What equipment do I need for designing circuits at home?
In summary, the speaker is starting their senior year in Electrical Engineering and feels they need more hands-on experience with equipment. They are considering playing around with circuits at home and have access to breadboards, resistors, diodes, mosfets, opamps, and a multimeter. They are unsure about the ideal power supply to use and are interested in finding a cheaper alternative to an oscilloscope. They also mention a potential project to make their own power supply and express interest in eventually getting a regulated variable power supply. They acknowledge the usefulness of an oscilloscope but mention that they have been able to do without one in the past.
dalarev
99
Firstly, I am starting my senior year in Electrical Engineering once school starts, and I feel that I am in dire need of some more "hands on" experience with the equipment. At my uni, the EE degree is split up into a Physics path, and a technology path. I'm thinking that may be a bad idea though, because most of my class mates (in the Physics program) are surprisingly inexperienced with most of the equipment.
At any rate, I would like to start playing around with circuits at home. I have breadboards readily available, resistors, diodes, mosfets, opamps, basic electronic devices like that. My biggest question is:
Power supply. I could try a 9v battery, per se, but how "ideal" of a source would that be? Also, that seems pretty inconvenient.
Also, perhaps something like an oscilloscope? I realize these cost thousands of dollars, but isn't there any software I can use to read an output signal, for example?
At home, I also have a device to measure resistance, voltage, current, and probably some other stuff I'm not aware of. I'm afraid to call it what I think it is (multimeter), because I always hear a new name for it. That is a clear indicator of my technical inexperience, so I would really take any advice/comments I can get. Thanks in advance.
A battery holder with a bunch of rechargable AA might be better for most digital stuff you only want 5V (4AA = 6v will do)
There are a few companies that make USB scopes for $100-200 , if you are into digital/microprocessors it's an interesting project to make one with an atmel/arduino
Multimeter / digital voltmeter / DVM it's all the same thing - from $20 to a lot!
Oscilloscopes don't necessarily have to cost thousands. For a couple hundred you can get something in the 30-50 MHz bandwidth range which is more than sufficient to learn the basics of operation and troubleshoot most circuits you'd be liable to design at this stage. There are also good deals to be had on used equipment. I have a Tektronix 2465B 400 MHz 'scope I picked up for around $800.
Multimeter is a perfectly acceptable term for the device; simply "meter" is used frequently in the industry.
As for a power supply, a 9 V battery is perfectly fine for most basic circuits; combine with various regulators to provide different voltages and you're good to go.
That does sound like an interesting project; I will look up more info on that.
Is a 9v battery likely to quickly deplete if it is powering simple circuits with a couple of diodes/resistors?
Also, I think the real learning comes from actually "seeing" your output. I wouldn't know how to interpret my design without seeing what's happening.
9V don't have a lot capacity - they have 6 tiny AAAA batteries (about 1/2 the size of AAA) in a box.
Picoscope (in the UK) are good source of PC based instruments, but you can get cheaper versions in the US.
True, but they can nevertheless power small circuits drawing a few tens of milliamps for many hours. If one wants greater longevity, most electronics stores carry various plug-in wall-wart power supplies; some even have voltage selectors to provide a range of outputs.
Cell-phone battery chargers are a good source of regulated dc voltage. Read the label on it for details. If you aren't charging your cell phone all the time, plug your circuit into it.
This is exactly what I had in mind, actually. That is what I am used to as a (DC) voltage source at my uni; I figured they would be too pricey (>$200) for what I'm willing to invest right now.
But I imagine it can be designed. A diode rectifier coupled with a couple of voltage regulators. Of course, more complex than that, but I imagine it'd be a good project, especially educational.
A good source of power for experiments is a holder for D cells. These are economical to run, especially if you put alkaline D cells into them. 6 D cells will give you a 9 Volt power source that should last for months.
Maybe aim at a regulated variable power supply eventually. These are not hard to make and always useful. There are schematics for this on Google. Just hunt for regulated power supply.
You can do without an oscilloscope, but sometimes you are really flying blind without one. They tell you the waveform and relative voltages of whatever you are looking at. Even quite a simple one is a huge improvement on nothing.
There are lots of them on Ebay at present at prices ranging up from $100.
Look for dual trace and 20 MHz or higher. Not that you always need these things, but the ones that have them are usually better quality than those that don't.
Also try to get a digital multimeter and a small soldering iron. These don't have to be expensive either. They make good birthday presents if you have a birthday coming up.
You are probably busy, but maybe you could contact your local Amateur Radio club and go along to a few meetings just to see what other people are doing. Also find out where the stores are locally that supply electronic components and kits.
