Proper Disposal of an Upright Piano: Tips and Precautions
  • Thread starter wolram
  • Tags
    Piano
In summary: If it is damaged beyond repair and you just need to break it own to haul away, remember the strings inside are all under tension, so just smashing might have some undesirable results of parts attached to strings snapping at you. You also might have some salvageable parts someone could use to repair another piano if it's not all smashed up.Would it be best to unscrew everything first or just smash it to pieces?It's probably best to unscrew everything first. If you smash it, there's a good chance that the strings will snap and you'll end up with a damaged piano. There are some good chances that you'll be able to salvage some parts, but it's
wolram
Dearly Missed
4,446
558
: Is it completely beyond repair? Seems a shame to destroy a piano if it's repairable. Someone might appreciate it for a child starting piano lessons if they can get repairs done cheaper than buying a working one.
https://www.youtube.com/watch?v=rJgt-HO0_kY
Wear eye protection if you smash it. The tension in the wires is high enough to take out an eye.
Fantastic Ivan i watched that twice, it is a shame this piano has terminal wood worm.
Those strings are under a lot of tension. And yes, they can put the hurt on you if they break.
Donate it someone will probably be willing to come and pick it up even. It doesn't need to be in great shape either lots of places will take just about any piano you can toss at them as they will either use the parts to repair others or find it a home with people who would never be able to even afford a used one.
The bottom line is that there probably isn't anything worth salvagiing. Unlike violins, pianos don't naturally have a long life. Instruments like rehearsal pianos that get played hard for 8 or 10 hours a day are scrap after a couple of years. Obviously a $250,000 Steinway is going to last longer than that, but I guess that's not what we are talking about here!
Unless it's got some value as antique furniture or some real historical interest as an instrument (e.g. it's more than say 150 years old) it would be cheaper to buy a factory built modern piano than pay to have it hand-restored.
Giving it to a kid to learn on isn't really a good idea either. If the kid has any interest or talent, they deserve something that will reward their efforts, not something where they will be fighting its defects rather than learning to play properly. Most musical instrument shops in the UK run schemes where you can rent an instrument for a year or two and then either buy at a discounted price or return it if the kid isn't interested or doesn't have any aptitude.
The safe way to demolish it is first take the tension off the strings. You should be able to find a socket spanner that will fit the tuning pegs. To avoid cracking the cast iron frame, start by lowering the pitch of ALL the strings by two or three notes. That will mean quite a small amount of turning the pins - check by playing a note and detuning it. Then repeat for ALL the notes, then you can wind off the tension completely.
Beware of breaking piano wires. The broken ends can do a lot of damage if they whiplash you. The safest way is not to take anything apart, except the minimum required to get at the tuining pins, before you take the tension off the strings. Then the rest of the piano will protect you if anything does break.
Here's how to demolish a grand piano. Watch and learn.
https://www.youtube.com/watch?v=MoTyDD0C93U
Performance of a piece of music by Annea Lockwood
https://www.youtube.com/watch?v=JXcpSUsGldg
Remove the action and strings and use it for storage. I once saw an old upright piano turned into a bar.
Flames? Destruction!?
Please don't get me started...
It's a new year!
https://www.youtube.com/watch?v=7cQ-yGCyjyM
I was only 7...
What did I know?
Woolie. Give it up. There may be someone who could turn such an instrument into a thing of beauty. Put it at the end of the driveway, with a sign marked; "Free".
I'm sure some old sod will snatch it up.
Just don't destroy it. :cry:
wolram said:
...it is a shame this piano has terminal wood worm.
Ah, too bad. Even in the clip, you'll see the piano used was already gutted of the wires.
Don't try moving it anywhere on your own. You need 3 people who know what they are doing, plus one of these: http://www.alanstuart.co.uk/removal/piano-truck.html
You can't use more than about 3 people, because there isn't enough piano for them all to get hold of when going through doorways etc. You need to plan ahead if there are narrow corridors etc, so people don't get "trapped" on the wrong side of the piano where they can't do anything useful.
Upright pianos are deceptively unstable - they are unexpectedly easily tip on their backs. That's not good news if some body parts end up underneath.
1. Can an upright piano be safely demolished?
Yes, an upright piano can be safely demolished as long as it is done by a professional with proper equipment and techniques.
2. What is the best way to demolish an upright piano?
The best way to demolish an upright piano is to first remove all the strings and internal components. Then, use heavy machinery or hand tools to break down the wooden frame and remove any remaining pieces.
3. Is it possible to salvage any parts of the piano during demolition?
Yes, some parts of the piano such as the keys, pedals, and decorative pieces may be salvageable. However, the soundboard and other internal components are typically not salvageable.
4. Can the wood from a demolished upright piano be repurposed?
Yes, the wood from a demolished upright piano can be repurposed for various projects such as furniture or art. It is important to properly dispose of any hazardous materials, like the ivory keys, before repurposing the wood.
5. How much does it cost to demolish an upright piano?
The cost of demolishing an upright piano varies depending on the location, size of the piano, and the company or individual performing the demolition. It is best to contact a few different professionals for quotes before making a decision.
  • Art, Music, History, and Linguistics
  • General Discussion
