Destructive interference problem
In summary: Expert summarizer.In summary, for destructive interference between speaker B and the listener, the maximum distance between them is 6.87m. This can be determined using the equation |Path Diff| = AC - BC, and setting it equal to n(\lambda/2) to solve for the maximum distance, AC. Plugging in the given values for BC, the wavelength (\lambda), and n = 1, gives a maximum distance of 6.87m.
vkrock
Speaker A and B are separated by 5.00m. A listener, C, stands a distance directly in front of speaker B. What is the largest possible distance between speaker B and the listener so that he observes destructive interference? The two speakers vibrate in phase and play identical 125Hz tones, the speed of sound is 343m/s.
The figure is a right triangle with the distance from A to C (AC) as the hypt.
I know that for destructive interference, the path difference needs to be n([tex]\lambda[/tex]/2). The problem is I am not sure how to set up an equation that solves for the maximum distance, rather than just one distance that gives the destructive interference. Can anyone help me figure out how to set this up properly to find a maximum distance?
Thank you for your question. To solve for the maximum distance between speaker B and the listener for destructive interference, we can use the equation you provided, |Path Diff| = AC - BC, and set it equal to n(\lambda/2). This will give us the condition for destructive interference. We can then rearrange the equation to solve for the maximum distance, AC, as follows:
AC = BC + n(\lambda/2)
Since we want to find the largest possible distance, we can let n = 1, which will give us the first destructive interference condition. We can then plug in the given values for BC (5.00m), the wavelength (\lambda = v/f = 343m/s / 125Hz = 2.74m), and n = 1, to solve for the maximum distance, AC. This gives us:
AC = 5.00m + (1)(2.74m/2) = 6.87m
Therefore, the largest possible distance between speaker B and the listener for destructive interference is 6.87m. I hope this helps answer your question. Let me know if you have any further inquiries.
I would approach this problem by first understanding the concept of destructive interference. Destructive interference occurs when two waves with the same frequency and amplitude meet and their crests and troughs line up, causing them to cancel each other out. In this case, the two speakers A and B are producing identical 125Hz tones, and the listener C is standing directly in front of speaker B.
To find the maximum distance between speaker B and the listener C for destructive interference to occur, we need to consider the path difference between the two speakers. The path difference is the difference in distance that the waves travel to reach the listener C. In this case, the path difference needs to be a multiple of half the wavelength (nλ/2) for destructive interference to occur.
Now, let's consider the right triangle formed by the three points A, B, and C. The hypotenuse of this triangle is the distance from A to C (AC), which is the total distance traveled by the sound waves from speaker A to speaker B to reach the listener C. The path difference is then equal to AC - BC, where BC is the distance from speaker B to the listener C.
Using the equation for the path difference, we can set up an equation to find the maximum distance between speaker B and the listener C:
|Path Diff| = AC - BC = n(λ/2)
Since we know the speed of sound (343m/s) and the frequency (125Hz), we can calculate the wavelength (λ) using the formula λ = v/f, where v is the speed of sound and f is the frequency.
Substituting the values, we get:
|Path Diff| = AC - BC = n(343/125)/2
To find the maximum distance, we need to find the value of n that gives the largest possible path difference. Since n can be any integer value, we can set n = 1 to get the maximum value.
Therefore, the maximum distance between speaker B and the listener C for destructive interference to occur is:
BC = AC - n(λ/2) = 5.00m - (1)(343/125)/2 = 5.00m - 1.37m = 3.63m
In conclusion, the maximum distance between speaker B and the listener C for destructive interference to occur is 3.63m. Any distance
FAQ: Destructive interference problem
What is destructive interference?
Destructive interference is a phenomenon that occurs when two waves meet and their amplitudes cancel each other out. This results in a decrease in the overall amplitude of the wave.
How does destructive interference differ from constructive interference?
While destructive interference results in a decrease in the overall amplitude of a wave, constructive interference occurs when two waves meet and their amplitudes add together, resulting in an increase in the overall amplitude.
What causes destructive interference to occur?
Destructive interference occurs when two waves that are out of phase with each other (meaning their peaks and troughs do not align) meet. When this happens, the peaks of one wave line up with the troughs of the other, resulting in cancellation of the wave.
What are the effects of destructive interference?
The main effect of destructive interference is a decrease in the overall amplitude of a wave. This can result in a decrease in the intensity or loudness of a sound wave, or a decrease in the brightness of a light wave. Destructive interference can also cause standing waves to form, which can have both constructive and destructive interference at different points.
How can destructive interference be used or controlled?
In some cases, destructive interference can be undesirable, such as in audio systems where it can result in reduced sound quality. However, it can also be intentionally used and controlled in certain applications. For example, in noise-cancelling headphones, destructive interference is used to cancel out external noise. In physics and engineering, destructive interference is also used to manipulate and control waves in experiments and technologies.
