How Can We Effectively Destroy An Asteroid Headed for Earth?
  • Thread starter Line
  • Tags
    Asteroid
In summary, it was said that if we needed to destroy and asteroid headed for Earth the fastest easiest way is with a nuclear bomb. If we used it it would destroy it but it would create thousands of pieces falling to Earth which would be much worse.
  • #106
mr200backstrok said:
this is a little off topic, but is there an upper limit for the yield of thermonuclear bombs?
To my knowledge, there is no upper yield limit. In principle, by cascading fission/fusion/fission stages, any size weapon could be constructed. I believe 50,000 megaton devices have been studied: http://en.wikipedia.org/wiki/Nuclear_weapon_yield
However there is a limit to the yield per unit weight. The absolute maximum theoretical yield is 166 kg per megaton, and that's just for the nuclear material itself. Actual achievable yield from real-world warheads is closer to 350-400 kg per megaton.
Stated differently, the maximum yield ratio thus far achieved is 5.2 megatons per metric ton, so a 200 megaton device would weigh 38.5 metric tons (84,877 lbs).
The Saturn V payload to lunar escape velocity was about 47 metric tons, so largest bomb it could lift on that trajectory would be "only" 244 megatons.
An asteroid intercept would likely require a higher energy trajectory, which means lower payload. Just guessing, say about 100 megatons on a Saturn V.
  • #107
mr200backstrok,
Unlike fission weapons, there is no upper limit nor lower limit to the yield of a
thermonuclear bomb [ provided you can ignite it ].
Consider the lower limit. The small fusion pellets that would undergo thermonuclear
fusion in ICF - Inertial Confinement Fusion are, in essence; small thermonuclear "bombs".
The problem is it takes an awfully large machine, like a laser the size of a football stadium
to ignite it.
In fission bombs; there is a lower limit because there is a "critical mass". You don't get
a self-sustaining fission reaction until you have a certain minimum amount of material,
called the "critical mass". Once you get the fission reaction started in a fission bomb
by having the minimum amount of bomb fuel - then you have enough fuel there for a
yield that is very sizeable compared with conventional chemical explosives.
In practice, the thermonuclear bombs are "triggered" by a fission bomb; so there is a
minimum possible yield to a real thermonuclear bomb because there is a minimum yield
for the device that triggers it.
The largest bomb ever designed was the "Tsar Bomba" - "King of the Bombs" - which
the Russians designed to have a yield of 100 megatonnes. They actually tested a
reduced yield version of this bomb with a yield of 54 megatonnes. That test was the
largest yield nuclear test ever conducted.
Dr. Gregory Greenman
Physicist
  • #108
joema,
You're off by a factor of 1,000!
The table in the Wikipedia article you reference gives the yield of the Tsar Bomb as
50,000 in units of KILOTONS. That would be 50 Megatonnes; not 50,000 Megatonnes.
Physicist
  • #109
Morbius said:
...You're off by a factor of 1,000!...The table in the Wikipedia article you reference gives the yield of the Tsar Bomb as
50,000 in units of KILOTONS. That would be 50 Megatonnes; not 50,000 Megatonnes...
Sorry, I was referring to theoretical weapons which have been studied, not actual detonations. I referenced the article to show the basic principles of nuclear weapon yield, and the chart which shows there's a yield-to-weight limit but no upper yield limit: http://en.wikipedia.org/wiki/Image:US_nuclear_weapons_yield-to-weight_comparison.svg
I don't have the ref, but I believe in the 1950s and 60s, Rand Corp. studied unitary Cobalt-salted devices with yields up to 50,000 megatons. They concluded there was no upper yield limit, and then-current engineering would allow construction.
However from an asteroid deflection standpoint, there's no way to deliver such a device, as it's far too heavy for even the largest launch vehicle. It would take a vehicle at least 100x the payload capacity of a Saturn V.
  • #110
that one is measured in kt. if you look at the left side of the chart, it says "yield (kt)".
That kind of power is insane...
  • #111
that one is measured in kt. if you look at the left side of the chart, it says "yield (kt)"...
