- #36
strangerep
- 2,170
Partly, yes.CAF123 said:Is there a reason why the state vectors in two dimensional space do not transform under the group of 2D real matrices SL(2,R)? (..or is that what you are getting me to see below?)
(I presume you meant "...same as for su(2,C) up to a sign...".)SU(2) is locally isomorphic to SO(3) which means it shares the same Lie algebra as SO(3), satisfying commutation relations ##[T_a, T_b] = i\epsilon_{abc}T_c##. In two dimensions, suitable representations of the generators are ##T_a = 1/2 \sigma_a## where ##\sigma_a## are the Pauli matrices.
For ##SO(2,R)##, the generator would be the 2x2 rotation matrix. For SL(2,R), from this document, it appears the Lie algebra is the same up to a sign in the last commutation relation.http://infohost.nmt.edu/~iavramid/notes/sl2c.pdf
OK, so when you asked earlier about a Pauli matrix that turned up in something you were doing, herein lies the reason: when you're working in 2D, the Pauli matrices are always floating around somewhere. Depending on whether you multiply (some of) them by ##i##, you get different algebras. So you need to be clear up front about which group is applicable to the scenario you're considering.
The important insight is that the state vectors are only of secondary importance. What matters most is the dynamical group one is trying to represent as Hilbert space operators. E.g., many physical scenarios involve the rotation group, and some involve ##SL(2,R)##, not to mention various other stuff.
So... first one must determine the dynamical group applicable to a physical scenario, then find all the unitary irreducible representations thereof (along the lines of what Ballentine does in sect 7.1 for the rotation group). The structure of the group's spectrum (Casimir values, and other eigenvalues) determines the dimension and structure of the Hilbert space(s) suitable for modelling that scenario.
