Derivative problem
  • Thread starter Essnov
Hello - I have been messing around with this problem for a while, please help.
I actually know the solution, but cannot reach it on paper:
Find where the slope of the tangent to the curve e^(-x^2) is equal to 2/e
d/dx e^(-x^2) = e^(-x^2) * d/dx -x^2 = -2xe^(-x^2)
Set: -2xe^(-x^2) = 2/e
e^(-x^2 + 1) = -1/x
(e^(-x^2 + 1))^-1 = (-1/x)^-1
e^(x^2-1) = -x
At this point I can see that the only possible solution is x = -1, yet cannot actually reach that conclusion on paper. It seems like I'm missing something ridiculously simple.
Any help greatly appreciated!
Answers and Replies
AKG
2,565
What do you mean you can't reach that conclusion on paper? Plug in x = -1, show that left sides = right side, then all that remains to show is that there are no more solutions. The function mapping x to ex²-1+x is clearly increasing, so it has at most one root, and you've found it at -1, so you're done.
I mean that I know that the solution is x = -1 because I just happened to notice that it was the solution, not because I solved for x = -1.
Say I'm left with:
e^(x^2-1) = -x
I could easily have no idea what the solution is.
How do I work the equation to show x = -1?
rock.freak667
6,223
31
sub x=1 into the equation and show the left side is equal to the right side
This is a problem that, as far as I know, can't be solved algebraically. You'd have to use analysis as explained above.
HallsofIvy
41,847
966
"Happening to notice" that a specific value satisfies an equation is a perfectly good method! (Provided that you check that it does work.) And a perfectly good method of seeing that x= -1 is the ONLY solution is to graph the functions [tex]y= e^{x^2-1}[/tex] and [tex] y= -x[/tex].
Related Threads on Derivative problem
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
