Determine the radius of a rising bubble
In summary: Pa = 101325 N/m². You can't just add 1 atm to 292 N/m². You need the full weight of the water column (and the bubble) on top of it.##P_2=ρgh_2+\frac {2σ} {r_2}#### = 1000*9.81*0.1+292####P_2=1273####V_1=\frac {4} {3} πr^3####V=\frac {4} {3} π(0.0005)^3####V_1=5.23*10^{-10
Sabra_a
33
A small air bubble at the bottom of an open 4-m depth water tank
has a radius of 0.5 mm. Due to some reason the bubble comes off
the bottom. Determine the radius of the bubble when it is 0.1 m
below the surface. Assume that the pressure inside the bubble is
2/r above the pressure outside the bubble, where  =0.073 N/m –
the surface tension of water-air and r – the radius of the bubble. The
pressure and volume of the air in the bubble are related by the
expression pV=const.
ρ=2 σ/r
P=ρgh+P
Homework Statement: A small air bubble at the bottom of an open 4-m depth water tank
Homework Equations: ρ=2 σ/r
P=ρgh+P
I calculated the pressure inside the bubble multiplying 2 into the given surface tension and the reduce I'm not sure if I should convert the mm to m for the radius or its not required.
ρ=2 σ/r
ρ=2 0.073/0.5
ρ= 0.292
the substituted that in P=ρgh+P
= (0.292)(9.81)(4) + 101300
=101311.4
this is what I did so far
Likes berkeman
Good recovery ! :welcome: back .
Now what about this PV = Const equation ?
And: what you did for h = 4 you can also do for h = 0.1
Help me understand the units you use. 0.292 stones/cubic inch ?
Likes berkeman
Thank you!
I think I should convert he radius unit to m from 0.5mm to 0.0005 m.
ρ=2 σ/r
ρ=2 (0.073N/m/0.0005m)
ρ= 292 N/m2 or Pascal
= (292)(9.81)(4) + 101300
=112758.08
when h = 0.1
= (292)(9.81)(0.1) + 101300
= 101586.452
PV= constant
maybe rearrange the equation to calculate volume! PV=nRT but we don't have the n and T
No, but we do have p and V at 4 m depth ... so we have the constant nRT !
Likes WWGD
so we calculate the volume of sphere by V=
V= 3/4 * 3.14 * (0.0005)3
= 2.94x10^-10
PV=constant
112758.08 * 2.94x10^-10
3.32x10^-5
Explain, please ...
Tip: use symbols, not numbers. And at the end: first check dimensions, then finally substitute to get a number + dimension for the answer. Oh, and don't let the number of significant digits explode. One or, tops, two -- like in the given information.
p at a depth of 4 m is bigger than 1.1 x 105 N/m2
because we have pressure we need to calculate volume by calculating the volume of sphere V=
radius = 0.0005 m
V= (3/4) * (3.14) * (0.0005)^3
= 2.94x10^-10 m^3
substituting the volume value in PV=constant
P and V at 4 m depth
PV=constant
(112758.08 * 2.94x10^-10) = constant
3.32x10^-5 = constant
as we have pressure and volume at 4 m depth but we have only pressure at 0.1 m we can use the following equation
P1V1=P2V2
V2 = P1V1/P2
V2 = 3.32x10^-5 / 101586.452
= 3.26x10^-10
Sabra_a said:
because we have pressure we need to calculate volume by calculating the volume of sphere V= View attachment 252197
radius = 0.0005 m
= 2.94x10^-10 m^3
PV=constant
P1V1=P2V2
V2 = P1V1/P2
= 3.26x10^-10
Your equation for the volume is incorrect. It is 4/3, not 3/4. In addition, you did not take into account the effect of surface tension in getting the pressure within the gas bubble at the 0.1 m depth.
Likes Sabra_a
volume of sphere
= 4/3 * 3.14 * r^3
= (4/3) * (3.14) * (0.0005)^3
= 5.23x10^-10 m3
I don't really get how to solve this question
by take into account the effect of surface tension at 0.1 m depth do you mean adding it to the equation
P=ρgh+P+ surface tension
Sabra_a said:
volume of sphere
= 4/3 * 3.14 * r^3
= 5.23x10^-10 m3
$$P_1=\rho g h_1+\frac{2\sigma}{r_1}$$
$$P_2=\rho g h_2+\frac{2\sigma}{r_2}$$$$P_2V_2=P_1V_1$$
$$V=\frac{4}{3}\pi r^3$$
Likes DEvens and Sabra_a
P=ρgh+P
There are some things utterly wrong here !
I recognize the second one by its form but not in the way presented (leads to ##\rho g h = 0##) . But that is definitely NOT the ##rho## in the first.
@Sabra_a : urgent advice to make good use of the tips in #6. Observe how much clearer things become when you use symbols, as @Chestermiller demonstrates in #10 ! You can count knowns, unknowns and number of equations to check if you have enough to start calculating, you can check dimensions, strike common factors, etc. etc. Much less prone to errors and easier to fix should you discover a mistake on the way.
