Deriving Formula for m2 in Terms of m1, a, and g in a Two Mass System
  • Thread starter Medgirl314
  • Tags
    deriving
In summary: I completely neglected the diagram when I posted this! I'll go to mobile and attach it and then perhaps this will be easier. I can't read the last LaTex equation, is that on my end or yours?Thanks so much. :smile:SteamKing, I think I see what you mean with the equation. When I typed it I must have done something wrong with LaTex. Thanks!Here we are. Can you see the diagram and the question easily? The problem I'm on right now is the first.
  • #36
4 issues:
1) I didn't see any ms in the problem ...
2) you've mixed cause (m2g) onto the same side of the equation as effect (m1a)
3) doesn't m2 have inertia?
4) I thought you were supposed to solve for a (isolate it on the left)
  • #37
1) Sorry about that, I didn't hit "preview" first. I meant m2.
2) I didn't see a m2a in my equation, could you please point it out?
3) We haven't discussed inertia yet.
4) No, we're solving for m2. Sorry for the confusion!
Thanks!
  • #38
Oops! Sorry, I thought you were writing Newton #2 .
solving for m2 means that you need to isolate m2 ... get both of them together first.
But it looks like you started with the correct Newton#2.
Inertia is from Newton #1: an object will maintain constant velocity due to its inertia (a property of its mass).
This rests on:
* mass is a numerically additive property, so it is a quantity ... Σm = total mass
* relative location x is a measurable property, so displacement is an additive quantity
* the product mx is an additive quantity (called the mass moment) ... Σ(mx) = m_total x_average
I fixrd my typo , but you might need to refresh screen
  • #39
I'm sorry, we are that far. I just had to look back. I just don't understand what you mean by "Doesn't m1 have inertia"? I think I meant that we haven't discussed inertia in a situation similar to this one.
  • #40
I wrote line 3 because there should have been a term "m2 a"
which I didn't recognize had been typo'ed into "ms a", and then split by division.
So, how are you going to isolate m2?
  • #41
Ah, okay. I thought you meant we needed an entire other equation to bring into this equation.
Would the following be a good place to start?
m1+m2=(m2-m1)a
  • #42
After the diagram (displacement and velocity vectors, deduce acceleration vector, and draw Force vectors)
you usually write Newton's 2nd Law.
What is causing the Force?
How much mass is accelerating?
  • #43
The equation in post #41 wasn't actually where I started. I did all the steps you explained, but then I tried to rearrange Newtons 2nd Law to get the above equation. Sorry for the confusion!
  • #44
Didn't the post 36 equation come from writing Newton's 2nd Law?
post 41 is missing gravity, and one of the masses seems to be negative.
  • #45
I haven't seen a new equation since post 36 besides the one in 41. Oops, I didn't notice that I neglected gravity. Can we start over from F=ma ? The next step, after writing F=ma, would be to determine the total mass, correct?
  • #46
yes, ∑F = ∑m a ... generally, both sides are sums (recall helicopter tension).
  • #47
Okay, so would the mass be m1+m2 ?
  • #48
yes. what's the Force?
  • #49
Is it m2g?
  • #50
yes. So Newton#2 is ...
  • #51
m2g=(m1+m2)a ?
  • #52
yes. now, expand the right-hand side, so that you can move the m2 a over to the left side.
  • #53
Sorry, I got tied up with other subjects.
m[itex]_{}2[/itex]g=m[itex]_{}1[/itex]a+m[itex]_{}2[/itex]a
I think I may have used the wrong button.
  • #54
that is to isolate your desired unknown m2 as a ratio
  • #55
Right, but I needed to expand first, so I just wanted to be sure that I didn't make an error. :smile:
m2g-m2a=m1a+m2a-m2a
How does that look so far?
  • #56
now isolate the desired unknown on the left (common factor) ... done.
  • #57
Ah, THIS is where I kept getting stuck last time! Okay, here's what we have:
m2g-m2a=m1a
This is where I haven't but a vague idea of what to do. Can I divide by ag?
Thanks!
  • #58
m2 on the left is a common factor in 2 subtracted terms
... "de-expand" those two, with m2 outside the parenthesis (with things that are subtracted)
  • #59
Right,thanks!
To expand we multiply, so do we divide by m2 here?
  • #60
algebra!
c(d + e) = cd + ce ... it goes both ways ... (left to right is expanding , right to left is collecting a common factor)
  • #61
Oh, I was overcomplicating it again! We're literally just pulling it out of the equation, I let he subscript mess me up.
m2g-m2a=m1a
m2(g-a)=m1a
Better?
  • #62
it is still not isolated (all by itself) ... it is still multiplying that difference ...
  • #63
Oh, right. Shoot. But was the step correct? Can I divide both sides by m2, yielding g-a=m1a/m2 ? Or would that not be considered solving for m2, since it's not on it's own side?
  • #64
collected it as common factor, good.
you want it on TOP, by itself ... not on bottom.
move the other factor, instead of m2 .
  • #65
Oh! Duh! m2=m1a/g-a ?
  • #66
keep the old parentheses, right? ok, done.
move on to the one with friction
  • #67
m2=m1a/(g-a)
Do you mean we're done here?
  • #68
well, look at 2 special cases first:
1) what m2 will make zero acceleration?
2) what m2 will make acceleration = 9.8 m/s² ?
  • #69
Lightgrav, I would really love to come back to these questions, but I have so many other problems this week that I can't justify spending the time on the extra questions that they deserve. Thanks so much for helping me with the problem! :smile: I will eventually come back to these if I have a moment.