Yes, I know it says yield in kt. But just as the horizontal axis shows weight in kg up to 10^5 kg, there is in fact no upper weight limit, nor any yield limit.
  • #112
joema,
Rand Corp. doesn't design nuclear weapons; or even know how the current ones work.
There are ONLY two places in the USA where the design knowledge for thermonuclear
weapons exists; and that's at Los Alamos and Lawrence Livermore.
So I wouldn't put any credance in anything out of Rand when it comes to nuclear
weapons design.
Physicist
  • #113
Morbius said:
joema,
Rand Corp. doesn't design nuclear weapons; or even know how the current ones work...
Thanks for the correction. Maybe it wasn't RAND.
True LANL and LLNL are the centers of actual weapon design, and past RAND research focused more on weapon effects than design. However RAND participants have included former Los Alamos and Lawrence Livermore physicists. Two examples:
- Harold L. Brode, physicist, and pioneer of numerical simulations of nuclear explosions
- Samuel Cohen, inventor of neutron bomb
None of this changes the answer to the poster's question: there's no upper limit to the maximum size of a nuclear warhead, but the yield-to-weight ratio imposes a practical limit based on current launch vehicle payload capacity.
  • #114
Harold L Brode was a physicist at RAND that simulated nuclear weapons effects -
NOT the bomb itself. The only places where the nuclear weapon itself is simulated
in the USA is at Los Alamos and Lawrence Livermore.
Cohen is the "self-proclaimed" inventor of the neutron bomb.
However, the devices that were once in the USA's stockpile called "neutron bombs"
dating from the '70s were the W-79 Mod 0 artillery shells and they
were invented by scientists at Lawrence Livermore; NOT Cohen.
There's no theoretical upper limit to the yield of a thermonuclear weapon.
A fission weapon does have lower and upper limits.
However, since a thermonuclear weapon needs to be "triggered" by a fission weapon, and the fission weapon
has a lower yield limit; the thermonuclear weapon has an effective lower limit, because its trigger does.
BTW, check your Physics Forum Private Messages.
Physicist
  • #115
Thats a horrible idea, as you said it would send thousands of pieces towards earth. Most likely, the solution would be to push the asteroid out or somehow detonate it where it would split into and somehow well that remains to be figured in how to deal with the remaining pieces.
  • #116
xllhawksllx,
You don't understand how you use a nuclear device to deflect an asteroid.
You don't "blow up" the asteroid. You detonate the nuclear weapon at a stand-off
distance from the asteroid. The radiation from the nuclear weapon ablates the surface
of the asteroid, which causes it to recoil.
The nuclear weapon PUSHES the asteroid; it doesn't "blow it up".
For a large asteroid, a nuclear weapon may be the ONLY HOPE; because only a
nuclear weapon has enough energy to deflect a large asteroid in a package that
is light enough for us to launch into space.
Physicist
  • #117
Extreme Size of Thermonuclear Devices for Space Based Planetary Protective Measures
There are a number of ways extremely large nuclear devices could be fabricated for any of a wide variety of extreme planetary defense scenarios.
The first such scenario involves destroying a distant but inward bound asteriod or planetary body of extreme size. Note that the destruction of such a large body is possible if given enough time to fabricate a large enough nuclear device in Earth or Solar orbit. One can consider an extreme but rather absurd case wherein a global society might want to construct a thermonuclear device comprising 10 EXP 15 metric tons of fusionable material of simmilar construction to a fission-fusion-fusion device. Such a device would have a yield of approximately 10 EXP 23 tons of TNT or about 50 times the mass of the Earth in TNT which is roughly equivalent to the heat of vaporization of a typical mass of solid ordinary planetary materials with total mass equal to (n)(50)(Me) where n ranges from unity to 10 and depends on the materials and Me is the mass of the Earth. Such a device, if utilizing a dense hydrogenic compound for fusion fuel such as Lithium Dueteride, would have a diameter on the order of 100 kilometers.
