Deriving the EM Hamiltonian
In summary, the person is trying to derive the Hamiltonian for an E&M field, but they are having trouble because they are not understanding the Lagrangian. They get close to finding it, but make a mistake in the calculation of one of the terms. They also mention that there is a better way to do it, but they don't remember the details. Finally, they mention that when working with the (+---) metric, the canonical momentum is either (\Pi^\mu=\frac{\delta \mathcal L}{\partial^0 A_\mu} or \Pi^\mu=\frac{\delta \mathcal L}{\partial_0 A_\mu} depending
For some reason I can't derive the Hamiltonian from the Lagrangian for the E&M field. Here's what I have (using +--- metric):
[tex]
\begin{equation*}
\begin{split}
\mathcal L=\frac{-1}{4}F_{ \mu \nu}F^{ \mu \nu}
\Pi^\mu=\frac{\delta \mathcal L}{\delta \dot{A_\mu}}=-F^{0 \mu}
\mathcal H=\Pi^\mu \dot{A}_\mu -\mathcal L=-F^{0 \mu}\dot{A}_\mu +\frac{1}{4}F_{ \mu \nu}F^{ \mu \nu}
=-F^{0 \mu}\dot{A}_\mu+\frac{1}{4}(2F_{0i}F^{0i}+F_{ij}F^{ij})
\end{split}
\end{equation*}
[/tex]
But F0i=Ei, and Fij=-Bk, so this is equal to:
[tex]
\mathcal H=-F^{0 \mu}\dot{A}_\mu+\frac{1}{2}(-E_{i}^2+B_{i}^2) [/tex]
The Hamiltonian however should be one half the sum of the squares of the electric and magnetic fields. But I can't figure out what I did wrong. I almost have it, as the first term almost adds to the 2nd term to give that, but not quite.
Also, I'm not quite sure when using the (+---) metric whether the canonical momenta is:
[tex]
[/tex]
or
[tex]
\Pi^\mu=\frac{\delta \mathcal L}{\partial_0 A_\mu}[/tex]
I don't think it matters in the derivation of the Hamiltonian, but which one do you use in the canonical commutation relations for example?
OK, I missed a term the first time around. We can write
[tex]
-F^{0 \mu}\dot{A}_\mu = -F^{0 i}\partial_0{A}_i = - F^{0i}( F_{0i} + \partial_i A_0 ) = E_i^2 + E_i (\partial_i A_0)
[/tex]
Then
[tex]
\mathcal H=-F^{0 \mu}\dot{A}_\mu+\frac{1}{2}(-E_{i}^2+B_{i}^2) =\frac{1}{2}(E_{i}^2+B_{i}^2) + E_i (\partial_i A_0).
[/tex]
The last term can be written as
[tex] \partial_i ( A_0 E_i) - A_0 ( \partial_i E_i) .[/tex]
The total derivative will vanish in the volume integral, while the second term vanishes by Gauss' law in the absence of sources.
I believe that there's a cleaner way of doing things by treating the choice of gauge as either a 1st or 2nd class constraint, but I don't remember the details.
[tex]
[/tex]
or
[tex]
It doesn't matter whether the 0 is upstairs or downstairs, if you're using the (+---) metric. It would have mattered however if you were using the (-+++) metric, of course. However, for consistency and esthetical reasons, the 0 should be downstairs when it's the time derivative of the vector potential. So the second formula in my quote is the right one to use.
And the canonical hamiltonian for a constrained system is always computed on the hypersurface of primary constraints. In your case, it's the hypersurface [itex] \Pi_{0} = \Pi^{0} = 0 [/itex].
To find the hamiltonian in terms of the classical fields E and B, first compute wrt the potentials and the canonical momenta.
Suggested for: Deriving the EM Hamiltonian
