Deriving differential eqaution
  1. Mar 28, 2005 #1
    I am trying to derive an equation for the oscillation of a conical float. There is a conical float with a density of delta 2 and its floating on water with density 1. Find the oscillation of the floating conical float. The final solution should be:
    d^2y/dt^2=-g+(g((L-y)/L)^3)/p
    where y(t) is the height of the conical float over the water, L is the length of the conical float,g is gravity and p is the ratio of the two density delta1/delta2
    what i did was i found the submerge volume: (1/3)r^2(L-y)
    then the weight of water displaced by the float is:
    (1/3)r^2(L-y)*delta2*g
    mass of float m=(1/3)r^2(L)*delta2
    using this in newton's second law i got:
    d^2y/dt^2=-g+g*p((L-y)/L) where p=delta1/delta2
    i am not getting the solution that my professor gave?...can somebody explain where the cubed part came from?
  3. Mar 29, 2005 #2
    ehild
    use delta1 instead of delta2.
    You can not use the same r for both parts. If R is the radius of the base of the whole conus and r is the same for the submerged part, r/R=(L-y)/L
    ehild
  4. Mar 29, 2005 #3
    You would need at least to show that
    [tex]\frac{d^2y}{dt^2} = ky[/tex]
    Also I believe you have to clarify whether the cone is upside down, or with the base down.
Similar Discussions: Deriving differential eqaution
  1. Derivative of (Replies: 5)
  2. Differential amplifier (Replies: 2)
Loading...
