Why is the Speed of Light Constant in Time Dilation?
In summary: because length contraction would only effect the x component, which is the same as the train velocity.
cragar
2,552
So when we derive time dilation, and when we have a train moving and we shoot a light beam from the bottom to the top, to an outside observer not on the train he will see the light leave at an angle. So my question is why don't we factor the horizontal speed of the train in order have the horizontal component of speed for the light wave . And then use the x and y component to find the magnitude of the vector.
http://en.wikipedia.org/wiki/File:Time-dilation-002.svg
this is a link to the picture i am talking about.
I realize that the speed of light is constant relative to all observers based on Maxwells equations.
If I understand your question, the answer is yes we do.
The guy standing on the platform thinks the light beam travels straight out and back, a distance L with velocity c, taking time t = L/c.
The guy on the train thinks the light beam travels along the diagonal D, a distance sqrt(L2 + (vt')2), with velocity c, taking time t' = sqrt(L2 + (vt')2)/c. Squaring the latter, you get (c2 - v2)t'2 = L2 = c2t2, or t' = t/sqrt(1 - v2/c2), which is the Lorentz relation.
Bill_K,
Sounds about right. However, I think you got the POVs accidentally mixed up, given the stated scenario. I'm assuming you meant ...
The guy on the train thinks the light beam travels straight out and back ...
The guy standing on the platform thinks the light beam travels along the diagonal D ...​
GrayGhost
I don't think you guys understand what I'm asking. I don't see why the diagonal velocity is c from the person watching the train go by. the person watching the train going by sees the light leave at an angle. So to find the magnitude of that velocity vector we take the x component and the y component and then find the magnitude . If we did this we would get a speed greater than c. So my question is why don't we take this into account.
You have answered your own question.
If "the speed of light is constant relative to all observers" then we cannot "get a speed greater than c".
Well, you know the light must remain directly above the emitter at all times (so that the light travels vertically in the x frame), so that means the x component must be the same as the velocity of the emitter, i.e. the velocity of the train. But how do you propose to find the y component? The normal method would be to start with the fact that relativity says the total magnitude of the velocity vector must be c, giving (train velocity)^2 + (y component)^2 = c^2, then solve for the y component. If you have some other suggestion about how to derive the y component, please explain.
I realize that the speed of light is constant relative to all observers based on Maxwells equations.[/QUOTE]
This is a postulate. In whichever direction, observer on the platform sees light beam travelling, it will be c. Not less, not more. That is why we get time dilation.
will the light appear to be red shifted or blue shifted to the observer watching the train go by.
Blue shifted when he sees the train approaching him, red shifted when he sees it moving away from him.
ok thanks , one more question about it, why don't we factor in length contraction into the horizontal component of length. Is this because the ruler on the trains also contracts so it doesn't matter . And i think that length contraction is also derived from this.
The horizontal component is the distance (in the observer's frame) the top and bottom mirror travel in the time t it take the light to get from one to the other, length contraction doesn't change the fact that if something is moving at v in my frame for time t, it travels a distance of v*t. Length contraction applies when you know the distance between two objects (or two ends of a single object) in their own rest frame, and you want to know the distance between them in your frame where both are moving.
Yes, you can derive length contraction from the light clock once you've already derived time dilation, just imagine setting the light clock on its side so that instead of one mirror being above the other, both mirrors are on the floor, the axis between them being parallel to the direction the train is moving in your frame. Then since the time to bounce from one to the other and back in your frame should be dilated by the same amount as a vertical clock (because they both tick at the same rate in the train rest frame, so they have to in your frame too), you can figure out how far apart they need to be for this to be true.
thanks for your answer
1. What is time dilation?
Time dilation is a phenomenon in which time appears to pass slower for an object or person in motion compared to a stationary observer.
2. How is time dilation derived?
Time dilation is derived from the theories of special and general relativity, which state that the laws of physics are the same for all observers in uniform motion. This leads to the concept of space-time and the idea that time can be distorted by gravity and motion.
3. What is the formula for time dilation?
The formula for time dilation is t0 = t / √(1 - v2/c2), where t0 is the time for the moving object or person, t is the time for the stationary observer, v is the velocity of the moving object, and c is the speed of light.
4. How does time dilation affect everyday life?
Time dilation has been observed in experiments involving particles traveling at high speeds, but its effects are not noticeable in everyday life. GPS systems, however, do take into account the time dilation caused by the satellites' high speeds in order to accurately determine location.
5. Can time dilation be proven?
Yes, time dilation has been confirmed through numerous experiments and observations, including the famous Hafele-Keating experiment in which atomic clocks were flown in airplanes to measure the effects of gravity and motion on time.
