bumfluff
- 8
I understand how an ordinary wing works but I cannot find anything on how a delta wing works, the only thing I know is that it creates vortices on the upper wing surface, but how do these vortices create lift?
bumfluff said:Is that a bit like the seam on say a baseball if I am right in thinking that can help reduce the turbulent wake, or maybe the fluff on a tennis ball?
The shape of a delta wing, with its triangular structure and swept-back design, creates a high aspect ratio and a large surface area for air to flow over. This allows for greater lift generation, as air is forced to travel a longer distance over the wing, resulting in a lower pressure zone on the top of the wing and a higher pressure zone on the bottom. This pressure difference creates lift.
The angle of attack for a delta wing is the angle at which the wing meets the relative wind. This angle is typically higher than that of a traditional straight-wing design, as the swept-back shape of the delta wing allows for a higher angle of attack without stalling. This angle is critical in generating lift and determining the efficiency of the wing.
Vortices, or rotating air currents, are created at the wingtips of a delta wing due to the sharp corners of the triangle shape. These vortices help to energize the airflow over the wing and create a downward force, resulting in additional lift. They also help to prevent flow separation and stalling at high angles of attack.
In addition to the unique shape, other factors that contribute to lift on a delta wing include the speed and density of the air, the angle of attack, and the size and shape of the wing itself. The engine power and weight distribution of the aircraft also play a role in the overall lift generation.
Yes, a delta wing can produce lift at low speeds, but it may require a higher angle of attack to do so. The swept-back design of the wing allows for a higher angle of attack without stalling, making it more efficient at lower speeds compared to traditional straight-wing designs. However, this also means that delta wings may not perform as well at higher speeds, as they can generate too much lift and cause the aircraft to become unstable.