The fusionable fuel for such a device would have to be collected from Earth and/or other planetary bodies and perhaps comets which comprise a large percentage of their material in the form of low atomic number exothermically fusionable elements. Thus such a large device would not be practicable nor possible to construct rapidly enough to respond to near term planetary emergencies such as the near term threat of a huge asteriod collision.
A more likely scenario for the use of devices this large and larger would involve the threat of extraterrestrial biological organisms such as may exist within a interstellar dust cloud in the form of exotic dangerous micro-organisms or any other simmilar interstellar threat. Such a threat in unlikely to be discovered any time soon and such a discovery would probably entail the ability and infrastructure in possession of future humanity to travel throughout interstellar space for which there have been suggested and studied numerous propulsion techniques that do not require any fundamental physics beyond what has already been commonly excepted and utilized on a wide scale in industry and research throughout the Globe.
One can, for instance, imagine the collection of cometary material from say the Kuiper Belt and/or the Oort cloud by intentionally directing comets in relatively slow collisions amongs themselves until a planetary body sized collection of low atomic number elements and their various isotopic forms has been accumulated. A means for purifying the collected material to form a planet sized nuclear device of precisely manufactured material content might be required to produce a workable thermonuclear device or perhaps the collected material could be ignited without refinement. In the later case, perhaps one or more large enough secondary nuclear devices could be used to initiate the
fusion of the collected mass at various locations wherein the process of fusion would quickly spread throughout the entire planetary mass until all of the collected fusionable material has fused. As another option, perhaps one or more large shaped charged nuclear fusion devices could produce the critical pressures required to initiate self propagating fusion reactions throughout the collected material. Note that a nuclear fusion device with the mass of the Earth would have a yield of roughly 10 EXP 29 tons of TNT or roughly the mass of TNT of two orders of magnitude greater than the approximate 10 EXP 27 metric tons mass of the Sun.
Although larger devices would seem to have no obvious conceivable purposes, one can even imagine as a very, very long term stellar engineering project, the very gradual construction of a thermonuclear device with the mass of a white dwarf star wherein the materials of construction would be supercooled at the construction site and gradually assembled and with a means for radiative heat exhaustion whereby the collection of matter could be built up in such a manner that it would not ignite and form a star. Obviously, a means would have to be devised to cope with the extreme gravitational forces on the surface of the growing orb which would eventually become, in a sense, a white dwarf as its increasing mass caused gravity induced self compression into white dwarf like matter densities.
As yet an even more extreme case, one can imagine the construction of a huge toriodal ring with the diameter of our planetary solar system comprising a mass of 10 EXP 5 to 10 EXP 6 solar masses of fusionable fuel wherein the torus would be gradually spun up as it is constructed in order to prevent gravitational collapse of the device as its mass increases. Accordingly, the device could be constructed at symmetrically disposed locations about a circle in either a discreet or continuous fashion. As the device neared completion, its final rotational velocity would be several hundreds of kilometers per second and the rotational velocity of the device would be designed along with the major diameter, thickness, and mechanical strength of the material composition of the torus in such a manner that the tidal forces acting on portions of the torus between locations at different radial distances from the center of the torus would have minimal effect. The torus when fully constructed would preferably be dense enough so that, even given its extreme size, its density would be close to that of a white dwarf inorder to provide a potentially much more stable and thin torus. For a torus having a 10 EXP 10 kilometer circumference, a mass of 10 EXP 6 solar masses, and a thickness of 10,000 kilometers. the density of the torus would approach that of a white dwarf.
Much larger torus shaped nuclear devices may be possible, but at the risk of boring the reader with absurdity, these more extreme versions will not be discussed here.
The point to be made here is that, literally speaking, there is no upper limit to the mass of a thermonuclear device. Why would mankind choose to produce the extreme sized devices described above is amyones guess. However, it may be useful to point out that the cosmos over long time frames is a metaphorical shooting gallery. One has to merely recall the event that supposedly wiped out the dinosaurs and realize that over a long enough time period, most probably, even larger threats will present themselves. If we are going to plan for the survival of mankind for the next thousand years, why not plan for our survival essentially for eternity.
