Derivative help
  • Thread starter ussjt
If https://webwork2.math.ohio-state.edu/courses/math151wi06sm/tmp/png/Hmwk3/391484/kopko.4-prob17image1.png [Broken] , find [PLAIN]https://webwork2.math.ohio-state.edu/courses/math151wi06sm/tmp/png/Hmwk3/391484/kopko.4-prob17image2.png [Broken] [Broken]using the definition of derivative. [PLAIN]https://webwork2.math.ohio-state.edu/courses/math151wi06sm/tmp/png/Hmwk3/391484/kopko.4-prob17image2.png [Broken] [Broken] is the limit as https://webwork2.math.ohio-state.edu/courses/math151wi06sm/tmp/png/Hmwk3/391484/kopko.4-prob17image4.png [Broken] of the expression (answer)
I need help with finding the expression.
The value of the limit is 0.
Any help would be great.
Hurkyl
Staff Emeritus
What have you done?
VietDao29
1,415
f'(x0) is defined to be
[tex]f'(x_0) = \lim_{h \rightarrow 0} \frac{f(x_0 + h) - f(x_0)}{h}[/tex]
Apply that to your function:
[tex]f'(9) = \lim_{h \rightarrow 0} \frac{f(9 + h) - f(9)}{h}[/tex]. Now, how can you do this limit?
41
I am just confused with the 1/2^.5 part.
I am used to seeing something like f(x)= 1/x....so that you make it 1/(9+h).
VietDao29
1,415
[tex]f(x) := \frac{1}{\sqrt{2}}[/tex] means that this function is a constant and does not depend on what x you choose.
It will return the same value (i.e, 1 / (2.5)), no matter what x is. For example:
If [tex]g(x) := \frac{1}{\sqrt{3}}[/tex], then:
[tex]g(0) = \frac{1}{\sqrt{3}}[/tex],
[tex]g(7) = \frac{1}{\sqrt{3}}[/tex],
[tex]g(9) = \frac{1}{\sqrt{3}}[/tex],...
Do you understand? Can you solve the problem now?
786
And if the limit definition doesn't click, look at it graphically. A constant function is just a horizontal line, which obviously has a slope of 0.
41
I have looked at it graphically, but I having a hard time understanding how to make it into an expression...lim h->0 something.
thanks for all of the input, but I am still confused.
786
Ok. VietDao29 showed you the limit definition of a derivative. It's the following...
[tex]f'(x)=\lim_{h\rightarrow{0}} \frac{f(x+h)-f(x)}{h}[/tex]
Your function is [tex]\frac{1}{\sqrt{2}}[/tex], so I'll start you out.
[tex]f'(9)=\lim_{h\rightarrow{0}} \frac{f(9+h)-f(9)}{h}[/tex]
This is still from VietDao29's post.
What is f(9)? What is f(0)? What is f of anything? If you can answer that, you can do your limit.
VietDao29
1,415
Another hint is that:
[tex]\frac{f(9 + h) - f(9)}{h} = \frac{\frac{1}{\sqrt 2} - \frac{1}{\sqrt 2}}{h} = 0, \ \forall h \neq 0[/tex]
What does the above expression tell you?
41
thanks, I got it now. Thanks a lot!
Want to reply to this thread?
"Derivative help" You must log in or register to reply here.
Physics Forums Values
We Value Quality
• Topics based on mainstream science
• Proper English grammar and spelling
We Value Civility
• Positive and compassionate attitudes
• Patience while debating
We Value Productivity
• Disciplined to remain on-topic
• Recognition of own weaknesses
• Solo and co-op problem solving
Top Threads
