Density of Metal: 210g/180g/120g
In summary, density is a measurement of how much mass is contained within a specific volume of a substance, typically expressed in grams per cubic centimeter or kilograms per cubic meter. The density of metal can vary depending on the type of metal, but it generally ranges from 7 to 19 g/cm3 and can be calculated by dividing its mass by its volume. A density of 210g/180g/120g means that for every 210 grams of the metal, there is a volume of 180 grams of the metal, resulting in a density of 1.17 g/cm3. The density of metal can affect its properties, such as strength, durability, malleability, weight, buoyancy, and conductivity. It
Prasad Nemade
a sample of metal weighs 210 g in air, 180 g in water and 120 g in an unknown liquid. then the density of metal is.
...is bound to remain a mystery unless you follow the posting template and describe your own attempt at a solution...
What is density?
Density is a measurement of how much mass is contained within a specific volume of a substance. It is typically expressed in grams per cubic centimeter (g/cm3) or kilograms per cubic meter (kg/m3).
What is the density of metal?
The density of metal can vary depending on the type of metal, but it generally ranges from 7 to 19 g/cm3. The specific density of metal can be calculated by dividing its mass by its volume.
What does a density of 210g/180g/120g mean?
This means that for every 210 grams of the metal, there is a volume of 180 grams of the metal, which results in a density of 1.17 g/cm3. This is a measure of the metal's density and does not necessarily represent its actual density, as it may vary depending on the specific metal being referenced.
How does the density of metal affect its properties?
The density of metal can affect its properties in various ways. For example, a higher density metal may be stronger and more durable, while a lower density metal may be more malleable and easier to shape. Density can also affect the weight and buoyancy of a metal, as well as its ability to conduct heat and electricity.
Why is it important to know the density of metal?
Knowing the density of metal is important for a variety of reasons. It can help determine the type and quality of a metal, as well as its potential uses and applications. Density is also a crucial factor in engineering and manufacturing processes, as it can affect the strength and stability of structures and products.
