Detection Methods: Heterodyne, Differential, Normal & Homodyne
In summary, the conversation discusses the differences between various types of detection, including heterodyne, differential, normal, and homodyne. The speaker suggests looking up the definitions and explanations on Wikipedia or Google, or using a textbook. They also mention the timing detection requirement for differential detection and the difference in terminology between optical and electrical homodyne/heterodyne detection.
watertreader
23
Hi,
Just a query...
what is the differences between this types of detection and their usage?
a) heterodyne
b) differential
c) normal
d) homodyne?
We don't do homework assignments.
Just go to Wikipedia or Google and look them up.
eg
http://en.wikipedia.org/wiki/Homodyne
Even your textbook from school will have nice diagrams and a carefully written explanation.
not a homework assignment...
actually i am more concerned with the timing detection requirement of differential detection... for a heterodyne detection, we need to capture 2 cycle of change to determine the heterodyne signal..what about differential?
also for homodyne and heterodyne detection... heard there is a difference in the terminology between optical and electrical homodyne/heterodyne..what/why the diff?
1. What is the difference between heterodyne and homodyne detection methods?
Heterodyne detection involves mixing the signal of interest with a local oscillator signal to generate a new frequency. Homodyne detection, on the other hand, uses only the signal of interest without any mixing.
2. How does differential detection work?
Differential detection involves comparing two signals, usually the received signal and a reference signal, to extract the desired information. This method is commonly used in communication systems to improve signal quality.
3. What is the purpose of using a normal detection method?
Normal detection is used to recover the original information from a modulated signal. It involves demodulating the signal using a detector circuit to extract the desired information.
4. How do scientists choose which detection method to use?
The choice of detection method depends on the specific application and the type of signal being detected. Factors such as signal-to-noise ratio, bandwidth, and complexity of the signal can influence the selection of the most suitable detection method.
5. Can multiple detection methods be used together?
Yes, it is possible to combine different detection methods to improve the overall performance. For example, heterodyne and homodyne detection methods can be used together to achieve higher sensitivity and selectivity in detection applications.
  • Quantum Physics
  • Electrical Engineering
  • Biology and Medical
