Derivative of e^x = e^x
  • Thread starter MHD93
Hello
As I was trying to figure out why the derivative of e^x = e^x using the derivative definition I faced this limit:
lim (e^x - 1)/x ; x goes to 0
and I need your help, thank you.
Answers and Replies
Have you tried applying L'Hopitals rule?
That should clear things up.
hunt_mat
1,745
Have you tried the power series for exp(x)?
[tex]
e^{x}=1+x+\frac{x^{2}}{2}+\cdots
[/tex]
hunt_mat
1,745
jegues, in order to do that you would have to know the derivative of exp(x) which is what he was trying to calculate in the first place.
#Jegues: I don't know L'Hopitals rule, but thanks for reply
#hunt mat: thank you so much, this made the problem so easy
Mohammad_93, one of the ways the exponential function is defined is by the fact that its derivative of this function is the exponential function itself !
HallsofIvy
41,847
965
For any positive real number, a, the derivative of [itex]a^x[/itex] is given by:
[tex]\lim_{h\to 0}\frac{a^{x+h}- a^x}{h}= \lim_{h\to 0}\frac{a^xa^h- a^x}{h}[/tex]
[tex]= \lim_{h\to 0}a^x\frac{a^h - 1}{h}= a^x\left(\lim_{h\to 0}\frac{a^h- 1}{h}[/tex]
That is, the derivative of [itex]a^x[/itex] is [itex]a^x[/itex] itself times a constant, [itex]C_a[/itex]. (Constant in the sense that it does not depend on x. It does, of course, depend on a.)
It is easy to show that, for a= 2 or a= 2.5, say, that constant is less than 1. it is equally easy to show that for a= 3 or 4, say, the constant is larger than 1. We define "e" to be the number such that
[tex]\lim_{h\to 0}\frac{e^h- 1}{h}= 1[/tex]
Another, in my opinion, simpler way to show that the derivative of [itex]e^x[/itex] is [itex]e^x[/itex] is to first define
[tex]ln(x)= \int_1^x \frac{1}{t}dt[/tex]
It is easy to see that the derivative of ln(x), by the fundamental theorem of calculus, is 1/x. You can also show that it is a 1 to 1 function from the set of positive real numbers to the set of all real numbers and so has an inverse function, exp(x), from the set of real numbers to the set of positive real numbers. One can then show that exp(x) has derivative exp(x) and that [itex]exp(x)= (exp(1))^x[/itex] where exp(1) is defined, of course, by ln(exp(1))= 1.
Let f(x)=e^x
Clearly:
(e^x - 1)/x = (e^x - 1)/(x-0) = ( f(x) - f(0) )/x-0 ----> f'(0) as x--> 0
HallsofIvy
41,847
965
Let f(x)=e^x
Clearly:
Yes, that's true but not relevant to the question of what that derivative is. The last part, (f(x)- f(0))/(x- 0)----> f'(0), is true for any function that is differentiable at x= 0. The question, really, was "How do you show that [itex]lim_{x\to 0} (e^x-1)/x= 1[/itex]".
Char. Limit
You don't even need to define log(x) that way. It's easy to prove that using the basic definition of e, as follows:
[tex]e = lim_{x\rightarrow\infty}\left(1+\frac{1}{x}\right)^x[/tex]
And using the definition of the natural log, again as follows:
[tex]IF x=e^y\\ THEN y = log(x)[/tex]
Then by applying the definition of a derivative, you can prove, algebraically, that the derivative of log(x) is 1/x. Then you can use that to prove the derivative of e^x without ever using an integral or the FTC.
Related Threads on Derivative of e^x = e^x
  • Last Post
9K
  • Last Post
  • Last Post
  • Last Post
  • Last Post
13K
  • Last Post
10K
  • Last Post
  • Last Post
