Can Bound States with Exact Energies Violate the Uncertainty Principle?
In summary, the delta function potential well has a bound state with a definite energy, but the uncertainty in position means it still fails to satisfy the HUP.
Allday
164
So I read that the delta function potential well has one and only one bound state. This seems to give a precise momentum and position as the bound state has a definite energy and the particle must be in the well. This seems to be a violation of the HUP. Is the physical impossibility of creating a true delta function potential the savior here?
Ahh I forgot about the exponential fall off outside the well. So I suppose there is still some uncertainty in position, though is it enough to counter a zero uncertainty in momentum? For that matter the regular finite potential well has bound states that have exact energies (and therefore momenta) and yet the uncertainty in position seems to not be big enough to satisfy the HUP?
Are these finite potential well bound states (stationary states) not realizable by particles. Can particles only be described by wave packets?
The uncertainty in the position of the particle is the amount of 'spread' in the probability distribution of the position. Likewise for the momentum.
Even if you know the particle is inside the well, there is still some uncertainty in its position. You don't know 'where' you'll find the particle in the well, when you measure its position.
A particle in a bound stationary state has a definite energy, but that doesn't mean it also has a definite momentum.
The uncertainty prinicple is always satisfied. Try it with the infinite square well, or any other potential.
Quantitatively it says:
[tex]\sigma_x \sigma_p \geq \frac{\hbar}{2}[/tex]
Where [itex]\sigma_x, \sigma_p[/itex] are the standard deviations of the position and momentum distributions respectively.
There appears to be a common error that permeates throughout your posting here. Somehow there is an impression that if a state has a definite energy, then the momentum must have the same degree of definiteness. What this implies is that the hamiltonian H always commutes with the momentum operator p. This isn't true in general. [H,p] is not always zero. This is because H typically has a term containing p and another term containing "x", or the position operator, in the potential part. And we already know p and x do not commute. So H and p do not necessarily commute.
The only situation [H,p] = 0 is for a free particle, where V(x)=0. So just because one has a well-defined energy state, it doesn't mean one also has a well-defined momentum distribution.
Zz.
common error
Yes that's it. I was equating states with exact energy with states that have exact momenta and this can only be done when they commute. Thanks Galileo and Zapper.
1. What is a delta function potential?
A delta function potential, also known as a Dirac delta function potential, is a mathematical function used in quantum mechanics to describe a potential energy that has a singular point of infinite strength and zero width. It is often used to model point-like interactions, such as a particle interacting with a potential well.
2. How is a delta function potential represented mathematically?
The delta function potential is represented by the Dirac delta function, which is typically denoted as δ(x). It is defined as zero everywhere except at x = 0, where it is infinite. Mathematically, it can be written as δ(x) = ∞ for x = 0 and δ(x) = 0 for all other values of x.
3. What is the physical significance of a delta function potential?
A delta function potential represents a point-like interaction between particles. It can be used to model a variety of scenarios, such as a particle being confined to a specific location or interacting with a potential barrier. It is also commonly used in quantum mechanics to simplify calculations and provide solutions for certain systems.
4. How is a delta function potential used in quantum mechanics?
A delta function potential is used in quantum mechanics to describe the potential energy of a system. It is often used in the Schrödinger equation to solve for the wave function of a particle in a given potential. It is also used to study the behavior of particles in confined spaces or in the presence of barriers.
5. Are there any limitations or drawbacks to using a delta function potential?
While the delta function potential is a useful mathematical tool in quantum mechanics, it does have some limitations. It cannot be physically realized, as it represents an infinitely strong and narrow potential. Additionally, it may not accurately represent the behavior of particles in certain scenarios, such as when interactions are not truly point-like. Therefore, it should be used with caution and in conjunction with other potential models.
  • Quantum Physics
  • Quantum Physics
  • Quantum Physics
