How to Derive a Cubic Function with Horizontal Tangents at Given Points?
In summary, we have a cubic equation $y=ax^3+bx^2+cx+d$ with horizontal tangents at the points $(-2,6)$ and $(2,0)$. By using the given information and solving a system of equations, we can find the values of $a$, $b$, and $c$ to be $\frac{3}{16}$, $b$, and $-\frac{9}{4}$, respectively. The value of $d$ is also determined to be $3$. Therefore, the final equation is $y=\frac{3}{16}x^3-\frac{9}{4}x+3$.
karush
MHB
3,269
$$y=ax^3+bx^2+cx+d$$
Find the cubic eq whose graph has horz tangent at the points$ (-2,6)$ and $ (2,0)$
$$y'=3a{x}^{2}+2bx+c$$
(Wave)
We have $y=f(x)=ax^3 + bx^2 + cx + d $ .
We want to find the values of $a, b, c$ and $d$.
We know that $f(-2)=6$, so we have: $-8a + 4b - 2c + d = 6 $.
We also know that $f(2)=0$, so we have: $8a+4b+2c+d=0$.
Since there are horizontal tangents at those two points, we know that the derivative is zero at those points, i.e. $f'(-2)=f'(2)=0$ .
Then you will have 4 equations and you will solve the system.
Isn't $d=3$
Of which we only need a, b, c
karush said:
Isn't $d=3$
Yes, it is $d=3$.
Making operations, we can find for example the equalities $16a+4c=-6$ and $12a+c=0$ and we deduce that $a=\frac{3}{16}$.
Then $c=-\frac{9}{4}$
So we have b left
So then $$f'(-2)=f'(2)=0$$
Is next?
Exactly! (Nod)
karush said:
So we have b left
Is next?
You said previously that $d=3$. Then by adding the equality that we get from $f(2)=6$ with the equality we get from $f(-2)=0$, if we multiply it by $-1$ , we have that $4b+d=3$. So... ?
$$y=\frac{3}{16}{x}^{3}-\frac{9}{4}x+3$$
I hope
I hope
Well done! (Clapping)
1. What is a cubic function?
A cubic function is a mathematical function of the form y = ax^3 + bx^2 + cx + d, where a, b, c, and d are constants and x is the independent variable. It is called a cubic function because the highest degree of the variable x is 3.
2. How do you derive a cubic function?
To derive a cubic function, you must follow the steps of differentiation, where you take the derivative of each term in the function. This involves using the power rule, product rule, and chain rule. The resulting function will be the derivative of the original cubic function.
3. What is the purpose of deriving a cubic function?
The purpose of deriving a cubic function is to find the slope of the function at any given point. This can be useful in calculating maximum and minimum values, finding the rate of change, and solving optimization problems.
4. What are the key features of a cubic function?
The key features of a cubic function include its degree, leading coefficient, axis of symmetry, vertex, and asymptotes. The degree and leading coefficient determine the shape and direction of the function, while the axis of symmetry and vertex indicate the location of the function's maximum or minimum point. Asymptotes are the lines that the function approaches but never touches.
5. Can a cubic function have more than one solution?
Yes, a cubic function can have up to three solutions, depending on the values of its constants and the discriminant. If the discriminant is positive, the function will have three distinct real solutions. If the discriminant is zero, the function will have one real solution. If the discriminant is negative, the function will have three distinct complex solutions.
  • Calculus
