Homework Help: Density 1
  1. Jul 3, 2009 #1
    The mass of an unfilled balloon is 7.5g. How much helium has to be filled in the balloon to make it float in air?
    density of helium: 0.18kg/m^3
    density of air: 1.29kg/m^3
    2. Relevant equations
    When I calculate the volume like this: (7.5*10^-3kg)/(0.18kg/m^3)=0.041m^3 and than I don't know what to do with the density and the volume of water...Solution would be 1.2g
  3. Jul 3, 2009 #2
    Borek
    Staff: Mentor
    When will the balloon float?
  4. Jul 3, 2009 #3
    When it has 1.2g helium in it. But I don't know how I can calculate this...
  5. Jul 3, 2009 #4
    What are the conditions required for the balloon to float? What should the net force on it be in order for it to float?
  6. Jul 3, 2009 #5
    I don't know what the conditions are. I just know that it has to float. And why do we need a net force? And how would we calculate it? Thx for your patience
  7. Jul 3, 2009 #6
    Borek
    Staff: Mentor
    What forces act on balloon?
  8. Jul 3, 2009 #7
    LowlyPion
    When your balloon is filled with helium, how much less mass is in it per unit volume than if it was filled with air?
    Think buoyancy. Displaced air ...
    When you know what volume you need to lift the mass of the balloon shell itself, then you can figure how much helium is in that volume can't you?
  9. Jul 4, 2009 #8
    So the volume needed to lift the mass of the balloon shell itself is calculated like this: 7.5*10^-3kg / 1.29kg/m^3=0.006m^3. But what's the point now? Should I calculate 7.5*10^-3kg / 0.18kg/m^3=0.04m^3 and then??
  10. Jul 4, 2009 #9
    LowlyPion
    No. Not like that.
    Think of the difference in density needed.
    Air is 1.29 kg/m3. If you replace it with helium then that means that you have a buoyancy of (1.29 - .18) or 1.11 kg/m3.
    The volume needed to lift the .0075 kg of the balloon itself is what you want. TRhen figure the mass of helium in that volume.
