Derive Convolution Expression for Z_PDF(z)
In summary: Yes, that is correct. The PDF formula for the destination RV needs to take into account the probability of each point on the plane (or line) of constant z. And in the case of a n-to-1 transformation, the PDF formula needs to incorporate the probabilities of n source RV values for each destination RV value.
  • #36
Stephen Tashi said:
No. Why do you have a "dz" on the left hand side of the equation?
I thought we were approximating the probability, so that we can then divide by |dz| to get Z_PDF(c)
Stephen Tashi said:
"catheters"? Do you mean "sides" ?
yep.. https://en.wikipedia.org/wiki/Cathetus
"catheters" in plural form from swedish according to google translate :)
  • #37
Yes, but there is nothing on the right hand size of the equation that depends upon "dz". If you divide the right hand size of the equation by "dz" and take the limit of the right hand size as ##dz \rightarrow 0##, you get an infinite result.
Since c is some constant, the integral on the right hand side of the equation (if the integral exists) is some constant.
Is your idea that we can fix the factor of ##\sqrt{2}## by some argument about "dz" being the hypotenuse of an infinitesimal triangle whose sides are "dx" and "dx" ? That's an interesting idea, but I don't see how to formulate it as plausible reasoning.
  • #38
Stephen Tashi said:
Yes, but there is nothing on the right hand size of the equation that depends upon "dz". If you divide the right hand size of the equation by "dz" and take the limit of the right hand size as dz→0dz \rightarrow 0, you get an infinite result.
Best would be to use z instead of c all the way, but I wanted to clarify.
Stephen Tashi said:
Is your idea that we can fix the factor of √2\sqrt{2} by some argument about "dz" being the hypotenuse of an infinitesimal triangle whose sides are "dx" and "dx" ? That's an interesting idea, but I don't see how to formulate it as plausible reasoning.
Something like that. Can we use the "aim-vector" of L for that? so that the rate of growth of t has dx and dy in it
  • #39
L = (x(t), y(t)) = (t*|dy|/sqrt(2), z-t*|dy|/sqrt(2))
x'(t) = |dy|/sqrt(2)
y'(t) = -|dy|/sqrt(2)
Z_PDF(z)*|dz| = integral wrt t from -inf to inf of X_PDF(x(t)) * Y_PDF(y(t)) * sqrt( x'(t)^2 + y'(t)^2 ) * dt
= integral wrt t from -inf to inf of X_PDF(t*|dy|/sqrt(2)) * Y_PDF(z-t*|dy|/sqrt(2)) * |dy| * dt
Make any sense?
  • #40
Z_PDF(z) dz is approximately the integral of the joint density over a thin area bounded by the lines x + y = z + dz and x + y = z - dz. Approximate this integral by dividing the area into parallelograms with vertices ( (k)dx, z+dz), ((k)dx, ,z-dz) , ( (k+1)dx, z-dz) ((k+1)dx, z+dz)). The area of a parallelogram is (dx)(dz). The probability mass in a parallelogram is approximately X_PDF(kdx) Y_PDF(z-kdx) dx dz. This gives an approximation with "dz" on both sides of the equation.
  • #41
Okay, sounds good.. I'll take a closer look when I get some more time. Thanks for now!
  • #42
Hm, a density value of an outcome equals the probability of that outcome per the length/area/volume of that outcome.
I would like to see how the outcome area of P(x<X<x+dx AND z-x<Y<z-x+dy) can be modified into the outcome area of P(z < Z < z+dz), since these should be equal.
Then it's desirable to take the quotient of these areas (even though I think this will be 1?).
When the number of source RV's equal the number of destination RV's, this will become the absolute value of the Jacobian determinant, I think?
I'll try to formulate that, but feel free to help out! :)
  • #43
rabbed said:
I would like to see how the outcome area of P(x<X<x+dx AND z-x<Y<z-x+dy) can be transformed into the outcome area of P(z < Z < z+dz), since these should be equal.
Why should they be equal ? For example, suppose z = 10, dz = 0.01, x = 5, dx = 0.5, dy = 0.25. Then you aren't accounting for cases like x = 9 and y = 1. And cases like x = 5.45, y = 5.20 aren't cases where x + y = z is in (z, z + dz).
  • #44
That would do for a definition of average density. For a probability density function (defined on points in a length, area, or volume) you need a definition for "density at a point", which means you must define it in terms of a limit of average densities.
  • #45
Right, already forgot :) Is it possible to express that as probabilities?
