Derivative of an integral help
In summary, the conversation discusses the use of the Euler Lagrange equation to solve the problem of motion of a simple pendulum under a gravitational field. The focus is on finding the partial derivative of the Lagrangian with respect to the angular velocity, which is needed to solve the equation. The conversation also highlights the difference between the partial derivative and the total derivative in physics.
Andreas C
197
OK, I lied a bit. It's not JUST the derivative of an integral. It's the derivative of a cosine of an integral. Solving the problem of the motion of a simple pendulum under a gravitational field using the lagrangian, I came into this mess (which I don't know if it's right):
l^2*((dθ/dt)/dt)-mg*d(cosθ)/(dθ/dt)=dL/dθ
The part I want to focus on is d(cosθ)/(dθ/dt). I know d(cosθ) is not a constant, because it depends on dθ/dt, since it's its integral with respect to dt, but how do I find what it is?
Why don't you show us the full problem statement and the way you found this 'mess'
OK, I will, I just have to mention that I meant d(cosθ)/d(dθ/dt), not d(cosθ)/(dθ/dt), that wouldn't make sense anyway.
Yes. And then it still doesn't make sense: you also have to mention the same thing for the lefthand side: not (dθ/dt)/dt but d(dθ/dt)/dt :smile:.
Furthermore -- and this is rather important -- you don't really mean d(cosθ)/(dθ/dt) ##\qquad## (or rather $$ {d\cos\theta \over {d{d\theta\over dt} }} $$ but instead you mean $$
{\partial \cos\theta \over {\partial {d\theta\over dt} } }$$ The ##\partial## derivative is different from the ##d## derivative (I think it's called the total derivative). Look it up - it appears a lot more in physics. The Euler Lagrange equation is a partial differential equation.
Meaning you consider ##\mathcal{L}## as a function of independent variables ##q## and ##\dot q## and take partial derivatives (differentiate to the one while keeping the other constant):$$
{ \partial \mathcal{L} \over \partial q} - {d\over dt}\left (\partial L\over\partial \dot q \right ) = 0
$$And what do you get when you do a partial differentiation wrt ##\dot \theta## of your $$\mathcal L = {m\over 2} \left (\ell\dot\theta\right)^2 - mg\ell\left (1-\cos\theta\right ) \ \ \rm ? $$
Likes Andreas C
That is actually exactly what I meant. That symbol is called the partial derivative, but I didn't know how to insert it, and I thought it would be the same, thanks :) I'm going to work it out.
Hint: shouldn't take long !
I'm going to do it when I'm back home, I am on my phone now!
I got (m*l^2*(dθ/dt))/2, is that right?
Edit: for ∂L/∂θ I got -mgl*sinθ, should I worry about the minus sign? Don't worry, it's not for homework, I'm teaching myself classical mechanics.
Likes BvU
no, you still want to differentiate it !
The hint was a nudge to make you see (which you did) that ##\cos\theta## is not a function of ##\dot\theta## so the partial derivative of ##V## wrt ##\dot\theta## is zero.
Yes you should. It's the difference beteween a stable equilibrium at ##\theta = 0## and an unstable one.
Kudos! Not an easy subject all on your own. Good thing there is PF :smile:!
Ηmmm... I'm a bit confused now... Are you saying I have to differentiate (m*l^2*(dθ/dt))/2 again?
BvU said:
Yes you should.
So I should have a plus sign instead of a minus one?
Ok, I think I found the mistake, I forgot to cancel out the *1/2 with the *2, so in the case of ∂L/∂(dθ/dt) it's just ((m*l^2)/2)*(∂(dθ/dt)^2/∂(dθ/dt)), right? Well, (∂(dθ/dt)^2/∂(dθ/dt))=2*(dθ/dt), so ((m*l^2)/2)*((dθ/dt)^2/(dθ/dt))=m*l^2*(dθ/dt). That's correct, isn't it?
Not 'again'. m*l^2*(dθ/dt))/2 is the kinetic energy T in ##\mathcal L = T - V\ ##. You haven't differentiated it yet.
[edit] My mistake, I misread the /2 for ^2. Anyway, you found it and fixed it.
Certainly not. You got a minus sign for ##{d\mathcal L\over d\theta}## and you want to keep it. The Euler Lagrange equation is $${ \partial \mathcal{L} \over \partial q} - {d\over dt}\left (\partial L\over\partial \dot q \right ) = 0$$ and if you do it right you automatically end up with ##\ddot \theta + \omega^2 \sin\theta = 0##.
