Solving: Finding $\frac{dT}{dt}$ for a Swimming Duck
  • MHB
  • Thread starter mathmari
  • Tags
    Swimming
In summary: No, you don't need to write it that way. You can write it as $T(t)=x^2(t)e^{y(t)}-x(t)y^3(t)$, where $y(t)$ is a function of $t$.
mathmari
MHB
5,049
Hey! :eek:
Suppose that a duck swims in a circle $x=\cos t$, $y=\sin t$ and that the temperature of the water is given from the formula $T=x^2e^y-xy^3$. Find $\frac{dT}{dt}$:
  1. using the chain rule
  2. expressing $T$ as a function of $t$ and differentiating
  1. At the chain rule do we not have $\frac{\partial}{\partial{t}}$ ?? Why are we looking for $\frac{dT}{dt}$ ?? (Wondering)
  2. $$T(t)=x^2(t)e^{y(t)}-x(t)y^3(t)=\cos^2 t e^{\sin t}-\cos t \sin^3 t$$
    $$\frac{dT}{dt}=2 \cos t (-\sin t)e^{\sin t}+\cos^2 te^{\sin t} (\cos t)-(-\sin t)\sin^3 t-\cos t 3 \sin^2 t (\cos t)= -2 \cos t \sin t e^{\sin t}+\cos^3 t e^{\sin t}+\sin^4 t -3 \cos^2 t \sin^2 t$$
    Is this correct?? (Wondering) Could I improve somehing?? (Wondering)
For part 1, I would begin with:
\(\displaystyle T=x^2e^y-xy^3\)
Now, differentiating with respect to $t$, we find:
\(\displaystyle \d{T}{t}=x^2e^y\d{y}{t}+2x\d{x}{t}e^y-2xy^2\d{y}{t}-\d{x}{t}y^3\)
\(\displaystyle \d{T}{t}=xe^y\left(x\d{y}{t}+2\d{x}{t}\right)-y^2\left(2x\d{y}{t}+\d{x}{t}y\right)\)
Now, using the following:
\(\displaystyle \d{x}{t}=-y\)
\(\displaystyle \d{y}{t}=x\)
we may write:
\(\displaystyle \d{T}{t}=xe^y\left(x^2-2y\right)-y^2\left(2x^2-y^2\right)\)
See if this matches the result you obtained for part 2. :D
mathmari said:
Hey! :eek:
Suppose that a duck swims in a circle $x=\cos t$, $y=\sin t$ and that the temperature of the water is given from the formula $T=x^2e^y-xy^3$. Find $\frac{dT}{\dt}$:
  • At the chain rule do we not have $\frac{\partial}{\partial{t}}$ ?? Why are we looking for $\frac{dT}{dt}$ ?? (Wondering)
Hi mathmari! (Smile)
The first is a partial derivative, which is used when there are multiple variables, but we differentiate with respect to only one of them.
The second is a total derivative with respect to $t$, meaning that we apply the chain rule for any variable that depends on $t$. Or else that we expand $T$ making all dependencies on $t$ explicit, and differentiating only then.
That means:
$$\pd T x = 2xe^y-y^3$$
$$\pd T t = 0$$
$$\d T t = \pd T t + \pd T x \d x t + \pd T y \d y t$$
You're supposed to evaluate the last expression. (Thinking)
  • $$T(t)=x^2(t)e^{y(t)}-x(t)y^3(t)=\cos^2 t e^{\sin t}-\cos t \sin^3 t$$
Completely correct! (Nod)
This mean that we have $$T(t)=x^2(t)e^{y(t)}-x(t)y^3(t)$$ so $T$ depends only on $t$, right ?? (Wondering)
Or does the way I wrote it mean that we write $T$ as a function of $t$, as we should do at the second part??
You can still go either way. You have only made the dependencies explicit.
That is, you can still first take a partial derivative with respect to x and apply the chain rule.
