Describing bond between elements
In summary, on case A, S has a bigger electonegative energy then Ca, so it will "take" 2 electrons from Ca in order to be a complete gas like Ar. So i know why there is +2 on Ca and -2 on S. Ca has after perfect gas 4S^2. S =[Ne]3s^2 3P^4. But there are dots and cols what they mean? Regarding case B, Mg needs to take only one electron from Br in order to become a perfect gas like Kr. After the reaction, Br needs to take 1 electron from Mg to become neutral gas. And for Mg to become a neutral gas we need to take 2 electrons. But why
transgalactic
1,395
http://img525.imageshack.us/img525/2290/84419342em1.th.gif
in case A:
so it will "take" 2 electrons from Ca inorder to be a complete gas like (Ar)
so i know why there is +2 on Ca and -2 on S .
S =[Ne]3s^2 3P^4
but there are dots and cols what they mean??
regarding B:
for Br to become a perfect gas like(Kr)
it needs to take only one electron
why there is -2 ??
and what are all the dots nere it and cols []??
Eight dots as octet (eight electrons) on the valence shell.
[] just groups atom and electrons together, so that when you write [Ca]<sup>2+</sup> or [Ca:]<sup>0+</sup> it is obvious that charge is that of the atom and the electrons together.
Where do you see -2? There are two Br<sup>-</sup> anions (each with its own octet), that gives -2 in all, but there is no individual entity with this charge in the magnesium bromide.
on case A
the formula for S is [Ne]3S^2 3p^4
from where in this formula i can see that there is 8 electrons on the valence shell??
For S2- it becomes [Ne]3s23p6 - hence the octet. [Ne]3s23p4 is a neutral S atom.
ok i understand case A
regarding case B:
Mg=[Ne]3s^2 so it has 2 electrons on the
valence shell before the merging.
Br=[Ar]3d^10 4s^2 4p^5
so it has 17 electrons on the
after the merging Br needs to take 1 electron from Mg to become neutral gas.
and for Mg to become a neutral gas we need to take 2 electrons
so we link two Br atoms
but why they present 8 dots around Br??
before it was 17 then we add 2 so we have 19
but 2*8=16
To get stable octet.
but 2*8=16
We don't add two electrons. We add one electron to each of the two Br atoms. You have to treat each atom separately.
d electrons can be in this case ignored, they don't play any role.
regarding case B:
before Br has 17 electrons
after the reaction each Br gets 1 electron
so each Br must have 18 electrons
but in the solution
they have only 5
Picture is fuzzy, but they have 8, just like sulfur. : on the left, : on the right (it is "Br:", not "Br."), two above and two below.
ok even if its 8
but in the solution
they have only 8
its not 18
I have already explained: d electrons are ignored, they don't play any role.
why egnoring
D
3d^10 4s^2 4p^5
they do play a role
they all
are on the
valence shell
Octet rule is only a simplification. Obviously it can't work for any atom where d electrons take part in the boding, as there are 10 of them and octet calls for 8 electrons.
In this particular case s&p electrons are enough to explain what is going on, d electrons are not involved - they sit on their orbitals untouched.
thanks
What is a chemical bond?
A chemical bond is a force of attraction between atoms or ions that holds them together in a molecule or compound.
What are the different types of chemical bonds?
There are three main types of chemical bonds: ionic bonds, covalent bonds, and metallic bonds. Ionic bonds involve the transfer of electrons, covalent bonds involve the sharing of electrons, and metallic bonds involve a sea of delocalized electrons that hold metal atoms together.
How are chemical bonds formed?
Chemical bonds are formed when atoms interact with each other, either by sharing or transferring electrons in order to achieve a more stable electron configuration. This allows the atoms to have a lower overall energy, making them more stable.
What factors affect the strength of a chemical bond?
The strength of a chemical bond is affected by several factors, including the types of atoms involved, the distance between the atoms, and the number of electrons being shared or transferred. Generally, the stronger the attraction between the atoms, the stronger the bond will be.
Why are chemical bonds important?
Chemical bonds are important because they are responsible for the formation of all molecules and compounds, which make up everything around us. They also play a crucial role in determining the physical and chemical properties of substances, such as their melting point, boiling point, and reactivity.
  • Atomic and Condensed Matter
26K
