Homework Help: DFT of cosine
  1. Jun 4, 2013 #1
    Compute the M sample DFT of:
    f(m) = cos(2*pi*(f*m)) for 0 <= m <= M-1
    where M = 128, f = 1/16
    This should be done by hand, and the solution will reduce to a very simple form.
    2. Relevant equations
    3. The attempt at a solution
    I slaved through this problem and got an answer that seems to have the same shape and magnitude as the dft function in MATLAB, but it is not what I'd consider a "very simple form." Could you please check my work and see if there is any major simplifications I missed?
    First, we look at the generic formula for the DFT:
    [tex]
    \tilde{x(k)} = \sum_{n=0}^{N-1} x(n) e^{\frac{-j 2 \pi k n}{N}}
    [/tex]
    where x(k) is the frequency values at normalized frequency k, x(n) is the input sample, and N is the number of samples taken. For this problem, this formula is:
    [tex]
    \tilde{f(k)} = \sum_{n=0}^{M-1} cos(2 \pi f_x n) e^{\frac{-j 2 \pi k n}{M}}
    [/tex]
    We can utilize Euler's identity:
    [tex]
    cos(x) = \frac {e^{jx}+e^{-jx}}{2}
    [/tex]
    [tex]
    \tilde{f(k)} = \sum_{n=0}^{M-1} (\frac{e^{j2 \pi f_x n}+e^{-j 2 \pi f_x n}}{2}) e^{\frac{-j 2 \pi k n}{M}}
    [/tex]
    Distributing the outside exponential, separating into two summations:
    [tex]
    \tilde{f(k)}
    = \sum_{n=0}^{M-1}
    \frac
    {e^{j 2 \pi f_x n}e^{-j 2 \pi k \frac{1}{M}n}}
    {2}
    = \sum_{n=0}^{M-1}
    \frac
    {e^{-j 2 \pi f_x n}e^{-j2 \pi k \frac{1}{M}n}}
    {2}
    [/tex]
    Combine terms:
    [tex]
    \tilde{f(k)}
    = \sum_{n=0}^{M-1}
    \frac{1}{2}
    e^{j 2 \pi n (f-\frac{1}{M}k)}
    = \sum_{n=0}^{M-1}
    \frac{1}{2}
    e^{-j 2 \pi n (f+\frac{1}{M}k)}
    [/tex]
    The form of a geometric sum:
    [tex]
    \sum_{n=0}^{M-1} a^n = \frac{1-a^M}{1-a}
    [/tex]
    In this case:
    [tex]
    a = e^{j 2 \pi (f-\frac{1}{M}k)}
    [/tex]
    Resulting in:
    [tex]
    \tilde{f(k)} = \frac{1}{2}
    \frac
    {1 - e^{j2 \pi (f-\frac{1}{M}k)M}}
    {1-e^{j2 \pi (f - \frac{1}{M}k)}}
    + \frac{1}{2}
    \frac
    {1-e^{-j 2 \pi (f+\frac{1}{M}k)M}}
    {1-e^{-j 2 \pi (f+\frac{1}{M}k)}}
    [/tex]
    There is a specific identity to be used:
    [tex]
    \frac{1-e^{jaN}}{1-e^{ja}} = \frac{e^{\frac{ja(N-1)}{2}}sin(\frac{aN}{2})}{sin(\frac{a}{2})}
    [/tex]
    In our case:
    [tex]
    \tilde{x(k)} = \frac{1}{2}
    \frac{
    e^{\frac{[j2 \pi (f-\frac{1}{M}k)][M-1]}{2}}
    sin(\frac{[2 \pi (f-\frac{1}{M}k)]M}{2})}
    sin(\frac{2 \pi (f-\frac{1}{M}k)}{2})
    \frac{1}{2}
    \frac{
    e^{\frac{[-j2 \pi (f+\frac{1}{M}k)][M-1]}{2}}
    sin(\frac{[-2 \pi (f+\frac{1}{M}k)]M}{2})}
    sin(\frac{-2 \pi (f+\frac{1}{M}k)}{2})
    [/tex]
    Plugging in the original values:
    [tex]
    \tilde{f(x)} = \frac{1}{2}e^{127 j \pi (\frac{1}{16}-\frac{1}{128}k)}
    \frac
    {sin[128 \pi (\frac{1}{16} - \frac{1}{128}k)]}
    {sin[\pi (\frac{1}{16} - \frac{1}{128}k)]}
    \frac{1}{2}e^{-j 127 \pi (\frac{1}{16}+\frac{1}{128}k)}
    \frac
    {sin[128 \pi (\frac{1}{16}+\frac{1}{128}k)]}
    {sin[\pi (\frac{1}{16}+\frac{1}{128}k]}
    [/tex]
  3. Jun 5, 2013 #2
    Return to the sum of the geometric series. Consider the case that [itex]f = \frac{\ell}{M}[/itex] where [itex]\ell[/itex] is an integer.
Have something to add?
Draft saved Draft deleted