  • #118
Um - there is a practical limit in which the yield is limited by the size, such that it would be impractical to build a large device. In addition to the yield, there is the matter of delivering the device. The bigger the device, the larger the propulsion system necessary to deliver it.
Pardon me, but a device based on 1015 metric tons of fusionable material is absurd!
  • #119
Hi Astronuc;
Thanks for the feedback.
A much more practical 1,000 megatons to safety destroy a 1/4 mile wide or even a 1/3 mile wide asteriod might be doable providing at least one third of the bombs energy can be deposited within the asteriod's material composition. 1,000 megatons of TNT releases the energy required to completely vaporize 2 cubic kilometers of water ice and because of the relatively lower specific heat and heat of vaporization of many solid minerals and metals roughly, an equal volume of rock and metal may be vaporized depending on the minerals and metals in question. Note that even though it is relatively easy to bring water from freezing to boiling, the heat of vaporization of water is about 1.85 megajoules/kilogram as opposed to the 0.420 megajoules/kilogram necessary to heat liquid water just above freezing to boiling temperature. The specific heat of water and its heat of vaporization is about as high as they come for ordinary materials.
Note that a 1 megaton nuclear warhead detonation in a surface blast will produce a crater 1,000 feet across and 200 feet deep in granite. Much of the ejected material would be vaporized in a surface blast and much of the remainder that is not vaporized will be pulverized into dust and or grainular pebble sized material. Based on the 1/3 route scaling of crater depth with yield, a 1,000 megaton device would produce a crater 10,000 feet across and 2,000 feet deep. Even based on the perhaps more precise EXP 0.31 dependence of crater size with incremental yield increase where the depth of the crater for a nuclear device detonated at Earth's surface scales as the EXP 0.31 incremental yield increase, we are still talking about a crater depth of at least 1/3 of a mile.
A good question would be how to effectively couple the bombs blast energy to the asteriodal material without causing it to break into smaller pieces. Perhaps using a robust deep asteriod penetration mechanism simmilar to the robust deep Earth penetration techniques studied within the U.S. defense establishment could be used to produce a much greater coupling between the bomb energy and the asteriodal material. Note that as big as the craters produced by surface detonations of nuclear weapons are, much of the weapons total energy is reflected back upward away from the ground so that more effective coupling of the blast energy to the ground as in a sub-surface burst produces a crater of considerably greater dimensions.
Another option would be to use a 1,000 megaton device in the form of a directed energy nuclear device such as a shaped charged nuclear device that would produce directed energy in the form of a much hotter, much higher pressured, and much higher velocity jet in a simmilar manner utilized by conventional shaped charged explosive devices used to defeat heavilly armoured vehicles. Some publically available sources quote the maximum potential explosive energy flux density from such a device as much as 6 orders of magnitude greater than that achievable by a traditional spherically symmetric nuclear detonation. Just as an interesting aside, this upper range for shaped charged nuclear explosives corresponds to a kinetic energy of protons within the explosion of about 10 TeV. This is within the range to be studied by the upgraded LHC of CERN in an attempt to discover the Higgs Bosons which are believed to be the quanta of the Higgs Fields which according to the Standard Model of Particles and Fields, is the mechanism responsable for mass generation and inertia for all known particles having mass in our universe.
The mattergy jet produced by a nuclear shaped charge device of 1,000 megaton yield might be just the right mechanism to effectively couple the blast energy to the asteriod providing that a large portion of the total energy of the blast can be incorporated within the jet.
For larger asteriods, larger devices could be constructed. Note that the approximate alledged 400 kilograms per megaton as the maximum mass specific yield of a nuclear device might not be valid if a large enough supply of fusionable fuel can be appropriately disposed around the fission primary of the thermonuclear device. Note that just one kilogram of hydrogen fully fusioned via the proton proton reaction cycle has a yield of about 200 kilotons. If such a reaction could propagate through a 100 metric ton thermonuclear device that is mostly hydrogen with about 95% or greater efficiency, then a 100 metric ton device based on the proton proton cycle could have a staggering yield approaching 20,000 megatons or a whopping 20 gigatons. I would think that this size of a device could be developed and llifted into low Earth orbit by the ARES V booster under development to lift into orbit the components of the CEV that will take mankind back to the Moon by about the year 2020. The large rocket propulsion system to accellerate this monster device to target an asteriod could be seperately lofted by another ARES V booster wherein the two components would be assembled in low Earth orbit.
