Dependent motion between 2 bodies to find velocity
In summary, The system is released from rest, and determine the speeds of both masses after B has moved 1m. Neglect friction and the masses of the pulleys. The Attempt at a Solution I have drawn up the free body diagram for both blocks, as well as labelled the lengths Sa and Sb relative to their respective datum points/lines. I obtain the equation 3Sa + 2Sb = L* where L* is the length of rope that is constant.This leads to the velocity and acceleration equations: 3Va = -2Vb and 3Aa = -2Va. My question is where do I go from here? Do I do Newtons second
t_n_p
595
If the system is released from rest, determine the speeds of both masses after B has moved 1m. Neglect friction and the masses of the pulleys.
http://img14.imageshack.us/img14/6321/fbd.jpg
this leads to the velocity and acceleration equations:
Do I do Newtons second law, sum of forces = ma?
This only gives me acceleration in terms of tension T
First of all you have to find the tension in the rope.
Since rope is single, acceleration of both the masses must proportional to the change in the lengths. .
Calculate the accelerations of the both the masses and equate them. That gives you the tension. If the know the acceleration of either mass, using kinematic equation, you can find the the velocity.
rl.bhat said:
Since rope is single, acceleration of both the masses must be the same.
I have seen other examples with 2 hanging blocks suspended by a pulley system where there was only one rope and acceleration of the two blocks was different.
Additionally, what is the point of the acceleration equation 3Aa = -2Va, if it is contrary to what you say?
OK. I have edited the previous post. When B moves 1 m downward how much A moves upward?
Firstly, I would be inclinded (pardon the pun) to say block A moves downward and block B moves upwards.
Secondly, I am not 100% sure mathematically how to determine how far A would move when B moves 1m. I am tempted to say 1.5m due to their being 3*Sa and 2*Sb
OK. Now find acceleration of A and B and equate them in the ratio 2Aa = 3Bb
Take the acceleration positive in both cases i.e in the direction of increasing velocity.
Ok, If B moves 1m up, Sb will shorten by 2m.
Hence Sa will be 2/3m as sort of suggested by the displacement equation.
Mathematically, how do we come to this conclusion from: 3Sa + 2Sb = L*
=> 3Sa = L* - 2Sb
=> Sa = (L* - 2Sb)/3
What does this mean physically?
It means that if B moves x m, A moves 2/3 x m. Since they take same time for the displacement Bv =2/3Av and Ba = 2/3 Aa
It means that if B moves x m, A moves 2/3 x m. Since the take same time for the displacement Bv =2/3Av and Ba = 2/3 Aa
I could understand that if the displacement equation was Sa = 2Sb/3
I am confused due to the constant length L*
Sa = (L* - 2Sb)/3
Sa = L*/3 - 2Sb/3
Doesn't the L*/3 also affect the length of Sa?
Total length L = 2Sb + 3Sa.
Take time derivative on both side. Note that L is constant. That gives you the velocity of A and B. Again take the time derivative of velocities. That gives you the accelerations of A and B.
Ok, I found
Aa = -1.099 m/s^2
Ab = 1.649 m/s^2
I know acceleration and initial velocity and I want final velocity when B has moved 1m.
I want to use Vf^2 = Vi^2 + 2as, but acceleration isn't constant because it starts from rest?
When you drop any object from a height, it also starts from rest. Still it has a constant acceleration. Similarly here also the initial velocity is zero and acceleration is constant.
how do I prove/show that acceleration is constant?
The movements of A and B are caused by the gravitational forces on them.
When an objects slides on an inclined plane, its acceleration decreases but it remains constant.
don't you mean it constantly increases since it starts from rest?
No. The velocity increases.
When we write v = u + at, a remains constant.
When one mass is pulling other, both must have the same acceleration.
Ok, now that I have established acceleration is constant, I am able to use Vf^2 = Vi^2 + 2as.
However, since my acceleration of block a is negative, I run into a problem with taking square root of a negative. Have I done somthing wrong?
Negative or positive sign indicates the direction of the acceleration. You have to find the magnitude of the acceleration. For that take the positive value.
cool.
I figured out V of block b = 1.82m/s (upwards) and V of block a = 1.21m/s (down the incline)
These answers seem reasonable to me, I am confident they are correct.
Thanks for the help
1. What is dependent motion between 2 bodies?
Dependent motion between 2 bodies refers to the relationship between the movement of two objects that are connected or dependent on each other. This means that the motion of one object will directly affect the motion of the other object.
2. How is velocity calculated in dependent motion between 2 bodies?
The velocity of the two bodies can be calculated using the formula v = v0 + at, where v is the final velocity, v0 is the initial velocity, a is the acceleration, and t is the time. This formula takes into account the motion of both bodies and their acceleration due to their connection.
3. What is the difference between dependent and independent motion?
Dependent motion refers to the relationship between two objects that are connected, while independent motion refers to the movement of one object without any external influences. In dependent motion, the motion of one object depends on the motion of another, while in independent motion, the motion of one object is not affected by any other objects.
4. How does the mass of each body affect the velocity in dependent motion?
The mass of each body does not directly affect the velocity in dependent motion. However, the mass of each body will affect the acceleration of the system, which in turn will affect the velocity. A heavier object will have a greater influence on the motion of the system compared to a lighter object.
5. Can dependent motion occur in non-linear systems?
Yes, dependent motion can occur in non-linear systems. In these cases, the relationship between the two bodies may not follow a straight line or constant acceleration, but the motion of one body will still be dependent on the motion of the other.