(or, of course ##- \omega^2 \sin\theta - \ddot \theta = 0## :smile: ) .
Likes Andreas C
Ok, I think I've got it: ##\ddot \theta##=-mgl*sinθ. Is that what you mean?
Yes! Well done.
(you lost a factor ml2 on the left, however...)
Likes Andreas C
BvU said:
Yes! Well done.
Hmmm... ∂L/∂θ=∂V/∂θ=mgl*(∂(1-cosθ)/∂θ)=-mgl*sinθ, where does l^2 come from?
Ooooh, I just realized what you meant! Well, since it was ##ml^2 \ddot θ =-mgl*sinθ##, l^2 cancels out with l, and we're left with just l.
Oh my god, what a tangle I have gotten myself into! Well, it's the first problem I solve using the lagrangian, so I guess it is to be expected...
If my calculations are correct, then ##ml^2 \ddot θ =-mgl*sinθ##, which means that ##\ddot θ = -(g*sinθ)/l##, which doesn't sound right at all...
Actually, I looked it up and it IS correct! Yay! Thanks a lot for your patience, you were very helpful! However, there's one thing I don't understand: how does g/l become ω^2?
For a harmonic oscillator (pendulum with small amplitude, ##\ \theta\approx \sin\theta\ ##) the equation is ##\ddot\theta + \omega^2\theta=0\ ## with solution ##\theta = a \sin\omega t + b\cos\omega t##.
The period is ##T = {2\pi\over \omega} = 2\pi\sqrt{\ell/g}##.
Likes Andreas C
Ah, ok, so it's a special case. However, the equation of motion I found here is for any amplitude, right?
Also, say I now want to find the x and y components of acceleration and velocity. How do I do that? I had a couple of ideas but I'm not sure if they are going to be fruitful...
the equation of motion is a second order differential equation. A solution needs two boundary conditions, e.g. an amplitude and a phase (or the a and b in the expression above).
For that you need to express x and y in ##\theta## ; rather straightforward !
So I have to know the initial θ in the case of a pendulum starting from a stationary position, because that would be the amplitude. What about the phase?
Also, what do you mean by "For that you need to express x and y in ##\theta## ; rather straightforward !"?
Does that mean that ##\ddot x = l*sin\ddotθ##?
Never done a mass and spring oscillator before ?
##\ \ddot\theta = -\omega^2\theta\ ## with ##\ \theta(0) = \theta_0\ ## and ##\ \dot \theta(0) = 0\ ## gives ##\ \theta(t) = \theta_0\cos(\omega t) = \theta_0\sin(\omega t + {\pi\over 2})##
Andreas C said:
Does that mean that ##\ddot x = l*\sin\ddot\theta \rm ?##
As long as ##\sin\theta\approx\theta## you have ##x=\ell\theta## so ##\dot x = \ell\dot\theta## and ##\ddot x = \ell\ddot\theta## etc. With ##x=\ell\sin\theta## things get more complicated (http://web.mit.edu/8.01t/www/materials/modules/chapter24.pdf).
Yeah, but that would be the phase for sinθ approaching θ, and I'm looking to find the equations for any amplitude, not just very small ones... It also bugs me how for some reason, the angular acceleration always turns out to be negative, shouldn't it be positive when the angular speed is increasing, like after it reaches the maximum height?
Well, what of the link? There are more of those (google mathematical pendulum, physical pendulum or just pendulum). If you just want the equations: yoeru can differentiate ##\ x =\ell\sin\theta\ ## yourself, I expect ? Is there a specific question ?
Where did you get that idea ? The minus sign only indicates the restoring force (and hence the acceleration) is opposite to the deviation from equilibrium ! If the deviation is negative, the acceleration is positive.
A thorough understanding of harmonic oscillators is very important for many areas of physics. If you have energy left over, studying things like damping is more useful than studying the implications of ##\ \sin\theta\ ##not ## \ \approx\theta\ ## (my opinion).
Likes Andreas C
BvU said:
Well, what of the link? There are more of those (google mathematical pendulum, physical pendulum or just pendulum). If you just want the equations: yoeru can differentiate x=ℓsinθ x=ℓsin⁡θ \ x =\ell\sin\theta\ yourself, I expect ? Is there a specific question ?
Oh, so I have to do the differentiation all over again... Ok, I thought there would be a more immediate way to do it, but yeah, I can differentiate that... Not that it's easy...
