Derivative Problem
  • Thread starter camboguy
find
f'(x)= [(x^2)(x-3)]^(1/3)
i got (3(x-2))/[x(x-3)^(2/3)]
is that correct? im so confused if i got it right or not.
Thanks before hand
Answers and Replies
Not quite. I'd start by making it simpler by multiplying out the polynomials. Then you'd have:
[tex](x^{3}-3x^{2})^{\frac{1}{3}}[/tex]
Then, use the chain rule:
If f(x)=g(h(x)), then f ' (x) = g ' (f(x))*f ' (x).
For example, look at f(x) = (sin(x))2.
So if g(x) = x2, and h(x) = sin(x), then f(x)=g(h(x)). Then to take the derivative, first, find the derivative of g and h.
So g(x)=x2, which means that g ' (x)=2x.
h(x) = sin(x), which means that h ' (x)= cos(x).
Then to take the derivative, you would remember that f ' (x) = g ' (f(x))*f ' (x). So first, look at g ' (x). That's 2x. So put f(x) in for x, to get 2(sin(x)). Then, multiply by f ' (x), which is cos(x).
So f ' (x), in this example, is 2(sin(x))*cos(x).
Now, use that same method for your problem.
This is an application of the chain rule.. You can multiply the inner product and get...[x^3-3x^2]
... now you bring the 1/3 out in front and reduce it by 1 as by application of the derivative. 1/3-1/1 = -2/3
So you get what 1/3[d/dx[x^3-3x^2]]^-2/3
so then it's: 1/3[x^2*(x-3)]^(-2/3) * derivative of the inside [3x^2-6x]
Got it?
Mentallic
3,798
94
never mind -.-
7,271
find
If you're trying to find f'(x), look no further than the equation you wrote.
I'm being facetious here. What you most likely meant was:
f(x)= [(x^2)(x-3)]^(1/3)
Find f'(x).
This might seem like a small difference, but it's important to keep a function and its derivatives clearly separated in your mind.
Thanks before hand
Related Threads on Derivative Problem
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
