Describing behavior on each side of a vertical asymptote
In summary, the vertical asymptotes of the graph of F(x) = (3 - x) / (x^2 - 16) are x = 4 and x = -4. The behavior of f(x) as it approaches these asymptotes is as follows: f(x) approaches +inf as it approaches x = -4 from the left, f(x) approaches -inf as it approaches x = -4 from the right, f(x) approaches +inf as it approaches x = 4 from the left, and f(x) approaches -inf as it approaches x = 4 from the right. This can be determined using limits.
Jacobpm64
239
Find the vertical asymptotes of the graph of F(x) = (3 - x) / (x^2 - 16)
ok if i factor the denominator.. i find the vertical asymptotes to be x = 4, x = -4.
The 2nd part of the problem asks:
Describe the behavior of f(x) to the left and right of each vertical asymptote.. I'm not sure what i need to write for this.
It's asking for what happens as the function appraches the asymptotes from the left and the right, does it go to infinity - what?
You can use limits to find out.
ahh thanks.. so...
f(x) approaches +inf as it approaches x = -4 from the left...
f(x) approaches -inf as it approaches x = -4 from the right...
f(x) approaches +inf as it approaches x = 4 from the left...
f(x) approaches -inf as it approaches x = 4 from the right...
correct?
Correct. :smile:
What is a vertical asymptote?
A vertical asymptote is a vertical line on a graph that represents a value where the function approaches but never touches. It can also be thought of as a boundary or limit for the function.
What does it mean for a function to have a vertical asymptote?
If a function has a vertical asymptote, it means that the function is undefined at that particular value. This can happen when the denominator of a rational function becomes zero.
How do you describe behavior on each side of a vertical asymptote?
The behavior on each side of a vertical asymptote can be described using limit notation. For example, if the asymptote is located at x=a, the limit of the function as x approaches a from the left side would be written as lim x→a- f(x) and the limit from the right side would be written as lim x→a+ f(x).
What are the different types of behavior on each side of a vertical asymptote?
There are three types of behavior that can occur on each side of a vertical asymptote: approaching from above, approaching from below, and approaching from opposite directions. The type of behavior depends on the slope and the concavity of the function.
How can I use the behavior on each side of a vertical asymptote to analyze a function?
By understanding the behavior on each side of a vertical asymptote, we can determine the end behavior of a function and identify any discontinuities. This can help us graph the function accurately and make predictions about its behavior. It is also useful for finding limits of the function.
  • STEM Educators and Teaching
  • Precalculus Mathematics Homework Help
