Description of a wave
A simple harmonic wave train of amplitude 3 cm and frequency 200 Hz travels in the +ve direction of x-axis with a velocity of 20 m/s. Calculate the displacement, velocity, and acceleration of a particle situated at 50 cm from the origin at t = 2 s.
I used [itex]y(x, t) = Acos(2\pi f(\frac{x}{v}-t))[/itex]
Plugging in the values into the above equation, I got [itex]y(0.5, 2) = 0.03cos(400\pi (\frac{.5}{20} - 2))[/itex], which evaluates to 0.0236 m. However, the book says the answer is 0.02523 m.
This is marked as an easy question and is one of the first ones, so I think that I'm missing something basic?
Answers and Replies
haruspex
Insights Author
2020 Award
36,415
6,945
You need to be a bit careful evaluating trig functions of large angles. The series expansions used by calculators get rather inaccurate. Instead, first reduce the angle to something less than 2 pi. I think you'll find both your answer and the given answer rather inaccurate!
Part of my confusion lies in whether I should be in radians or degrees - the examples in the book all use radians, but when I evaluated the above, I got [itex]cos(-790\pi)[/itex], or 1. Changing the angle to something less than 2[itex]\pi[/itex] still gets me 1.
When I use degrees, I get 0.0236, which is closer to 0.02523. I plugged the expression into Wolfram-Alpha, which got me the same as the one on my calculator. Changing the angle to something less than 360 degrees got me 0.0271.
haruspex
Insights Author
2020 Award
36,415
6,945
Definitely radians. The standard equation you quoted assumes radians.
It gives you 1 for the value of the cos function, but you still have to multiply by A.
rude man
Insights Author
822
I got the same answer as you.
BTW the problem should state that the wave is inded ~ cos(kx - wt) and not something like cos(kx - wt + φ), φ ≠ 0.
Always assume radians. And always assume natural instead of base-10 logs. Calculus falls apart otherwise!
haruspex
Insights Author
2020 Award
36,415
6,945
Then you must be using a calculator that truncates the precision of pi at the same point. The right answer is clearly 0.03m.
rude man
Insights Author
822
Not truncate. Round off.
But yes, score one for the Aussies. Again, only if the wave is cos(kx - wt + φ), φ = 0 assumed. The problem is not clearly stated.
Related Threads on Description of a wave
  • Last Post
9K
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
