Determine whether the following series converges
  • Thread starter Thread starter elliotician
    Series
The series \sum \frac{(n-1)^3}{\sqrt{n^8+n+2}} diverges based on the application of the Limit Comparison Test and the standard Comparison Test. The sequence behaves similarly to 1/n, leading to the conclusion that it does not converge to a finite limit. The inequality \frac{(1-1/n)^{3}}{n\sqrt{1+n^{-7}+2n^{-8}}} \geq \frac{1}{4n} was established for n \geq 2, confirming divergence. The discussion also highlighted common pitfalls in using LaTeX for mathematical expressions.
  • Understanding of series convergence and divergence
  • Familiarity with the Limit Comparison Test
  • Knowledge of the Comparison Test
  • Basic proficiency in LaTeX for mathematical notation
  • Study the Limit Comparison Test in detail
  • Explore the Comparison Test and its applications
  • Review LaTeX syntax for mathematical expressions
  • Practice problems on series convergence and divergence
Mathematics students, educators, and anyone studying series convergence, particularly those preparing for exams or working on calculus assignments.
elliotician
Determine whether the following series converges:
<br /> \sum \frac{(n-1)^3}{\sqrt{n^8+n+2}}<br />
Definition of convergence:
Let \sum a_{n} be a series.
If the sequence of (sn) partial sums converges to L (finite). Then we say the series converges to L or has sum L. If (sn) diverges we say \sum a_{n} diverges.
With some manipulation i can see the sequence acts like 1/n, thus the series \sum a_{n} would diverge. However i can't use 1/n as a comparison since we would not have an > bn. So I haven't been able to find a suitable divergent sequence.
So basically we need a sequence bn such:
\frac{(n-1)^3}{\sqrt{n^8+n+2}}}&gt;b_{n}
This doesn't need to hold for all natural numbers n we can have it for some n>=a.
And bn must of course be divergent
Next question, if someone can tell me why my LaTex isn't working that would be fantastic ?
Fixed your LaTeX. See below for what I did.
With some manipulation i can see the sequence acts like 1/n, thus the series \sum a_{n} would diverge. However i can't use 1/n as a comparison since we would not have an < bn. So I haven't been able to find a suitable divergent sequence.
So basically if the is a sequence bn such:
\frac{(n-1)^3}{\sqrt{n^8+n+2}}}&lt;b_{n}
Some of your beginning tex tags had a '\' character in them, and all of you ending tex tags had \ instead of /.
Regarding your problem, do you know the Limit Comparison Test? If you can show that the arbitrary term in your series is > 1/n, the Limit Comparison Test might be helpful.
Cheers, and crikey i made loads of mistakes in there - fixing :)
I think the arbitrary term in my series is less than 1/n except for very small values of n below zero, so 1/n isn't suitable.
With some manipulation we can express the nth term as as:
<br /> \frac{(1-1/n)^3}{n\sqrt{1+n^{-7}+2n^{-8}}}<br />
I'm not thinking clearly at the moment, need a break, but I think 1/4n would work though for n>=3.
You mean 1/n isn't suitable for the Limit Comparison Test?
If the arbitrary term in your series is less than 1/n, then the Comparison Test is no help, but try the Limit Comparison Test, if you know it. There is also the Ratio Test, which might be useful.
Also, you probably aren't interested in negative values of n. The index for series usually starts at 0 or 1. Not always, but usually.
I do know the limit comparison however i just get the sequence tending to 0 rather than a finite L. So doesn't seem to be of use
Comparison test should work for 1/4n, for n>=2
\frac{(1-1/n)^{3}}{n\sqrt{1+n^{-7}+2n^{-8}}}\geq\frac{1}{4n}\]
So by comparison test the series diverges?
No i meant for the comparison test, however if i use 1/n in the limit comparison i get an/bn tending to 0
You'd have to prove or show how you got that inequality in order to use it for the comparison test.
If you use 1/n for the limit comparison test, you should not get 0 if you start with your manipulated series.
I don't see your work using the limit comparison test, so can't comment on the correctness of your result. You shouldn't get a sequence that tends to zero -- maybe you meant the limit was zero.
That test works this way, with an being the general term in your series and bn being the one in 1/n.
If \lim_{n \rightarrow \infty} \frac{a_n}{b_n} = L \neq 0
and L is a finite number, then both series converge, or they both diverge. The wikipedia article (http://en.wikipedia.org/wiki/Limit_comparison_test) is somewhat misleading about when you can use this test. It's not just for convergent series. The external reference at the end of the wikipedia article I cited has a more complete presentation.
I haven't calculated this limit, so I can't tell if this test would have been conclusive. If you can actually prove the inequality you have in your last post, the comparison test tells you that your series diverges.
Ah no i made a mistake! (again!)
Limit comparison works, tends to 1 when i divide by 1/n.
Thanks!
So to conclude
By the standard comparison test:
since (1-1/n)^3 >= 1/2 for n>=2
and n\sqrt{1+n^{-7}+2n^{-8} <= 2n
we must have
<br /> \frac{(1-1/n)^{3}}{n\sqrt{1+n^{-7}+2n^{-8}}}\geq\frac{1/2}{2n}=\frac{1}{4n}\]<br />
More simply by the limit comparison test
\frac{(1-1/n)^{3}/n\sqrt{1+n^{-7}+2n^{-8}}}{1/n}\rightarrow\frac{1/n}{1/n}=1\]
elliotician said:
So to conclude
That's not true, try it for n=2 and n=3. Are you forgetting the ^3?
I meant n>=5 :)
  • · Replies 17 ·
