Homework Help: Determine Lift
  1. Oct 21, 2007 #1
    I have recorded raw pressures for from a wind tunnel for a NACA 0012 airfoil with 30 surface pressure taps.
    I have computed Reynolds Number for 3 angles of attack.
    I have computed the Pressure Coeff. for each pressure and graphed them verses the non-dimensionalized tap locations.
    This is where I am stuck:
    Numerically integrate the pressure distribution ( trapezoidal rule) to estimate lift.
    2. Relevant equations
    [tex]F_{N}=\int_{x=0}^{c}(p_{u}-p_{l})dx[/tex]
    [tex] F_{A} = \int_{x=0}^{c}(p_{u})(\frac{dy}{dx})_{u}+(p_{l})(\frac{dy}{dx})_{l}dx[/tex]
    [tex] L = F_{N}cos(\alpha)-F_{A}sin(\alpha)[/tex]
    F_{A} is axial force and F_{N} is normal force
    Pu is upper surface pressure, Pl is lower surface.
    3. The attempt at a solution
    I am completely stuck.
Draft saved Draft deleted