Something like P(OR wrt x from -inf to inf of x<X<x+dx AND z-x<Y<z-x+dy)? :)
Or maybe integral wrt x from -inf to inf of P(x<X<x+dx AND z-x<Y<z-x+dy)
Or integral wrt x from -inf to inf of P(X=x AND Y=z-x)
Also, should dy be expressed wrt x?
  • #46
Express what ? Are you asking for ways to describe the event ##Z :\{ z < Z < z + dz\}## ? If you describe it in terms of variables like x,y,dx,dy, then those variables must have some relation to z and dz.
In the XY-plane the event ##Z :\{ z < Z < z + dz\}## is ## (x,y): \{ z < x + y < z + dz \} ## If you want to write a description that includes "dx" and "dy", you have to specify how they are related to "z" and "dz".
  • #47
Basically, there should be a directional derivative or gradient (dz/dx, dz/dy) when you have many source RV's and one destination RV.
I want Z_PDF(z) to be expressed in terms of the probability of the points on that infinite line, divided by the absolute value of the derivative (length?) of the point where Z=z, like when there is a Jacobian..
Something like:
Z_PDF(z)/|dz| = integral wrt x from -inf to inf of X_PDF(x) / |dz/dx| * Y_PDF(z-x) / |dz/dy| * |dz|
I realize |dz/dx| and |dz/dy| is 1.. so maybe it would be better to try something like Z = 2*X + 3*Y
Maybe it will give a definition of what a determinant looks like for a non-square matrix, because that has no definition now, right? :)
  • #48
For continuous random variables, the probability of each point on the infinite line is zero and the probability that (X,Y) will be some point on the infinite line is also zero. We have to think about probability densities, not probabilities.
The line x + y = z is a level curve of the surface f(x,y) = x + y. The gradient of f(x,y) defines a vector field that is perpendicular to that level curve. If we imagine Z varying from z to z + dz, this corresponds to the level curve x+y = Z sweeping out an area approximated by moving each point (x,y) on the level surface in the direction specified by the gradient.
I don't think you can approximate the area swept out by the level surface only by considering the gradient, because the area swept out depends on the shape of curve. If I imagine the curve approximated by a series of small straight line segments, then the area swept out is approximated by a sum of areas of parallelograms. One side of a parallelogram is a line segment. The adjacent size is a vector defined by the direction of the gradient at one end of the line segment.
Perhaps this topic has been worked out by people who study "level set" methods. https://en.wikipedia.org/wiki/Level_set_method
Or page 449 eq 39 b) of https://books.google.com/books?id=Q...ge&q=area swept out by a moving curve&f=false
  • #49
Crystal clear explanation! Thank you :)
It doesn't seem impossible to do, but I guess if it can/has been solved they would already be teaching it as part of probability theory.
So people get by with only having the n-to-1 and n-to-n dimensional cases or are n-to-m calculations done graphically instead of with a formula?
  • #50
Even the 1-dim to 1-dim case isn't that simple in practice. Things are simple if Y = F(X) is a monotone function of the random variable X, but if it has peaks and valleys, you must consider various cases.
A complication with an n-dimensional function of a random variable (or variables) is that the components of a n-dimensional random vector might be dependent, even if the variables in the domain of the functions are independent. For example if X1,X2,X3 are independent random variables and Y1 = X1 + X3, Y2 = X2 + X3 then the joint density of (Y1,Y2) isn't necessarily given by the product Y1_PDF(y1) Y2_PDF(y2).
  • #51
Hello again, a bit late (as usual after doing some thinking).
Does this make sense?
The line is (x(t), y(t)) = (t, z-t)
Z_PDF(z) = integral wrt t from -inf to inf of X_PDF(x(t)) * Y_PDF(y(t)) * sqrt( x'(t)^2 + y'(t)^2 ) * dt / sqrt(det( [ z'(x(t)) z'(y(t)) ] * [ z'(x(t)) z'(y(t)) ]^T ))
The line integral divided by the square root of the squared determinant of J where J is the gradient [ z'(x(t)) z'(y(t)) ]
(the square root which is also the length element of z divided by the area element of x and y at a point)
It would be nice to convert the line integral into a double integral with dx and dy multiplying area elements into length elements of z, but maybe that's not possible..
  • #52
I don't see any definition for z(t).
Does you forumula work for the case where X and Y are each uniformly distributed on [0,1] ?
  • #53
Right, but z(t) isn't used anywhere. z = f(x,y) = x + y, does it need to be a function of t?
Since both square roots become sqrt(2) we end up with the convolution formula, so it should be ok?
