi(x)=Ae^{-k|x|}[/tex]
    I don't have first derivative in 0.
    [tex]lim_{\epsilon \rightarrow 0} \int^{\epsilon}_{-\epsilon}\frac{d^2\psi}{dx^2}dx=lim_{\epsilon \rightarrow 0} \int^{0}_{-\epsilon}\frac{d^2\psi}{dx^2}dx+lim_{\epsilon \rightarrow 0} \int^{\epsilon}_{0}\frac{d^2\psi}{dx^2}dx=0[/tex]
    Why I don't get same solution different then zero like in case
  3. Apr 28, 2010 #2
    gabbagabbahey
    First, I'd like to point out how disappointed I was when I clicked on this thread and found that it wasn't a Chuck Norris movie:biggrin:
    No you cant. The wavefunction [tex]\psi(x)=\left\{\begin{array}{lr}Ae^{kx}, & x<0 \\ Ae^{-kx}, & x>0\end{array}\right.[/itex] is undefined at [itex]x=0[/itex] (as it should be for a delta function potential). The wavefunction [itex]\psi(x)=Ae^{-k|x|}[/itex] is defined at [itex]x=0[/itex]; the two wavefunctions are not equivalent.
    I don't see how you are getting zero for that limit. Show the rest of your steps.
  4. Apr 29, 2010 #3
    [tex]
    [/tex]
    [tex]lim_{\epsilon \rightarrow 0} \int^{0}_{-\epsilon}\frac{d^2\psi}{dx^2}dx+lim_{\epsilon \rightarrow 0} \int^{\epsilon}_{0}\frac{d^2\psi}{dx^2}dx=lim_{\epsilon \rightarrow 0}\frac{d\psi}{dx}|^{0}_{-\epsilon}+lim_{\epsilon \rightarrow 0}\frac{d\psi}{dx}|^{\epsilon}_{0}
    [/tex]
    [tex]\frac{d\psi}{dx}=kAe^{kx}[/tex] for [tex]x<0[/tex]
    [tex]\frac{d\psi}{dx}=-kAe^{-kx}[/tex] for [tex]x>0[/tex]
    kA-lim_{\epsilon \rightarrow 0}kAe^{k\epsilon}-lim_{\epsilon \rightarrow 0}kAe^{-k\epsilon}+kA=2kA-2kA=0[/tex]
  5. Apr 29, 2010 #4
    Double check your exponentials (hint hint) and maybe expand them out ignoring terms higher than [itex]\epsilon^1[/itex]
