BayernBlues
- 65
In all the following problems state the variables or combination of variables
which should be plotted to check the suggested variation and state how the unknown
may be found ( through the slope and/or intercept of the best fitting straight line
y = m x + b.). Because you are not given any numerical data it is just required to
qualitatively describe you method of solution in few lines with schematic graphs.
here are a couple of examples:
The gas law for an ideal gas is PV = RT , P and T are measured variables, V is fixed and
known. Determine R.
The linear expansion of a solid is described by ℓ = ℓo ( 1 + α.Δt ) where ℓ and Δt are
measured variables, ℓo is constant but unknown. Determine α .
For the first one:
An increase in T will yield an increase in P because V is a fixed value. P is therefore the dependent variable while T is the independent variable. R is the coefficient to T therefore it will be the slope when P vs T is graphed.
My question is mainly how would I go about problems like this or more complicated than this. When it gives you an equation, two measured values, and a third one which is supposed to be a constant like g. How would you determine the constant?
