Diagonal line plotting in C
  • Thread starter 1alph1
this is quite a simple problem,what i am trying to do is plot a line between any two points on my image, i can plot horizontal lines fine.
below is the part of my code to for the line...
int x1 = 92, y1 = 35, x2 = 150, y2 = 55;
//line between two points
for (x = x1; x <= x2; x++)
y = y1;
y2 = y1 + ((y2-y1)/(x2-x1))*(x2-x1);
y = y1;
y2 = y1 + ((y2-y1)/(x2-x1))*(x2-x1); ??????
image[x][y][0] = 255; // red colour component
image[x][y][1] = 255; // green colour compnent
image[x][y][2] = 255; // blue colour compnent
this plots a straight line from points (x1,y1) to (x2, )
however im stuck on the y2 value im not sure on what code to use i know its got somthing to do with the graident?
i also know that....
about a for loop in x running between x1 and x2, and calculating a value of y at each point in x.
Something like
y = y1 + gradient*(x - x1);
Now if the magnitude of the gradient is greater than one you'll need a loop in y calculating x at each point.
And you'll need to check x2 is greater than x1 (and swap them if it's not) or the loop won't work.
any help would be really appericated thanks so much guys!!!!!!
Answers and Replies
ok i see, yes thats a good formula but im not sure how it would be implemented into the code??? i have sex x = x1 this wouldnt work with this formula, i could pre determine the graident from the four points but im not sure what to do to get y2 to move vertically while y1 remains constant??
Related Threads on Diagonal line plotting in C
  • Last Post
  • Last Post
  • Last Post
  • Last Post
16K
