Homework Help: Determine closed expression
  1. Apr 10, 2012 #1
    determine a closed expression for b(n), given
    b(0) = 3
    b(n+1) = 2+[itex]\prod[/itex] (k=0 to n) * b(k) , n >= 0 , without using recursion og or the product given by [itex]\prod[/itex].
    I wanna start out by b(n+1) -1 = (b(n)-1)^2 for n >= 0 , but im not sure.
    kind regards
    Maxmilian
  3. Apr 10, 2012 #2
    Ray Vickson
    What does the word "wanna" mean?
    Have you tried writing out the first few b(k), to see if there is any discernible pattern?
    RGV
  4. Apr 10, 2012 #3
    oh sry, wanna is my street slang for "want to".
    And no I havent
  5. Apr 10, 2012 #4
    Curious3141
    The usual way to tackle this sort of problem is to write out the first few terms of the sequence, discern the pattern, then prove it by induction.
    Hint: think in terms of powers of 2 plus a little something.
  6. Apr 10, 2012 #5
    Thx for your reply.
    so for n = 1 , im getting ;
    2 + b(0) *b(1) = 2 + 3 * b(1)
    for n = 2 ;
    2 + 3 * b(1) * b(2)
    edit: could 2+3*b(n)! be a solution to the pattern ?
    Can anyone give me a hint for what I should do next ?
  7. Apr 10, 2012 #6
    any help is still appreciated
  8. Apr 10, 2012 #7
    Curious3141
    No.
    b(n+1) = 2 + ∏(k from 0 to n) b(k)
    So b(1) = 2 + ∏(k from 0 to 0)b(k) = 2 + b(0) = 2 + 3 = 5.
    Can you now work out b(2), b(3), b(4) and b(5)? Try and see the pattern, then I (or someone else) can guide you through the induction if you still have problems.
  9. Apr 10, 2012 #8
    then
    b(2) = 2 + ∏(k from 0 to 1)b(k) = 2 + b(0)*b(1) = 2 + 3*b(1)
    b(3) = 2 + ∏(k from 0 to 2)b(k) = 2 + b(0)*b(1)*b(2) = 2 + 3*b(1)*b(2)
    b(4) = 2 + ∏(k from 0 to 3)b(k) = 2 + b(0)*b(1)*b(2)*b(3) = 2 + 3*b(1)*b(2)*b(3)
    b(5) = 2 + ∏(k from 0 to 4)b(k) = 2 + b(0)*b(1)*b(2)*b(3)*b(4) = 2 + 3*b(1)*b(2)*b(3)*b(4)
    right ?
  10. Apr 10, 2012 #9
    Curious3141
    Yes, but calculate them (get the final numbers).
    You should be able to make out the pattern clearly by b(4). b(5) is a little large, so you may not want to bother with that.
  11. Apr 10, 2012 #10
    right.
    b(2) = 17
    b(3) = 257
    b(4) = 65537
    as far as a pattern goes for b(n) , I think I have a good idea (Fermet)
  12. Apr 10, 2012 #11
    Curious3141
    Yes, they are Fermat numbers. Now prove it by induction.
  13. Apr 10, 2012 #12
    is recursion not a part of induction ?
    I might have misunderstood the "determine the closed expression - without using recursion" wrong. but if I wanted to prove it by induction. I would;
    1. prove the basis ;
    b(0)=2^(2^0) +1 = 3 , true , basis proven.
    2. prove inductionstep
    b(n) -> b(n+1)
    b(n) = 2^(2^n) +1 -> b(n+1)=2^(2^n+1) +1
    b(1) = 2^(2^1) +1 = 5 -> b(1+1)2^(2^1+1)+1 = 17
    both n and n+1 is true, so I have proven it for both n and n+1 - right ?
  14. Apr 10, 2012 #13
    Curious3141
    What I mean is that you need to prove the closed form expression by mathematical induction. You've only inferred a pattern by observation, but you haven't rigorously proven it.
    Of course, you need to use the recursive relation in your proof. But it needs to be a formal inductive proof, starting with an inductive hypothesis.
  15. Apr 10, 2012 #14
    Curious3141
    Let P(n) be the proposition that b(n) = 2^(2^n) + 1. This is the inductive hypothesis which you start by assuming.
    From this, you need to establish that P(n+1) is true, i.e. that b(n+1) = 2^(2^(n+1)) + 1.
    This needs to be an algebraic (symbolic) proof. Just verifying it for certain numerical n's is not sufficient.
  16. Apr 10, 2012 #15
    right.
    so I start with my hypothesis, then prove basis , then assume P(n) is true , then last prove P(n+1) is true. How do I prove P(n+1) is true?
  17. Apr 11, 2012 #16
    Curious3141
    Wanted to reply to this earlier, but a lot of things came up.
    So assume P(n) is true. Hence you can write down b(n) = 2^(2^n) + 1
    Now you have to use this given relation: b(n+1) = 2 + ∏(from 0 to n) b(k)
    to somehow arrive at b(n+1) = 2^(2^(n+1)) + 1
    which would establish P(n+1).
    Here's a hint:
    ∏(from 0 to n) b(k) = b(n) * ∏(from 0 to (n-1)) b(k)
    and
    b(n) = 2 + ∏(from 0 to (n-1)) b(k),
    so ∏(from 0 to (n-1)) b(k) = b(n) - 2
    Can you put all that together and do the remaining algebra to prove the result?
