Density Of Metal In Alloy
  • Thread starter Lancelot59
A Mg-Al alloy has a mass of 0.263 g and a density of 2.40 g/cm3. The density of pure Mg =
1.74 g/cm3 and for pure Al = 2.70 g/cm3. Calculate the % Mg in the alloy.
D=M/V
Well I'm not really sure where to do. I solved for the volume of the alloy, then tried to use it to determine the mass of the Mg. Once there I divided by the total mass and multiplied by 100 to get the wrong answer.
How can I go about getting the mass of Mg in the alloy?
Answers and Replies
Borek
Mentor
28,702
3,190
Assume that volume of the alloy is the sum of volumes and mass is the sum of masses. That gives two equations in two unknowns.
In reality only one of these equations is correct - that is, mass is sum of masses. Volumes are not additive. But that's not your fault.
methods
Could you please elaborate on why volumes aren't additive in this case?4
Also I'm getting nowhere fast.
I wound up with 0.263g = MassMg + MassAl
Then solved for MassAl like so:
MassAl = 0.263 - MassMg
Then tried to substitute it back in:
0.263 = MassMg + 0.263 - MassMg
Which just cancels itself out.
Borek
Mentor
28,702
3,190
Where is the equation for sum of volumes? Note, that volumes can be expressed using mass and density.
Volumes are not additive in general. If you mix 50 mL of water and 50 mL of ethanol you will get 96.4 mL of mixture.
Ok. I finally got word back from my teacher, and I think I see what to do now. I'll post my resulting solution when I figure it out.
Related Threads on Density Of Metal In Alloy
  • Last Post
  • Last Post
18K
15K
  • Last Post
  • Last Post
10K
9K