Would there ever be a negative deviation? Anyway, I think I got it: It IS always negative, and that is to be expected, why? Because there are two cases: when the pendulum is "falling" (1), and when it is "climbing" back to its maximum height (2). In case (1), we've got an increasing negative angular velocity (the angle is decreasing at an increasing rate), so the angular acceleration is negative as well. Then, in case (2), we've got a decreasing positive angular velocity (the angle is increasing at a decreasing way), so in both cases, the angular acceleration is negative.
Is this right? Because conceptually, it seems to be right...
BvU said:
A thorough understanding of harmonic oscillators is very important for many areas of physics. If you have energy left over, studying things like damping is more useful than studying the implications of sinθ sin⁡θ \ \sin\theta\ not ≈θ ≈θ \ \approx\theta\ (my opinion).
Oh don't worry, I'm doing that as well! :)
? Try it and post if in doubt.
Yes, half the time ##\theta < 0## (when it is to the left of the vertical :smile:). Perhaps the word 'deviation' can be misleading. Does F = ##-##kx with a mass/spring give you the same difficulties ?
When it's on the left and falling, ##\theta < 0##, ##\dot\theta > 0## and ##\ddot\theta > 0##.
When it's on the right and falling, ##\theta > 0##, ##\dot\theta < 0## and ##\ddot\theta < 0##.
When it's on the right and going up, ##\theta > 0##, ##\dot\theta > 0## and ##\ddot\theta < 0##.
When it's on the leftt and going up, ##\theta < 0##, ##\dot\theta < 0## and ##\ddot\theta > 0##.
All nicely summarized with $$\theta = \cos(\omega t) \\ \dot\theta = -\omega\sin(\omega t) \\ \ddot\theta =-\omega^2\cos(\omega t) = -\omega^2\theta$$
Good ! So, are you currently doing Lagrangian and Hamiltionian mechanics or the more basic conventional mechanics ?
With respect to what do I have to differentiate it? With respect to time, right? But then it's a mess, because θ is a function of time...
BvU said:
Yes, half the time θ<0θ<0\theta < 0 (when it is to the left of the vertical :smile:). Perhaps the word 'deviation' can be misleading. Does F = −−-kx with a mass/spring give you the same difficulties ?
Uh... Not really, it's just that negative angles don't make much sense to me, I prefer to think them as reflex angles, as in this shape: https://www.dropbox.com/s/izc1t8vnidfw5tj/Screen Shot 2016-05-25 at 3.37.26 PM.png?dl=0 (not sure how to import pictures on this site).
Some basic (just filling in the gaps), mostly Lagrangian (just started), and I've read up a couple of concepts of Hamiltonian mechanics.
For Euler-Lagrange you need a continuous coordinate at the equilibrium point.
And for simple physics too: if you let the pendulum go at A', then at A it has ##\dot\theta <0## so it will move into ##\theta < 0##. With your angles you get a very jumpy and weird looking graph of ##\theta(t)## !
Likes Andreas C
Ok, I'll keep it in mind. Now if I want to differentiate ##x=ℓsinθ ## to find the x components of acceleration, with respect to what do I differentiate it? Time right? Well, I will have to find θ as a function of time then, right?
  • #31
Oh, I think I figured it out on my own. I got ##\ddot θ ## in terms of the angular velocity, acceleration, and θ.
1. What is the derivative of an integral?
The derivative of an integral is the original function that was integrated. It represents the rate of change of the original function at a specific point.
2. Why do we need to find the derivative of an integral?
Finding the derivative of an integral helps us to understand the behavior of a function and its rate of change at a specific point. It is also essential in solving optimization problems and finding the area under a curve.
3. How do you find the derivative of an integral?
To find the derivative of an integral, you can use the fundamental theorem of calculus, which states that the derivative of an integral is the original function being integrated. You can also use the chain rule or other derivative rules depending on the complexity of the integral.
4. Can you give an example of finding the derivative of an integral?
Sure, for example, if we have the integral ∫(x^2 + 3x)dx, the derivative would be (x^3/3) + (3x^2/2) + C, where C is the constant of integration.
5. What are some common mistakes to avoid when finding the derivative of an integral?
Some common mistakes to avoid when finding the derivative of an integral include forgetting to add the constant of integration, using the wrong derivative rule, or not simplifying the final answer. It is also crucial to pay attention to the limits of integration when using the fundamental theorem of calculus.
  • Differential Equations
