Delta function integral
In summary, the conversation is about finding and plotting the function f(y), which is equal to the integral of the delta function over a certain interval. The conversation discusses different scenarios for calculating f(y) based on the position of the singularity in the interval, and suggests a method of converting the original problem to a form with simpler integration limits.
thenewbosco
187
let [tex]f(y)=\int_0^2 \delta(y-x(2-x))dx[/tex]. Find f(y) and plot it from -2 to 2.
I know how to calculate [tex]\delta (g(x))[/tex] but i am not sure how to treat it with the y. I thought possibly to solve the quadratic in the delta function to find what x will equal for the roots in terms of y and got 1+(1-y)^1/2 and 1-(1-y)^1/2. i am not sure though how to find f(y) with the integral. any suggestions?
Treat the cases separately:
1. The singularity lies in the open interval between the end points
2. The singularity lies outside the interval
3. The singularity lies at an end point
The singularity arildno refers to is where y- x(2-x)= 0. In other words when y= 2x- x2. Find the value of that integral, f(y), for y in the positions arildno listed and that's your function.
so what youre saying is to form the integral [tex]f(y)=\int 2x-x^2 dx[/tex]?
if its outside the interval do i let the limits be (-infinity to 0) and (2 to infinity)
for inside 0 to 2 but at the endpoints what are the limits?
No, why do you think that? :confused:
What is [itex]\int_a^b \delta(x)dx[/itex] for any a, b?
Even more appropriately,
What is [itex]\int_a^b \delta(x)f(x)dx[/itex] for any a, b?
One way to solve the problem at hand is to convert the original problem,
to the form
[tex]f(y)=\int_{u_0}^{u_1} \delta(u)f(u)du[/tex]
Note that the integrand may have two singularities between the integration limits, depending on the value of y.
What is the definition of the delta function integral?
The delta function integral, also known as the Dirac delta function, is a mathematical function that is used to model point-like or concentrated forces or impulses in physics and engineering. It is defined as a distribution that is equal to zero everywhere except at a single point, where it is infinite, and has an integral of unity.
What is the purpose of the delta function integral?
The delta function integral is used to simplify calculations and models in physics and engineering, by representing point-like forces or impulses as a single mathematical point. It is also used in signal processing, probability theory, and other areas of mathematics.
What are the properties of the delta function integral?
The delta function integral has several important properties, including the sifting property, which states that when the delta function is integrated with another function, the value of the function at the point where the delta function is non-zero is returned. It also has the scaling property, which states that the delta function can be scaled by any constant without affecting its integral.
How is the delta function integral used in practical applications?
The delta function integral is used in many practical applications, such as in calculating the response of a system to a sudden force or impulse, in modeling point sources of pollution or radiation, and in solving differential equations in physics and engineering. It is also used in probability and statistics to represent events with infinitesimal probabilities.
Are there any limitations to the use of the delta function integral?
While the delta function integral is a useful mathematical tool, it does have some limitations. For example, it cannot be used to represent continuous distributions, and it can lead to infinite or undefined results if not used properly. It is important to carefully consider the context and assumptions when using the delta function integral in practical applications.