You are getting great advice here. I can only add a bit and emphasize some of the points made already.
Consider putting together a few kits for fun stuff that you are interested in. They help you to get started soldering and monitoring (and debugging!), and give you fun results in the process.
For a simple general power supply, you could use two DC "wall wart" power supplies, and arrange the connectors to output +/- power supplies. You could use 3 of them to give you +5V and +/-12V as a standard output, which will serve you fine for 99% of your bench-top projects. Basing your power supply on batteries has some limitations, so using DC wall warts instead will give you more development flexibility.
For your first 'scope, the USB PC/laptop based units are inexpensive and convenient. You will out-grow their capabilities at some point, and then you can look at the new $600 'scopes that are hitting the market (well, okay, from China). Pretty impressive 2-analog-channel + 16 digital signal logic analyzer performance.
Pick up a computer PSU rated for about 200 watts on eBay for about $15. It'll give you regulated (about +/- 5%) 12V, 5V, 3.3V, -5V and -12V (negative voltages aren't always available on newer PSUs). I had one in an old computer, so you could check there.
They usually have built in short circuit protection, over-voltage protection, over-temperature protection and are good for at least 5 amps on most of the outputs. You can combine the various voltages to get 24V, 17V, 10V, 8.7V, 7.0V, 1.7V (and any other ways you can combine the voltages). To switch them on you need to hard wire the green wire (PS_ON) to a ground lead. Then you can use the rear switch, if it has one, to control it.
Note that you might need to load down the inputs. Use a 10W+ / 10R resistor to do that (on 5 volt line)... Not all PSUs require it though.
I'm certain I have at least one extra PSU laying around somewhere, so I will definitely look into that.
And about the suggestion to look for local amateur radio clubs, that is an excellent idea. Fun, small projects would be a great idea to keep busy and motivated. Thanks a bunch for the great content.
dalarev said:
QUOTE]
The very old "AT" style computer powers supplies are the best for this because they have a "hard" switch to turn them on. With the newer ATX style power supplies you need to short two terminals (usually the green and the black) to kick them off. Also be aware that many computer power suppies require a minimum loading on some of the rails in order to maintain correct regulation or in some case to even function anywhere near normally.
Maybe you can make a small bench power supply one of your first projects. One thing about having a decent power supply, especially when you're first starting out and are likely to make some stuff-ups, is the ability to set current limits which are appropriate to the circuit under construction. For example if you're building a simple op-amp circuit and you don't expect it to draw more than a few tens of mA then you can really save unnecessarily damaging components (with accidental shorts circuits etc) if you set the current limit to match (eg 50 to 100mA for a low power circuit).
Be careful - the front panel switch is normally on the input side so at least one of the wires to it has line voltage when the thing is off.
Speaks from experience - and it's 240V over here, and that hurts!
This is why I only use ATX power supplies. Shorting two terminals is a easy price to pay for not making our hair stand strait up.
Also, be sure to get a GOOD multi-meter. Not one of those cheap ones for $10 from harbor-freight but an actual good quality meter.
The power supply I have requires no loading. Maybe the fan is enough for it, I don't know.
PS_ON is not at line voltage. It is 5 volts standby power which is provided even when the unit isn't switched on (e.g. fan not spinning but the switch on the back is on).
It is on ATX, on the older AT supplies there was a line switch to the front panel.
1. How can I start designing circuits at home?
To start designing circuits at home, you will need basic knowledge of electronics and circuit components. It is also helpful to have a breadboard, wires, resistors, capacitors, and other basic components. You can also use online resources, such as tutorials and circuit simulation software, to guide you through the design process.
2. What are the essential elements of a circuit design?
The essential elements of a circuit design include a power source, conductive pathways (such as wires), and components (such as resistors, capacitors, and transistors). These elements work together to control the flow of electricity and perform a specific function.
3. How can I ensure the safety of my circuit design?
To ensure the safety of your circuit design, it is important to follow basic safety precautions, such as working with low voltage circuits, using insulated tools, and disconnecting the power source before making any changes. It is also recommended to use a fuse or circuit breaker to protect your circuit from overloading or short circuits.
4. How can I test and troubleshoot my circuit design?
To test and troubleshoot your circuit design, you can use a multimeter to measure voltage, current, and resistance at different points in the circuit. This can help you identify any issues or faulty components. You can also use circuit simulation software to test your design before building it physically.
5. What are some common mistakes to avoid when designing circuits at home?
Some common mistakes to avoid when designing circuits at home include incorrect wiring, using incorrect component values, and omitting essential components. It is also important to double-check your circuit design and calculations before building it physically to avoid any potential hazards or malfunctions.
  • Electrical Engineering
