Dft of cos function
  • Thread starter amaresh92
greetings,
i have typed some code in matlab to find the 5 point fft of cos function of frequency 100hz but in answer i am not geting the answer at 100 hz.may i know where the things going wrong. the code is as this one
clc;
t=0:1/4:1;
x=cos(2*pi*100*t);
xm=abs(fft(x));
disp(xm)
p=0:length(xm)-1;
subplot(2,2,1);
stem(100*p,xm);
the answer is
5 0 0 0 0
thanks in advance
Answers and Replies
uart
Hi amaresh92. Tell me what you know about the Nyquist sampling theorem.
dont know why it has to be true
uart
Ok. The problem is that your single is at 100Hz, but you are only sampling at at 4 Hz (4 samples per second). Sampling theory says that we have to sample at at-least twice the highest frequency component of the signal, so greater than 200 Hz in this case. What this means is that your "t" spacing must be less than 0.005.
uart
Hi amaresh92, if you want a simple 5 point example then try this code and see if the results make more sense. :smile:
Code:
n = 5                    # Specify the number of points to sample.
fs = 500                 # Specify the sample frequency.
dt=1/fs                  # Calculate the inter-sample interval.
t = [0:n-1]*dt           # Create the sample vector.
x = cos(2*pi*100*t)      # Create the signal vector.
xm = abs(fft(x))         # Compute the fft magnitude.
df = fs/n                # Calculate the frequency increment of the fft.
ascale = n/2             # Amplitude scale factor.
                         # Plot fft magnetude. Note "reflection" about fs/2.
plot([0:n-1]*df,xm/ascale,'*')
thanks a lot
Related Threads on Dft of cos function
  • Last Post
10K
  • Last Post
  • Last Post
  • Last Post
  • Last Post
15K
  • Last Post
10K