Best Regards;
Jim
  • #120
I would like to wish all of the readership of this site and your families and loved ones a great New Year and many more to follow.
Regards;
Jim
  • #121
Thanks Jim.
Interestuing that this thread should get resurected now. I just read an article about a possible impactor headed for Mars. All scenarios for defending Earth from an impact rely no the early detection and accurate prediction f the impending impact event. If the asteroid 2007 WD5 hits Mars, it will do so within the month, and still nobody can say for sure. Not a very promissing sign.
  • #122
LURCH said:
Thanks Jim.
How accurately was the Shoemaker-Levi event predicted?
  • #123
Hi LURCH and baywax;
Thanks for your comments and feedback.
Given that a one megaton nuclear warhead releases the energy to fully vaporize 2 million metric tons of water ice or 2 million cubic meters of ice, and by virtue of many minerals' and metals' much lower heat of vaporization and specific heat compared to water, an equal volume of many of these much denser minerals and compounds could be vaporized by a one megaton device. I would have to say that if the energy of a one megaton nuclear detonation could be evenly distributed throughout a 450 foot diameter asteriod, the asteriod could be completely vaporized by such a device.
Note, that a surface detonation of only a one megaton nuclear warhead will produce a crater 200 feet deep and 1000 feet wide in hard rock, even in consideration that much of the blast energy of a surface nuclear detonation is instantly reflected back away from the ground. I would have to say that a robust deep asteriod penetrating one megaton nuclear warhead should be able to vaporize completely at least a 100 meter diameter asteriod. A 100 meter diameter asteriod would have a mass on the order of 1.5 million tons.
Such an asteriod hitting the surface of the Earth at a typical 20 Km/Sec would have a yield of (1.5 x 10 EXP 6)((7) EXP 2) tons of TNT or about 75 megatons which is almost as powerful as the most powerful publically agknowledge H-Bomb design of the former U.S.S.R. at 100 megatons. Such a 75 megatons explosion would be catastrophic if it happened in New York City, Mexico City, Tokyo, Beijing or other very large metro area.
Note that the thermal pulse of the Russian 58 megaton Tsar Bomba tested in 1961 in an airburst over a remote Arctic island location would have caused fatal third degree burns in humans at a distance of 100 kilometers from the blast epicenter. Although detonated 2.5 miles above the ground over the island, the rock crust beneath the blast was turned to ash. A woman who later visited the test side was amazed when she saw and noted that the blast zone was licked clean and shinny like an ice skating rink, all traces of uneveness in the rocks where melted and swepted away. Such an explosion's thermal pulse is large enough in the extent of its effects to completely set ablaze the entire land mass of many smaller nations and several of the smaller states within the U.S..
Clearly even only a 100 meter diameter asteriod, although not able to wipe out the human race, could produce totally unacceptable losses of property and human life. A direct nuclear strike by a typcial 0.475 megaton to one megaton yield warhead may be our only option in dealing with 100 meter diameter class asteriods on relatively short notice. Note that perhaps a couple to a few W-88 nuclear warheads such as those stationed aboard U.S. Ohio Class SSBM boats could probably do the job. The yield of one W-88 warhead is about 0.475 megatons or 475 kilotons.
Much larger asteriods might be destroyable with nuclear devices of much higher yield given enough lead time to construct and/or deploy such devices. Super large asteriods could be deflected potentially with a high yield stand off neutron bomb detonation wherein the intense neutron flux would penetrate several meters into the asteriod vaporizing the surface layer of the asteriod thus allowing the momentum imparted to the asteriod for course correction to be maximized by the recoil produced by the reaction between the hot very high pressured vaporized surface layer in gaseous form and the bulk of the remaining asteriod.
