Determining Force of Fb: Homework Statement
  • Thread starter Eternal Sky
  • Tags
    Force
In summary, two forces, Fa and Fb, act on an object at the origin, with Fa having a force of 4500 N at an angle of 60 degrees and Fb at an angle of 140 degrees. The force of Fb can be determined by decomposing the vectors into vertical and horizontal components, as the object is in static equilibrium and the net force must be zero. This method is more effective than using the law of sines, as it results in the correct answer of 6890 N.
Eternal Sky
Two forces, Fa and Fb, act on an object located at the origin. Fa has a force of 4500 N and has an angle of 60 degrees with respect to the positive x-axis. Fb has an angle of 140 degrees with respect to the positive x-axis. Determine the force of Fb.
Component vector equations (possibly):
sin θ = Vy/V
cos θ = Vx/V
tan θ = Vy/Vx
V^2 = Vx^2 + Vy^2
Newton's Second Law:
F = ma
I split up Fa into it's components, but that didn't really help me to solve for Fb. I also had the idea of using the law of sines:
sin 140/4500 N = sin 60/b
However, the answer came out to 6062 N, and my textbook has the answer listed as 6890 N. Besides, my book doesn't even mention the law of sines, so this probably isn't the correct method.
Any help would be greatly appreciated.
It sounds as if (although you didnt mention it) that the box in in static equilibrium??
If this is true then the net force must be zero, decomposing the vectors into two directions (vertical & horizontal) should make this easier
-spoon
That makes things a great deal easier. Thanks for your help!
1. What is the purpose of determining the force of Fb in a homework statement?
The purpose of determining the force of Fb in a homework statement is to understand and quantify the force that is acting on an object. This information can be used to solve problems and equations related to the motion of the object.
2. How do you determine the force of Fb in a homework statement?
The force of Fb can be determined by using Newton's Second Law, which states that force equals mass times acceleration (F=ma). In most homework statements, the mass of the object is given and the acceleration can be calculated using other known variables.
3. What are some common units for force in a homework statement?
The most common units for force in a homework statement are Newtons (N) and pounds (lb). Other units such as dynes and kilograms-force may also be used depending on the specific problem and the unit system being used.
4. Can the force of Fb be negative in a homework statement?
Yes, the force of Fb can be negative in a homework statement. This indicates that the force is acting in the opposite direction of the chosen positive direction. It is important to pay attention to the sign of the force when solving problems and interpreting the results.
5. How does the force of Fb affect the motion of an object in a homework statement?
The force of Fb affects the motion of an object by causing it to accelerate in a certain direction. Depending on the magnitude and direction of Fb, the object may speed up, slow down, or change direction. The net force acting on an object, including Fb, determines its overall motion according to Newton's Second Law.
10K
