Homework Help: Derivative at 0 problem
  1. Oct 28, 2013 #1
    f(x) = |x| + x
    Does f'(0) exist? Does f'(x) exist for values of x other than 0?
    This is from lang's a first course in calculus page 54 # 13
    2. Relevant equations
    lim (f(x+h) - f(x))/h
    h->0
    3. The attempt at a solution
    So I'm not sure if I am doing this correctly
    at first I took the derivative of f(x) = |x| + x
    f(x) = |x| + x = √x^2 + x
    from there
    f'= lim h -> 0 (√(x+h)^2 + (x+h) - (√x^2 + x))/h
    = x + h +x + h - x - x / h
    = 2h/h
    =2
    I assumed this meant that f' = 2 but this doesn't make sense because there is no slope at x = 0
    so I decided to take the right and left derivatives
    right:
    for x > 0, h>0
    |x| = x
    f'= (|x+h| + (x + h) - (|x| + x))/h = ((x+h) + (x + h) - ( x + x )) / h = 2
    left:
    for x < 0 , h < 0
    |x| = -x
    f' = (-(x+h) + (x + h) - (-x +x ))/h = -1
    so my conclusion is that there is no derivative at x = 0 because the left and right derivatives do not equal.
    I am not very confident in what I did here. If someone can help me understand it better I would really appreciate it!
  3. Oct 28, 2013 #2
    UltrafastPED
    |x| does not have a derivative at zero due to the sharp point of the "V".
  4. Oct 28, 2013 #3
    So how do I show that mathematically?
    I understand that geometrically, but when I do problems like these I have a tough time doing it
  5. Oct 28, 2013 #4
    also when I graph it out it only shows the right side / instead of V
    I don't understand how I got the left derivative as -1 when there's nothing on the left
  6. Oct 28, 2013 #5
    Mark44
    Staff: Mentor
    Typo - should be f(x) = |x| + x.
    You need more parentheses, as in (f(x + h) - f(x))/h
    √(x + h)2 ≠ x + h. Think about the case when x + h < 0.
    Your conclusion is correct, but there's an error in your work. If you sketch a graph of y = |x| + x for x < 0, it should be clear that the slope is 0, not -1
  7. Oct 28, 2013 #6
    shouldn't f'(0) = 0 or undefined or dne since there is no derivative at 0?
  8. Oct 28, 2013 #7
    Mark44
    Staff: Mentor
    Since the derivative doesn't exist for x = 0, the f' is not defined at 0.
  9. Oct 28, 2013 #8
    UltrafastPED
    For x > 0 |x| = x; so the slope for x>0 is 1.
    For x < 0 |x| = -x; and the slope for x<0 is -1.
    These are constants, so the limit from the left (x<0) at x=0 is -1. From the right (x>0) it is +1.
    So the left and right derivatives are not the same ... this is due to the kink at x=0.
    So for the expression g(x) = -|x| + x you get g(x) = 0 for x>= 0, and g(x) = 2x for x < 0;
    so now the slope is +2 for x<0, but it is 0 for x>0.
  10. Oct 28, 2013 #9
    Mark44
    Staff: Mentor
    The OP went back and fixed his first post. It should have been f(x) = |x| + x.
    For x > 0, f'(x) = 2; for x < 0, f'(x) = 0.
  11. Oct 28, 2013 #10
    Thanks for the replies! I fixed up the errors in my thread and added parentheses.
    so I re-did the left for x<0
    I got
    f' = (-(x+h) + (x+h) - (-x+x))/h = (-x - h + x + h + x - x)/h = 2x/h but taking the limit as h->0 it is undefined
    is it an algebraic error I am making?
  12. Oct 28, 2013 #11
    Yeah sorry for the confusion
  13. Oct 28, 2013 #12
    Mark44
    Staff: Mentor
    The numerator isn't 2x. Check your algebra.
    Yes
  14. Oct 28, 2013 #13
    sorry
    f' = (-(x+h) + (x+h) - (-x+x))/h = (-x - h + x + h + x - x)/h = 0/h not 2x/h
  15. Oct 28, 2013 #14
    Mark44
    Staff: Mentor
    Right. And in the limit, even though h → 0-, for each value of h that isn't zero, the quotient is zero, hence the limit is zero as well.
    So as you found, if x > 0, f'(x) = 2, and if x < 0, f'(x) = 0. At x = 0, f' doesn't exist.
  16. Oct 28, 2013 #15
    I completely understand now! thank you so much for your help and clarity, I appreciate it!
  17. Oct 29, 2013 #16
    Ray Vickson
    You have already done it: you showed that the left- and right-derivatives are unequal, so there cannot be a limit of [f(h) - f(0)]/h as h → 0.
    Note that h → 0 means that h is allowed to have either sign, as long as its magnitude goes to 0. If we want to specify a direction of approach to 0 we must write either h → 0+ or h → 0-.
Have something to add?
Draft saved Draft deleted