Best Regards;
Jim Essig
  • #124
How does one evenly distribute the energy of a one megaton nuclear detonation throughout an asteroid?
Do we get someone like Bruce Willis out there drilling holes for and even distribution?
  • #125
Hi baywax;
Thanks for the response.
You make an excellent point. If one is going to go through the trouble of bringing the hardware and/or explosives such as dynamite to drill a hole to the center of the asteriod, why not just attach a large effecient chemical rocket to nudge it out of the way. Perhaps on relatively short notice, a assemblage of powerful chemical rockets might do the job. Assumming that perhaps 2000 metric tons of rocket propellent would be used wherein the energy of propellent to asteriod velocity vector changing kinetic energy would be equal to 50 %, one can imagine the rocket system pushing on the asteriod to change its velocity by as much as about 100 meters per second which is very significant giving enough lead time assumming that the mass specific energy release for the combined masses of the rocket fuel components is roughly equal to that of TNT detonation. At the very least, the asteriod might be directed into a mid-ocean environment or to the middle of Antartica where it would likely do much less harm than if it hit a populated area.
Another draw back of nuking asteriods at very close range is the spread of the radioactive fallout cloud or a significant portion of it composed of radioactive gas, condensed particles, and soot from the destroyed asteriod. The whole planet could receive an unsafe dose of radioactive fallout at best.
Personally, I kind of like the huge chemical rocket idea in part because we understand chemical rockets very well. Scaling them up to huge proportions however would take some doing. But, better safe than sorry.
Thanks;
Jim Essig
  • #126
Everything I've seen on the Discovery channel about asteroid impacts seem to indicate that it wouldn't matter where it hit, the subsequent damage would be propogated around the earth. I also remeber seeing something about the force of impact traveling through the center of the Earth and causing greater damage on the other side. Of course the size and velocity of the asteroid would dictate how much damage was done.
CS
  • #127
CS
As for the planetoid that hit Mars and made the giant http://www.davesbrain.ca/whims_mars_atlas.php?map=altitude&labels=on" *, just ask the former residents of the Tharsis bulge and the Valles Marineris.
* sorry, IE only.
  • #128
* sorry, IE only.
Yes, it is also possible that an impact also took half of Mar's crust off.
Hemispheres Apart: The Crustal Dichotomy on Mars
Thomas R. Watters,1 Patrick J. McGovern,2 and Rossman P. Irwin III1
1Center for Earth and Planetary Studies, National Air and Space Museum, Smithsonian Institution, Washington, D.C. 20560; email: watterst@si.edu
2Lunar and Planetary Institute, Houston, Texas 77058
Abstract The hemispheric dichotomy is a fundamental feature of Mars, expressed by a physiographic and geologic divide between the heavily cratered southern highlands and the relatively smooth plains of the northern lowlands. The origin of the dichotomy, which may have set the course for most of the subsequent geologic evolution of Mars, remains unclear. Internally driven models for the dichotomy form the lowlands by mantle convection, plate tectonics, or early mantle overturn. Externally driven models invoke one giant impact or multiple impacts. Areal densities of buried basins, expressed by quasi-circular depressions and subsurface echoes in radar sounding data, suggest that the dichotomy formed early in the geologic evolution of Mars. Tectonic features along the dichotomy boundary suggest late-stage modification by flexure or relaxation of the highlands after volcanic resurfacing of the northern lowlands. Subsequent deposition and erosion by fluvial, aeolian, and glacial processes shaped the present-day dichotomy boundary.
