What is the limit of (ah-1)/h as h approaches 0?
In summary, the function ex comes around because you want a function whose derivative is equal to itself. Well, we can show that if f(x)=ax, a>0, then f'(x) is equal to a multiple of itself. If you use L'Hopital's rule, you'll get that lim h-->0 (ah-1)/h ) = 0/0, so if you apply that, you'll get lim h-->0 (h*ah-1)/(1) = 0.
dumbQuestion
125
Hey, I am having some difficulties. So it's my understanding that the function ex comes around out of a desire to have a function whose derivative is equal to itself. Well we can show that if f(x)=ax, a>0, then f'(x) is equal to a multiple of itself using the limit definition of the derivativef'(x) = lim h-->0 (f(x+h)-f(x))/h = lim h-->0 (ax+h - ax)/h = lim h-->0 ax(ah-1)/h = ax ( lim h-->0 (ah-1)/h )So the goal is, if we can find a value a that makes (lim h--> 0 (ah-1)/h ) = 1, then f'(x) = f(x).My only issue is that when I actually take this limit, I don't understand how it can be anything other than 0. lim h-->0 (ah-1)/h ) = 0/0 so if we apply L'hopitals, we getlim h-->0 (h*ah-1)/(1) = [lim h--> 0 (h) * lim h-->0 (ah-1)]/lim h-->0 (1) = 0Right? What am I doing wrong in evaluating this limit? I mean I know I"m doing something wrong I just can't figure out what it is
If you use L'Hopital's rule, you'd have to differentiate with respect to h and not a (you always differentiate with respect to the variable under lim with l'Hopital's rule):[tex]\lim_{h\to 0}\frac{a^h-1}{h} = \lim_{h\to 0}\frac{\frac{d}{dh}a^h-1}{\frac{d}{dh}h} = \lim_{h\to 0}\frac{d}{dh}a^h[/tex]which basically brings you back to where you started in finding the derivative of ax...
Now, there is a way to rewrite the limit expression lim h-->0 (ah-1)/h ) to get another expression that you can use to approximate the value of a such that the limit above equals 1, which turns out to be a ≈ 2.71828, if that's what you wanted.
To be honest, Taylor series can easily express the solution to the differential equation
[tex]\frac{dy}{dx}=y[/tex]
subject to the condition [itex]y(0)=1[/itex], which is the exponential function. e is its value at one.
Your method will work. Try plugging in the limit formula for e after making the variable of the limit go to 0 via a substitution.
You talk about "deriving" the value of e, but, in fact, in most texts the value of e is defined just as you give it:
From the derivative calcluation, we can show that the derivative of [itex]a^x[/itex] for any positive a is
[tex]a^x \lim_{h\to 0}\frac{a^h- 1}{h}[/tex]
We define "e" to be the value of a that makes that coefficient 1:
[tex]\lim_{h\to 0}\frac{e^h- 1}{h}= 1[/tex]
We can roughly (and it can be made precise by "[itex]\delta- \epsilon[/itex] arguents") say that, for h close to 0, we have, approximately,
[tex]\frac{e^h- 1}{h}~ 1[/tex]
[tex]e^h- 1~ h[/tex]
[tex]e^n~ 1+ h[/tex]
[tex]e~ (1+ h)^h[/tex]
and so arrive at the definition [itex]e= \lim_{h\to 0} (1+ h)^h[/itex] which is equivalent to
[tex]e= \lim_{n\to\infty} (1+ \frac{1}{n})^{n}[/tex]
You will also see that definition of "e" in situations that have nothing to do with derivatives. If you have a loan, or investment, or bank account, where the interest rate is r and the interest is compounded n times a year, after one year the return (or amount owed if a loan) will be the original amount times [itex](1+ r/n)^n[/itex]. The limit, as n goes to infinity, of that is [itex]\lim_{n\to\infty}(1+ r/n)^n= e^r[/itex].
As for specific values of e, we can see that if a= 2, taking h= .001 gives [itex](a^h- 1)/h=[/itex] .6939< 1 while taking a= 3, h= .001, [itex](a^h- 1)/h=[/itex] 1.099> 1 so the value of a= e, giving a limit of 1 must be between 2 and 3. Taking a= 2.5, h= .001, [itex](a^h- 1)/h=[/itex]0.917< 1 so e must be between 2.5 and 3. Taking a= 2.75, h= .001, [itex](a^h- 1)/h=[/itex]1.012 so e must be between 2.5 and 2.75. Continuing in that way we can get e as accurately as we wish.
I will also point out that many new Calculus texts first define [itex]ln(x)[/itex] by
[tex]ln(x)= \int_1^x \frac{1}{t} dt[/tex]
All of the properties of ln(x) can be shown from that, including that it is invertible. We can then define exp(x) to be the inverse function. It can then be shown that, for all x, [itex]exp(x)= (exp(1))^x[/itex] so, defining e= exp(1), we have exp(x)= e^x. That is the same as saying that ln(e)= 1 so that e can be evauated numerically by repeated numerical integrations of 1/x from 1 to different values of a, each time getting the integral closer to 1.
Thank you all so much for the responses! This has given me many different angles to think about this issue from. Also I see the stupid mistake I was making now (was differentiating in terms of a instead of h)!
What is the value of e?
The value of e is approximately 2.71828. It is a mathematical constant that is the base of the natural logarithm.
How is the value of e derived?
The value of e can be derived through various mathematical methods, such as using infinite series or limits. One common method is by using the formula e = limn->∞ (1 + 1/n)n.
What is the significance of the value of e?
The value of e has many applications in mathematics and science. It is used in exponential growth and decay, compound interest calculations, and in the normal distribution of statistics. It also has connections to complex numbers and calculus.
Who discovered the value of e?
The value of e was first discovered by the Swiss mathematician Leonhard Euler in the 18th century. However, the concept of e was known to earlier mathematicians such as John Napier and Jacob Bernoulli.
Is the value of e an irrational number?
Yes, the value of e is an irrational number, meaning it cannot be expressed as a simple fraction. Its decimal representation is infinite and non-repeating.
  • Topology and Analysis