Or else, you can substitute the expression for x(t) and differentiate then, as you did in the second part. (Wasntme)
So, we have to use the following version of the chain rule:
We suppose that $c: \mathbb{R} \rightarrow \mathbb{R}^3$ and $f: \mathbb{R}^3 \rightarrow \mathbb{R}$. Let $h(t)=f(c(t))=f(x(t),y(t),z(t))$, where $c(t)=(x(t),y(t),z(t))$. Then $$\frac{dh}{dt}=\frac{\partial{f}}{\partial{x}}\frac{dx}{dt}+\frac{\partial{f}}{\partial{y}}\frac{dy}{dt}+\frac{\partial{f}}{\partial{z}}\frac{dz}{dt}$$
right ?? (Wondering) Do I have to write $T$ as a composition of two functions, for example $T(t)=f(c(t))=f(x(t),y(t))=x^2(t)e^{y(t)}-x(t)y^3(t)$, where $c(t)=(x(t),y(t))$ ?? Or isn't it necessary ?? (Wondering)
mathmari said:
So, we have to use he following version of the chain rule:
Yes. (Nod)
I don't think that is necessary. I think you're only supposed to show that you know what you're doing. Getting stuck into cosmetic notational issues isn't part of that. (Wasntme)
So, do we have to write
$$\frac{dT}{dt}=\frac{\partial{T}}{\partial{x}}\frac{dx}{dt}+\frac{\partial{T}}{\partial{y}}\frac{dy}{dt}$$
?? (Wondering)
Or is it a little confusing that we write $T(t)=x^2(t)e^{y(t)}-x(t)y^3(t)$ and then we take $\frac{\partial{T}}{\partial{x}}$ ?? (Wondering)
?? (Wondering)
Yup. (Nod)
That is confusing.
Formally, we can't take $\frac{\partial{T}}{\partial{x}}$ from $T(t)$, because $T(t)$ is not a function of x. (Worried)Actually, we're dealing with 2 distinct functions: $T_1(x,y)$ and $T_2(t)=T_1(x(t),y(t))$.
As you can see, they have different domains.
So we can talk about $\pd {T_1} x$, but not about $\pd {T_2} x$. (Doh)
When writing $\d T t$, this means $T_2'(t)$, which is equal to $\pd {T_1} x x'(t) + \pd {T_1} y y'(t)$ due to the chain rule. In practice these distinctions are often not made: we write $x$ instead of $x(t)$ unless we want to emphasize that $x$ is a function of $t$. And we write $T$ to mean any of $T(x,y)$, $T(t)$, or $T(t,x,y)$. (Malthe)
What is the meaning of $\frac{dT}{dt}$ in relation to a swimming duck?
$\frac{dT}{dt}$ represents the rate of change of temperature over time for a swimming duck. It is a measure of how quickly the duck's body temperature is changing as it swims.
How can $\frac{dT}{dt}$ be calculated for a swimming duck?
To calculate $\frac{dT}{dt}$ for a swimming duck, one must measure the duck's body temperature at different time intervals while it is swimming and then use the change in temperature over time to calculate the rate of change.
What factors can affect $\frac{dT}{dt}$ for a swimming duck?
Some factors that can affect $\frac{dT}{dt}$ for a swimming duck include the water temperature, the duck's physical activity level, and its body composition. These factors can all impact the rate at which the duck's body temperature changes while swimming.
Why is it important to understand $\frac{dT}{dt}$ for a swimming duck?
Understanding $\frac{dT}{dt}$ for a swimming duck can provide insight into the duck's thermoregulation and how it maintains its body temperature while swimming. This information can also be useful for studying the effects of water temperature and physical activity on the duck's body temperature.
Can $\frac{dT}{dt}$ be used to compare different species of swimming ducks?
Yes, $\frac{dT}{dt}$ can be used to compare the thermoregulation abilities of different species of swimming ducks. By measuring and comparing the rate of change of temperature over time for different species, scientists can gain a better understanding of how these ducks adapt to their aquatic environments.
  • Calculus