http://arjournals.annualreviews.org/doi/abs/10.1146/annurev.earth.35.031306.140220
  • #129
James Essig said:
Hi baywax;
Thanks;
Jim Essig
Pretty complicated James! But, the big rocket idea seems more plausible than the idea of drilling into an asteroid and precisely planting a nuke for max. even distribution of energy. Besides, Bruce Willis probably isn't willing to risk his neck again for this one (re: the movie: Armageddon, 1998)
How about building boosters on Earth to get us out of the way!? Either way, I think there are groups who have dug themselves in for an occasion such as this. They've stashed their gold, oil, food, SUVs and swimming pools deep under the Rockies etc... Too bad they'll be the only ones representing the human race when all the dust, ash and crust settles.:-(
  • #130
Hi stewartcs and DaveC426913;
In fact I heard on the Discovery Channel that an asteriod of the size of that which blasted out the Yucatan Peninsula and perhaps killed off the dynosuars may have turned the entire atmosphere of planet Earth into a broiler thus killing any dynosuars that would have survived the initial blast wave as it circled the globe. Accordingly, there would be so much glowing red hot and white hot debris shot out into orbit around the Earth that the black body thermal emmissions from such debris would have roasted the surface of the Earths land mass and might have even caused ponds and shallow lakes to begin bioling. The animals that survived would be of the types that could borrow underground or dive underwater to take advantage of the thermal inertia of the ground and deep water.
Hi baywax;
I not sure what we could do if we saw a 6 to 10 mile wide asteriod heading for Earth and due to impact in a couple of weeks wherein the asteriod was of dark surface color and therefore missed by astonomers until a few weeks before doomsday. I suppose I would break out my grill or try to buy an outdoor turkey smoker and cook some real good final barbecued food. In such a case, mankind might have to impart on a crash course to produce as many nuclear warheads as we could and of unprecedented yield and let the asteriod have it either by many simultaneous and/or repeated direct hits or via stand off blasts that would gradually nudge the sucker out of the way via the surface layer high pressure gas prooducing ablative effects of the stand off nuclear detonations. In this scenario, short of this, I can't see what else we could do. In such a case, I completely agree with you that, unfortunately, all that humanity would have left to represent us after the smoke, fire, and dust settled out would be those folks hold up deep underground with those SUVs, oil depos, gold, food, and swimming pools: a rather scary thought!.
Thanks;
Jim
  • #131
That was my point! It wouldn't matter where it hit on Earth if it was big and fast enough.
CS
  • #132
James Essig said:
... an asteriod of the size of that which blasted out the Yucatan Peninsula and perhaps killed off the dynosuars may have turned the entire atmosphere of planet Earth into a broiler thus killing any dynosuars that would have survived the initial blast wave as it circled the globe. Accordingly, there would be so much glowing red hot and white hot debris shot out into orbit around the Earth that the black body thermal emmissions from such debris would have roasted the surface of the Earths land mass and might have even caused ponds and shallow lakes to begin bioling.
To my ear this sounds like quite an exaggeration of generally plausible and accepted events, but I can not be sure.
  • #133
James Essig said:
Hi baywax;
Thanks;
Jim
Its interesting that you noted the low reflectivity and high light-absorbency of some asteroids... to the point of only reflecting 4 percent of the light hitting them.
That makes them particularly scary. These are called "ghouls" by some astronomers. Very hard to detect and therefore a cause for the learned types to be paranoid at all times.
Why not strike up the BBQ every day or the equivalent since it could be any day of the century that this impact could happen, with no one the wiser... except the outlandishly paranoid types who, at this very moment, are living underground, in artificial light, because they know there is very little warning about a bollide event taking place and being caused by a "GHOUL"!
This is an interesting topic, mind you, and I think we could come up with a solution that would favour the people of the Earth if we really put some effort into it. Your multiple hits from all angles by nukes is a good start. It would just have to be far enough away from Earth to help us avoid the radon clouds etc..
Another disconcerting thought is... we have never, overtly, exploded a nuke in space so we need to know what those effects are before we do. Who knows, it might cause a chain reaction of black holes sucking our solar system into another universe... beam me up Scottie!
  • #134
Hi baywax;
Thanks for the interesting info regarding the actual reflectivity of the GHOULS and related nomenclature.
It is hard to be certain what the extreme effects of space based nuclear detonations could be. I have heard of quasi-scientific notions that such effects could by chance produce electromagnetic space time bridges to other locations in space time including into the past or future. The result accordingly would be an electromagnetic wormhole produced by the device's low frequency electromagnetic pulse. If such could be produced, it might perhaps be dangerous for our civilization or life on Earth if the electromagnetic wormhole provided a link between the present and the past wherein energy or information could be transmitted into the past into the Earth wherein it might pose the possibility of changing the present in drastic ways.