I hope this is clear now
##P=\frac {2σ} {r}##
r = 0.5mm →m = 0.0005m
##P=\frac {2*0.073N} {0.0005m}##
##P=292 N/m^2##
density of water = 1000 ##kg/m^3##
##P_1=ρgh_1+\frac {2σ} {r_1}##
## = 1000*9.81*4+292##
##P_2=39532##
##P_2=1273##
##V_1=5.23*10^{-10}##
##P_2V_2=P_1V_1##
##V_2=\frac {P_1V_1} {P_2}##
##V_2=1.62*10^{-8}##
##P=292 N/m^2##
##P_2=39532##​
You forgot to include atmospheric pressure in this calculation. If you are using the ideal gas law later, you need to use absolute pressures.
##P_2=1273##
You again forgot to include atmospheric pressure here. And the surface tension contribution is not 292 since you don't even know r2 yet.
This is correct.
##P_2V_2=P_1V_1##
This is incorrect because you need to use absolute pressures.​
##P=292 N/m^2##
##P_1=ρgh_1+\frac {2σ} {r_1}+P##
## = 1000*9.81*4+292+101300##
##P_1=140832##
##P_1V_1=constant##
##140832 * 5.23*10^{-10}=const.##
##7.36*10^{-5}=const.##
##P=292 N/m^2##
##P_1=140832##
##P_1V_1=constant##
OK so far. How much do you think the surface tension term contributes to the final answer?
as the bubble move upwards it grows in size, so as the volume increase pressure outside the bubble drops therefore surface tension increases!
Actually, as the radius of the bubble increases, the contribution of surface tension to the pressure of the gas inside the bubble decreases. And you have already shown that for the depth of 4 m, the surface tension contribution to the pressure is only 292 Pa out of 140832 Pa, or much less than 1%. You will find that the surface tension contribution at the shallower depth will be even less. So, you might as well neglect surface tension. But it's very minor effect can still be included if you really want to.
I will probably include it, but how I will be able to calculate the radius at 0.1 m?
You have a non-linear algebraic equation to solve, right? What methods do you know of for solving a non-linear algebraic equation?
##ax+b=0##
##x=-b/a##
Sabra_a said:
##ax+b=0##
##x=-b/a##
I said non-linear.
Let me summarize what you have so far: $$P_1\left(\frac{4}{3}\pi r_1^3\right)=P_2\left(\frac{4}{3}\pi r_2^3\right)$$ or, equivalently $$P_1r_1^3=P_2r_2^3$$with $$P_1=P_{atm}+\rho g h_1+\frac{2\sigma}{r_1}$$and$$P_2=P_{atm}+\rho g h_2+\frac{2\sigma}{r_2}$$Combining these equations gives:
$$(P_{atm}+\rho g h_1+\frac{2\sigma}{r_1})r_1^3=(P_{atm}+\rho g h_2+\frac{2\sigma}{r_2})r_2^3$$Next, defining $$x=\frac{r_2}{r_1}$$ we have:$$(P_{atm}+\rho g h_1+\frac{2\sigma}{r_1})=(P_{atm}+\rho g h_2+\frac{2\sigma}{r_1x})x^3$$Our objective is to solve for x. Do you agree with this so far?
yes I do agree
It is possible to solve this cubic equation in x analytically, but it is much easier to solve numerically. Any ideas on how to solve it numerically? Have you heard of the "method of successive substitutions?" What level of math have you had so far in your courses?
I have stopped uni 3 years ago, don't remember much but trying my best. is it fine like this
No. Your algebra is incorrect.
1. What is the radius of a rising bubble?
The radius of a rising bubble refers to the distance from the center of the bubble to its outer edge. It is a measure of the size of the bubble and can help determine its behavior and properties.
2. How is the radius of a rising bubble determined?
The radius of a rising bubble can be determined through various methods, such as direct measurement using specialized tools, or through mathematical equations based on the properties of the bubble, such as its volume, surface tension, and buoyancy.
3. Why is it important to determine the radius of a rising bubble?
Determining the radius of a rising bubble is important in understanding the dynamics and behavior of bubbles, which can have various applications in industries such as food and beverage, medicine, and materials science. It can also provide insights into fluid mechanics and surface tension.
4. Can the radius of a rising bubble change?
Yes, the radius of a rising bubble can change due to various factors such as changes in temperature, pressure, or composition of the surrounding fluid. It can also change as the bubble rises and interacts with its environment.
5. How does the radius of a rising bubble affect its rise rate?
The radius of a rising bubble can affect its rise rate, as larger bubbles tend to rise faster due to their higher buoyancy force. However, this can also depend on other factors such as the viscosity of the surrounding fluid and the presence of obstacles or other forces acting on the bubble.
