Derivative of an Integral
In summary: The definite integral can be a function of a different variable, and if you actually tried the problem, you'd see that the definite integral becomes a function of s.
p75213
96
F is an antiderivative of f, so F’=f.
[tex]\begin{array}{l}
\int_{g(x)}^{h(x)} {f(t)\,dt} = F\left( {h\left( x \right)} \right) - F\left( {g\left( x \right)} \right) \\
\frac{d}{{dx}}\int_{g(x)}^{h(x)} {f(t)\,dt} = F'\left( {h\left( x \right)} \right)h'\left( x \right) - F'\left( {g\left( x \right)} \right)g'\left( x \right) \\
\end{array}[/tex]
Can somebody show how to find the derivative of the following integral?
[tex]\frac{d}{{ds}}\int_0^\infty {f\left( t \right){e^{ - st}}dt} [/tex]
Just reverse the order of integration and differentiation. The fundamental theorem doesn't really apply here.
Use integration by parts. Then d/ds every term. Then write the solution as a sum.
I would think the answer is 0, since the definite integral is just a number, and the derivitive of a number if 0.
This isn't true. The definite integral for multivariable functions can be a function of a different variable, and if you actually tried the problem, you'd see that the definite integral becomes a function of s.
Leibniz's Integral rule as shown by Dick does the trick:
[tex]\frac{d}{{ds}}\int_0^\infty {f\left( t \right){e^{ - st}}dt} = \int_0^\infty {\frac{\delta }{{\delta s}}f\left( t \right){e^{ - st}}dt} = \int_0^\infty {f\left( t \right)\left( { - t{e^{ - st}}} \right)dt} = \int_0^\infty { - tf\left( t \right){e^{ - st}}dt} [/tex]
1. What is the derivative of an integral?
The derivative of an integral is the rate of change of the integral with respect to its variable. It represents the slope of the tangent line to the integral curve at a specific point.
2. How is the derivative of an integral calculated?
The derivative of an integral can be calculated using the fundamental theorem of calculus, which states that the derivative of an integral is equal to the integrand evaluated at the upper limit of integration.
3. Can the derivative of an integral be negative?
Yes, the derivative of an integral can be negative. This means that the integral curve is decreasing at that point, indicating a negative rate of change.
4. What is the relationship between the derivative of an integral and the original function?
The derivative of an integral is the inverse operation of integration. This means that the original function can be obtained by integrating the derivative of the integral.
5. Why is the derivative of an integral important in science?
The derivative of an integral is important in science because it helps in understanding the rate of change of a given quantity. It is used to analyze motion, growth, and other physical phenomena in various fields such as physics, engineering, and economics.