Certain theories on the possible pluasibility of time travel suggest that a temporal causality censorship principle would prevent the travel into the past by persons, information, or energy form interfering with the present even in consideration of free will in the sense of actions not being completely determined by their causes. One version of such a conjecture holds that if a time traveler tried to change the present by changing the past freely or was in positions to perform a deterministically constrained act that could do such, nature would act to prevent such from happening such as by causing the time traveler to suddenly pop back into the present time and location from whence he left.
Another possibility is that such a time traveling act would result in the chance in the present to be realized in a parallel history of the type simmilar to those conjectured to exists in the "Many Worlds Interpretation" of quantum theory in which each act of the collapse of a wavefunction causes a branch of parallel history to be formed. Accordingly. there are ensembles if not infinities of new complete parelell histories forming all of the time as a result of each naturally occurring quantum act of decoherence even on microscopic particle levels.
If such electromagnetic wormholes are possible by remote chance, perhaps brought on by a chance electromagnetic low frequency radiation pattern of flux distribution, there is a real possibility that it could be very dangerous.
I think I remember that in the original "Planet of the Apes" series of books and movies, such an electromagnetic time warp is what caused the fusion powered long duration flight relativistic starship launched from Earth to enter a time portal and travel a few hundred years into the future wherein the crew members that survived the suspended animation process eventually came to realize that they had landed back on Earth in the distance future wherein the civilization that they had left behind was destroyed in a global nuclear holocuast.
I don't know if such electromagnetic time portals can exist but I can think of some additional ways that they might be realized although only in a general sense although I have no idea how one would actually be produced in detail either artificially or naturally. One way to view the electromagnetic force is that it is a fundamental force just like general relativistic gravity for which there is mounting mathematical and theoretical evidence that wormholes into the past, future, cosmically remote locations in space time within our universe can exist, and perhaps also travel into other universes or Big Bangs that remain at least causally weakly coupled to our universe or wherein such causality and information exchange ability, even if normally dorment, can be activited by rare natural or perhaps be artificial general relativistic gravity based wormholes on demand.
This, however, is a very fascinating subject to me as well.
Thanks;
Jim
  • #135
James Essig said:
Hi baywax;
Thanks;
Jim
I was going to suggest using sonic energy to break a bollide apart but... sound can't travel in space.:-, (and that wouldn't suit the Nuclear Engineering section of PF anyway!)
  • #136
Dunno if its been said already. Discover did a similar article about satellite destroying, and the science channel has done a show on it.
  • #137
Pentagon prepares to destroy defunct spy satellite
The US Navy isn't going to launch a nuke at the broken spy satellite but this is a first for the the Pentagon. After criticizing China for blowing up one of its own worn satellites, the Pentagon has decided its the only option for this one or have it raining down rocket fuel on potential, earth-bound victims.
So I thought this story was along the lines of this thread in the terms that there will be a launch and it will be aimed at an orbiting body in space.
http://news.yahoo.com/s/ap/20080214/ap_on_go_ca_st_pe/dead_satellite
  • #138
Hi baywax;
Thanks for providing the above link. I should be an interesting test of the missile's capabilities.
Regards;
Jim Essig
  • #139
Apparently the missile to be used to intercept the satellite is a Standard Missile 3, a product of Raytheon. I uses a conventional warhead, not a nuclear warhead.
http://www.globalsecurity.org/space/systems/sm3.htm
  • #140
Hi again;
It occurred to me inorder to completely avert the risk of material hitting the ground, perhaps the interceptor missle could be fitted with a 1 kiloton to 5 kiloton nuclear device that detonates a few meters away from the sattelite via proximatety sensor to completely ionize the sattelite. There might be some radiation risk but not as much radioactive fallout as a ground burst would produce.
Thanks;
Jim Essig
  • Astronomy and Astrophysics
17K
11K
  • Nuclear Engineering
