Calculating ΔS for Mixing H20 and D20 Solutions
  • Thread starter ebunny91
  • Tags
    Mixing
In summary: J/mol) = 24.04 kJ. This means that the total enthalpy of the mixture will be lower than in part a, since we are adding energy to melt the solid D20. This will result in a lower entropy change.Step 5: Understand the resultsThe change in entropy for part a is positive, meaning that the mixture will become more disordered (higher entropy) when the two substances are mixed together. This is because the two liquids form an ideal solution, meaning they mix evenly and there is no energy required for mixing. In part b, the change in entropy is smaller because we are adding energy to convert the solid D20 into liquid D20. This means that the mixture will not be
ebunny91
For both H20 and D20:
Cp = 75.5 J/mole-k for the liquid Cp = 37.8 J/mole-k for the solid ΔHfus=6.01 kJ/mole.
Liquid H20 and D20 form an ideal solution.
a) One mole of liquid H20 at 10 C is mixed with four moles of LIQUID D20 at 0 C in an insulated container.
Determine ΔS.
b) One mole of liquid H20 at 10 C is mixed with four moles of SOLID D20 at 0 C in an insulated container.
Determine ΔS.
ΔSmixing = -R(nX1lnX1 + nX2lnX2)
I found
ΔSmixing = -R(nX1lnX1 + nX2lnX2) = -8.324[(1mol)(1/5)ln(1/5) + (4mol)(4/5)ln(4/5)] = 8.612 j/mol-k
I don't really understand the question. Can someone explain some of he concepts I need to know or direct me to somewhere where it sums it up?
What are the steps to solving this? What do I have to think about? (Like...I know X, so I get Y because of Z)
Hi there! Let's break down the problem and go through the steps to solve it.
Step 1: Understand the problem
The problem is asking you to calculate the change in entropy (ΔS) when mixing different quantities of liquid H20 and D20 at different temperatures. The given information includes the specific heat capacity (Cp) and the enthalpy of fusion (ΔHfus) for both substances.
Step 2: Identify the relevant equations
The equation you need to use is ΔSmixing = -R(nX1lnX1 + nX2lnX2). This equation relates the change in entropy to the number of moles (n) and the mole fraction (X) of each substance in the mixture. R is the gas constant, which has a value of 8.314 J/mol-k.
Step 3: Determine the number of moles and mole fractions
a) In the first scenario, we have 1 mole of liquid H20 and 4 moles of liquid D20. The total number of moles is 5. The mole fraction of H20 is 1/5 = 0.2, and the mole fraction of D20 is 4/5 = 0.8.
b) In the second scenario, we have 1 mole of liquid H20 and 4 moles of solid D20. The total number of moles is still 5. However, since the D20 is now in its solid form, we need to consider its enthalpy of fusion. This means that we need to take into account the energy required to convert the solid D20 into liquid D20. This will affect the mole fraction of D20 in the mixture.
Step 4: Calculate the change in entropy
a) Plugging in the values from part a, we get ΔSmixing = -8.314[(1mol)(0.2)ln(0.2) + (4mol)(0.8)ln(0.8)] = 8.612 J/mol-k.
b) For part b, we need to consider the change in enthalpy when converting the solid D20 into liquid D20. This can be calculated using the enthalpy of fusion (ΔHfus) and the number of moles of D20. The enthalpy change for this process is ΔH = (4mol)(6.
1. What is ΔS in the context of mixing?
ΔS, or change in entropy, measures the amount of disorder or randomness in a system. In the context of mixing, it refers to the change in entropy that occurs when two or more substances with different properties are combined or mixed together.
2. How is ΔS calculated when mixing substances?
The equation for calculating ΔS when mixing substances is ΔS = ΣnΔS°products - ΣmΔS°reactants, where n and m are the coefficients of the products and reactants in the balanced chemical equation, and ΔS° is the standard entropy change for each substance. The sum of the products' entropies is subtracted from the sum of the reactants' entropies to determine the overall change in entropy.
3. What factors affect ΔS when mixing substances?
The main factors that affect ΔS when mixing substances are the nature and amount of the substances being mixed, as well as the temperature and pressure of the system. Generally, substances with higher molar masses and more complex structures will have a greater ΔS, while substances with lower molar masses and simpler structures will have a lower ΔS.
4. How does mixing affect the overall entropy of a system?
Mixing substances typically results in an increase in the overall entropy of a system. This is because the substances become more dispersed and disordered, leading to a greater number of possible arrangements or states. The second law of thermodynamics states that the entropy of a closed system will always increase over time, making mixing a spontaneous process that leads to a greater overall entropy.
5. Can ΔS be negative when mixing substances?
Yes, ΔS can be negative when mixing substances, although this is less common. This can occur when the products of the mixing have a lower entropy than the reactants, such as when two substances with highly ordered structures are mixed together. However, the overall change in entropy for the system will still be positive, as the mixing process itself increases the entropy of the system.
21K
