Determinant of a 3X3 matrix
  • Thread starter snoggerT
M= |3-2x^3_____-4+2x^2+4x^3______0|
|-x^3________1+x^2+2x^3_______0|
|-8-6x^2_____16+12x^2____-1-3x^2|
find the determinant.
* I put the underscores for spacing.
I first tried finding det(A) as if it was a regular matrix of numbers, but that doesn't seem to work. So I'm really not sure how to find the determinant for a matrix of polynomial equations. Where would you actually start?
Answers and Replies
Astronuc
Staff Emeritus
2,952
Well, one can use the fact that the third column has two zeros as entries.
Think about
I'm not quite getting what I'm supposed to see from the 2 zeros. The way I worked it out before was using the normal determinant method of a11(a22*a33-a32*a23)-a12...etc. Would that not be the correct way to find a determinant for this type of matrix?
kdv
348
It should work! If it does not work, check your calculation. It's really the same as the determinant of a matrix of numbers. The fact that there are two zeroes will make the final result not too awful looking. But it's the usual formula for the determinant of a 3 by 3 matrix.
EDIT: give your answer (before expanded out) and we can check if you made a mistake
Astronuc
Staff Emeritus
2,952
That would be one way. The co-factor expansion (or determinant expansion by minors) can be done on any column or row! If one does is using the third column, one sees a33|A33|, where A33 is the 3,3 minor.
http://mathworld.wolfram.com/DeterminantExpansionbyMinors.html
See the examples here - http://en.wikipedia.org/wiki/Laplace_expansion - using first row or second column. One can also use the third row or third column.
Related Threads on Determinant of a 3X3 matrix
  • Last Post
  • Last Post
  • Last Post
  • Last Post
9K
  • Last Post
  • Last Post
  • Last Post
