Determine the sum of the windage and friction losses for this motor
In summary, the windage and friction losses in a four-pole, star-connected, squirrel-cage induction motor are based on the line voltage, stator current, and speed-torque curve.
rob1985
24
Thread moved from the technical forums, so no Homework Template is shown
Hi I was wondering if someone could tell me the equation for finding out what the windage and friction losses are based on the information below. I've drawn the graph and I can work out the I/0, R0 and X0A four-pole, star-connected, squirrel-cage induction motor operates froma variable voltage 50 Hz three-phase supply. The following results were
obtained as the supply voltage was gradually reduced with the motor
running on no-load.
Stator line voltage 220 164 112 88 42
Stator line current (amperes) 6.8 5.4 3.9 3.8 3.7
Stator power (watts) 470 360 278 244 232
(a) By plotting a suitable graph from these results, determine the total of
windage and friction losses, the no load magnetising current II0
(assume no load current II0 is magnetising losses) and the equivalent
circuit magnetising circuit parameters R0 and X0.
You don't really have enough information for a precise calculation
but you can estimate .
It's magnetizing plus friction and windage losses.
At constant speed Friction / windage is independent of voltage but magnetizing loss is not.
Try a search on terms "Steinmetz magnetizing loss" , here was my first hit: http://web.eecs.utk.edu/~dcostine/ECE482/Spring2015/materials/magnetics/CoreLossTechniques.pdfHmmm. i see you have watts.
Was that measured with a wattmeter ?
If so, you might plot watts versus voltage but backward - start with high voltage of left and decreasing as you move right. . It'll be roughly asymptotic to friction and windage. That's because magnetizing loss is proportional to flux raised to some power, typically cited as 1.4 or 2.
So as you decrease voltage your magnetizing losses drop off quickly leaving the lion's share to friction and windage. Another estimate would be from RPM at no load and published speed-torque curve. Torque at observed slip is friction and windage.
Best way is to put it on a dynamometer and spin it, measure torque.
So how do I estimate what the losses are, is there a formula I can use
Read again carefully what @jim hardy told you.
i am another victim of this poorly explained HNC module. I'd be lost without John Birds book Electrical Circuit theory and technology but it is not an in depth discussion of electri motors.
From the little I have gleaned from the module the main losses are windage and friction with magnetics being ignored. Therefore surely the windage and friction losses are infact the V x I given as they are the sum total of the main losses.
Surely the magnetising current is the current supplied to he stator easily calculated with the line voltage and the stator power.
Did anyone get anywhere with this? I am looking into it now,
I've plotted my points on the graph and extrapolated to get windage and friction losses.
However struggling to find the no load magnetising power loss.
Aware that the power taken from the supply is virtually equal to the core losses in the motor but where to begin?
1. What is windage loss in a motor?
Windage loss in a motor refers to the energy loss caused by the movement of air around the motor's rotating parts. This can include losses due to air resistance and turbulence, which can decrease the efficiency of the motor.
2. How is windage loss calculated?
Windage loss is typically calculated by measuring the air flow and pressure around the motor's rotating parts, and then using mathematical equations to determine the resulting energy loss. This calculation can also take into account factors such as the motor's speed and size.
3. What is friction loss in a motor?
Friction loss in a motor refers to the energy loss caused by the friction between the motor's moving parts, such as bearings and gears. This can result in heat generation and decreased efficiency of the motor.
4. How is friction loss calculated?
Friction loss is typically calculated by measuring the force required to move the motor's parts against each other and then using mathematical equations to determine the resulting energy loss. This calculation can also take into account factors such as the type of lubrication used and the surface roughness of the motor parts.
5. Why is it important to determine the sum of windage and friction losses for a motor?
Knowing the sum of windage and friction losses for a motor is important because it can help determine the overall efficiency of the motor. These losses can significantly impact the motor's performance and can also affect its lifespan. By accurately calculating and minimizing these losses, the motor can operate more efficiently and effectively.
