Derivative of an Expectation value/Ehrenfest theorem
In summary, the expectation value of the time derivative of x^2 for a three-dimensional wave packet can be evaluated using the Ehrenfest theorem. By taking into account the time dependence of the wavefunction, we can eliminate the extra term (ihbar/m) and obtain the correct result as (1/m)(<x(p_x)> + <(p_x)x>).
OGrowli
Show that (d/dt)<x^2>=(1/m)(<x(p_x)>+<(p_x)x>)
For a three dimensional wave packet
1. <O>=Int_v(d^3r)(psi*Opsi), where O is some operator
Ehrenfest Theorem:
2. ihbar(d/dt)<O>=<[O,H]>+<(partial)(d/dt)O>, H is a hamiltonian.
I evaluted (d/dt)<x^2> using both number one and 2. With each I come to the expression:
(-ihbar/2m)int_v(d^3r)[psi*[del^2(x^2psi)-(x^2)(del^2(psi))], let psi'=(partial)(d/dx)psi
=(-ihbar/2m)int_v(d^3r)[psi*[(partial)(d/dx)[2xpsi+x^2psi']-x^2psi'']],the y and z parts of the laplacian in the first term cancel with those of the second.
=(-ihbar/2m)int_v(d^3r)[psi*(2psi+2xpsi'+2xpsi'+x^2psi''-x^2psi'')]
take the 2 out, bring the -ihbar in and you have
=(1/m)int_v(d^3r)[psi*(-ihbar)psi+psi*x(-ihbar(partial)(d/dx))psi+
psi*(-ihbar(partial)(d/dx))xpsi
=(1/m)(<x(p_x)>+<(p_x)x>)-(ihbar/m)
My question is, what does this extra term mean? how do I get rid of it? Is is a result of error on my part? I assumed that <(partial)(d/dt)(x^2)>=0 since there was no term to account for this in the integral method. Thanks a lot for your help.
Your solution is correct up to the point where you have the term (ihbar/m). This term arises because you have not taken into account the time dependence of the wavefunction. The expectation value <x^2> is a function of time, so when you take the time derivative, you need to use the chain rule to account for the time dependence of the wavefunction.
To get rid of this extra term, you can use the Ehrenfest theorem (equation 2) to evaluate the time derivative of <x^2>. This theorem states that the time derivative of the expectation value of an operator is equal to the expectation value of the commutator of that operator with the Hamiltonian, plus the expectation value of the partial time derivative of the operator. In this case, the operator is x^2, so we have:
(d/dt)<x^2> = <[x^2,H]> + <(partial)(d/dt)x^2>
The commutator [x^2,H] can be evaluated using the commutation relations for position and momentum operators. After some algebra, you should get:
[x^2,H] = 2ihbarx(p_x) + 2ihbar(p_x)x
Substituting this into the above equation and using the fact that the expectation value of the Hamiltonian is <H> = <E>, we get:
(d/dt)<x^2> = 2ihbar<x(p_x)> + 2ihbar<(p_x)x> + (partial)(d/dt)<x^2>
Rearranging this equation, we get:
(d/dt)<x^2> = (1/m)(<x(p_x)> + <(p_x)x>)
And this is the desired result. So, to summarize, the extra term (ihbar/m) in your solution arises because you have not taken into account the time dependence of the wavefunction. By using the Ehrenfest theorem, we can properly account for this time dependence and get the correct result.
FAQ: Derivative of an Expectation value/Ehrenfest theorem
1. What is the Ehrenfest theorem?
The Ehrenfest theorem is a mathematical theorem that relates the time evolution of a quantum mechanical expectation value to the classical equations of motion. It states that the time derivative of an expectation value of an observable is equal to the expectation value of the commutator between the observable and the Hamiltonian operator.
2. What is the significance of the Ehrenfest theorem?
The Ehrenfest theorem allows us to understand the behavior of quantum mechanical systems in terms of classical mechanics. It also helps us to connect the classical and quantum descriptions of a system and provides a way to study the dynamics of quantum systems without solving the Schrödinger equation.
3. How is the Ehrenfest theorem derived?
The Ehrenfest theorem is derived using the Heisenberg equation of motion, which describes how operators evolve in time. By taking the time derivative of an expectation value and using the Heisenberg equation, we can derive the Ehrenfest theorem.
4. Can the Ehrenfest theorem be extended to non-commuting observables?
Yes, the Ehrenfest theorem can be extended to non-commuting observables by using the generalized commutator, also known as the Poisson bracket. However, in this case, the time derivative of the expectation value will also depend on the commutator between the two observables.
5. How is the Ehrenfest theorem used in practical applications?
The Ehrenfest theorem is used in various practical applications, such as in the study of molecular dynamics, quantum transport, and quantum control. It allows us to model the behavior of quantum systems using classical equations of motion, making it a useful tool for understanding and predicting the behavior of complex quantum systems.