  • #54
By the way,
since (x(t), y(t)) = (t, z-t)
is
equal to
integral wrt x from -inf to inf of X_PDF(x) * Y_PDF(z-x) * sqrt( (dx/dx)^2 + (dy/dx)^2 ) * dx?
In that case:
Z_PDF(z) = integral wrt x from -inf to inf of X_PDF(x) * Y_PDF(z-x) * sqrt( (dx/dx)^2 + (dy/dx)^2 ) * dx / sqrt(det( [ (dz/dx) (dz/dy) ] * [ (dz/dx) (dz/dy) ]^T ))
  • #55
If z is a function of the two variables (x,y) then what do you mean by z' ?
  • #56
depends on what variable it's derivated with respect to
z = x + y
dz/dx = 1 (z'(x) = 1)
dz/dy = 1 (z'(y) = 1)
  • #58
Stephen Tashi said:
You should be using the notation for partial derivatives. (The Insight: https://www.physicsforums.com/insights/partial-differentiation-without-tears/ is relevant to the question "Is z a function of t ?")
Yep, I know the other notation is a bit flawed, but it has it's uses. (but tell me if my logic was wrong somewhere!)
So it this better?
rabbed said:
By the way,
is
equal to
In that case:
  • #59
rabbed said:
So it this better?
The problem is that your notation can't be interpreted. For example, what function is "dy/dx" ?
A mathematical function has a domain and a co-domain. What is the domain of "dy/dx" and what is it's co-domain?
  • #60
Since z = x + y,
y = z - x
and
dy/dx = -1?
  • #61
As far as I can tell, you aren't presenting any logical arguments. You are conjecturing various formulas and asking for criticism of them. That's a permissible approach in the early stages of an investigation, but you should follow-up a conjecture by testing it with some simple examples instead of relying on my comments. it's ok to make conjectures by resorting to "magic" - such as writing down symbols like "dx/dx" without asking what they symbolize. But you should proceed to working specific examples that force you to make specific interpretations. (I'm about to get busy for a few days with the jobs of being executor of an estate, so I'm not going to have time to criticize a hundred different conjectures.) - In fact I just got a phone call and I must leave right now.
  • #62
I think the essence here is that for multiple variables/dimensions we need to use line/surface integrals
and that it starts to make more sense to use the joint PDF of the source RV's.
XY_PDF(x,y)*sqrt(dx^2 + dy^2) = X_PDF(x)*|dx| * Y_PDF(y)*sqrt(1 + (dy/dx)^2)
Hm, maybe regular multidimensional integration comes in when considering inequalities, like Z < X+Y.
I'll keep exploring. Thanks for all help!
<h2>1. What is the purpose of deriving the convolution expression for Z_PDF(z)?</h2><p>The purpose of deriving the convolution expression for Z_PDF(z) is to understand the probability distribution function (PDF) of a sum of two independent random variables. This is important in many fields of science, such as signal processing, statistics, and engineering.</p><h2>2. What is the mathematical formula for the convolution expression for Z_PDF(z)?</h2><p>The convolution expression for Z_PDF(z) is given by the formula Z_PDF(z) = ∫f_X(x)f_Y(z-x)dx, where f_X(x) and f_Y(x) are the PDFs of the two independent random variables X and Y, respectively.</p><h2>3. How is the convolution expression for Z_PDF(z) related to the Central Limit Theorem?</h2><p>The convolution expression for Z_PDF(z) is related to the Central Limit Theorem in that it allows us to calculate the PDF of a sum of independent random variables, which is a key concept in the Central Limit Theorem. In other words, the Central Limit Theorem states that the sum of a large number of independent random variables will tend towards a normal distribution, and the convolution expression for Z_PDF(z) helps us to understand and calculate this distribution.</p><h2>4. Can the convolution expression for Z_PDF(z) be extended to more than two independent random variables?</h2><p>Yes, the convolution expression for Z_PDF(z) can be extended to any number of independent random variables. The formula remains the same, but the integral will have more terms, one for each random variable.</p><h2>5. How is the convolution expression for Z_PDF(z) used in practical applications?</h2><p>The convolution expression for Z_PDF(z) is used in practical applications to analyze and model real-world phenomena that involve multiple random variables. For example, it can be used to understand the distribution of noise in a signal or to calculate the probability of a certain outcome in a complex system with multiple variables. It is also used in statistical analysis and machine learning algorithms.</p>
  • Topology and Analysis
  • Classical Physics
  • Calculus
