Calculating Air Density at High Elevations
In summary, the density of air at high altitudes is estimated by assuming the atmosphere is an isothermal ideal gas in a constant gravity field, then calculating the pressure and molecular weight distribution using Boltzmann statistics.
LT72884
323
48
Ok, we all know that density is mass/volume. So if air is 1.22kg/m3,If we increase pressure, volume will change, therefore density can change.
So how does one calculate density of air at higher elevations. Where i currently live, at 4700ft above sea lvl, I am guessing air density is not 1.22kg/m3. So how would i calculate it?
Thanks
The easiest possible way is to assume the atmosphere is an isothermal ideal gas in a constant gravity field. Then the energy of each gas molecule E = 1/2 mv^2 + mgz, where g= 9.8 m/s^2 and z is height above some reference altitude z0, e.g. sea level, where you know a reference pressure, e.g. p0 = 1 atm. Boltzmann statistics gets you the distribution of molecules, therefore the density, therefore the pressure, is then proportional to exp(-E/kT). You don't care about the kinetic energy part, and it separates. You're left with an exponential distribution of altitudes, and all you need to do is get the mass and units straight, and do an integration to establish the constant in front of the exponential in terms of your reference pressure, the average mass of the gas molecules, k and T. Pick some T, e.g. the average temperature of the troposphere, and you're all set.
The most obvious flaws in this are that the atmosphere is not isothermal and that the gravity field isn't constant, but I don't think they would be huge flaws at this level of calculation. Neither T nor g vary much over 5000 ft.
For an ideal gas which air approximates use the ideal gas law
PV = nRT
where P is pressure in atmospheres (or millibars), V is volume in liters, is the number of moles in the volume, R is the universal gas constant = 0.0821 liters-atm /gram-mole-deg-Kelvin. and T is temperature in deg Kelvin ( 273° + °C)
using ρ =m/V with m the mass (in the volume) = gram molecular weight for air x the number of moles.
You get ρ = m×P/RT
from that you can compute the ratio of densities at different pressure and temp.which eliminates the mass and the constant R.
ρel = ρsl ×Pel×Tsl/(Psl×Tel)
You can calculate the pressure at elevation ( see https://www.mide.com/pages/air-pressure-at-altitude-calculator ) or you can get a barometer calibrated at sea level and bring it to you elevation and read the pressure. The pressure at sea level is usually 1 atmosphere (1013.2 millibars) ±2% at 0 °C (273°K).
Likes LT72884
Try here.
Likes LT72884
The barotropic formula gives the vertical pressure variation as $$p=p_0\exp{\left(-\frac{Mg}{R}\int_0^z{\frac{dz'}{T(z')}}\right)}$$where z is the altitude, ##p_0## is 1 bar, M is the molecular weight of air, g is the acceleration of gravity (essentially constant up to your altitude), T(z) is the absolute temperature at altitude z, and R is the universal gas constant. If z is in meters, the temperature in the troposphere decreases with altitude as $$T(z)=288.15-6.5z/1000$$ The density at altitude z is calculated from $$\rho=\frac{p(z)M}{RT(z)}$$
sophiecentaur said:
Those are interesting formulas. Now i just need to find all the other numbers and calculate density in my area haha.
I know pressure can effect volume, but where is that in the basic density equation? What substitutes in for volume that has P involved?
Thanks for all the jelp
1. What is air density and why is it important to calculate it at high elevations?
Air density refers to the mass of air particles per unit volume. It is important to calculate air density at high elevations because the density of air decreases as altitude increases, which can affect various processes such as aircraft performance, weather patterns, and human health.
2. How is air density at high elevations calculated?
Air density at high elevations can be calculated using the ideal gas law, which states that the product of pressure and volume is proportional to the number of gas molecules and the temperature. This equation can be rearranged to solve for air density, taking into account the decrease in air pressure and temperature at higher altitudes.
3. What are the units of measurement for air density?
The standard unit of measurement for air density is kilograms per cubic meter (kg/m3). However, it can also be expressed in other units such as grams per cubic centimeter (g/cm3) or pounds per cubic foot (lb/ft3).
4. How does air density at high elevations affect aircraft performance?
As air density decreases at higher altitudes, there is less air for the aircraft's engines to take in, resulting in reduced engine power and thrust. This can lead to longer takeoff distances, reduced climb rates, and decreased fuel efficiency. Pilots must take into account air density when planning flights at high elevations to ensure safe and efficient operation of the aircraft.
5. Can air density at high elevations impact human health?
Yes, air density at high elevations can have an impact on human health. As air density decreases, there is less oxygen available for the body to use, which can lead to altitude sickness or hypoxia (lack of oxygen). It is important for individuals to acclimatize properly when traveling to high elevations to avoid these potential health risks.
  • Mechanics
  • Mechanics
  • Mechanics
  • Mechanical Engineering
  • Classical Physics
