Detailed Balance: meaning?
  1. May 28, 2010 #1
    Hey,
    I was wondering in what way the detailed balance condition (DBC) has to do with thermodynamic equilibrium.
    The DBC is defined as
    [tex]
    W(i\to j)P(i) = W(j\to i)P(j)
    [/tex]
    with W the rates (probabilities per unit time) to jump from state i to j. P(i) is the equilibrium prob. density to have state i, this could be e.g. a Boltzmann Gibbs distribution in case of canonical equilibrium.
    When for a (Markov jump) proces the above equality holds, then the system is time-reversible: it is even likely to follow a path forward in time or backwards in time
    My question is:
    The above formula is always possible to write down, but how is this related to equilibruim?
  3. Jun 1, 2010 #2
    It is obvious that the probability distribution must not change by the flows. So you see that your equation states that the same amount of thingamajigs are jumping from i to j as from j to i. Hence the distribution stays the same under time evolution. If you know W then you can derive an equilibrium distribution with the DBC.
    If the DBC holds than P is an equilibrium distribution. I am not sure if the inverse direction is also true.
